plyhammer
Joined: 14 Dec 2004 Posts: 82 Location: greenville, ohio 45331
Posted: Wed Dec 22, 2004 12:30 am Post subject: 924 sloppy shifter |
| I would like to tighten up the shifter. The transmission is tight but the shifter has all kinds of play in it. Is this an easy fix in which I can change a bushing or something from under the shift boot or is this a "take the tranny out" type of thing in which case I will live with it. |
Posted: Wed Dec 22, 2004 2:07 am Post subject: |
There's a pin on the shifter that the shift rod pivots on and it wears to an egg shape over time. That should be the source of a good bit of the looseness. I took a lot of the play out of mine by wrapping that egg-shaped part with just enough plastic electrical tape (prestretched and wrapped tight) to take out the play and serve as a bushing. I fit a wide washer on the end before replacing the C-clip to inhibit the tape from sliding out sideways over time. That's the quick-easy-cheap fix. Another option is to grind the pin off, drill the lever and fit a bolt or a bolt and bushing to replace the pin. -Or you could buy a new shift lever. Bushings at the gearbox end can be worn too, but I haven't messed with them yet.
Also, there were at least 2 different shifters used, so your model, year and gearbox type (snailshell or Audi) would be useful. _________________ "..it's made in Germany. You know the Germans always make good stuff."
plyhammer
Posted: Wed Dec 22, 2004 2:20 am Post subject: new to this |
| I am really new to the porsche scene. How would I tell which tranny I have? |
D Hook
Posted: Wed Dec 22, 2004 2:26 am Post subject: |
| If you tell people what year your car is, whether or not it's a turbo or N/A (normally aspirated), that would help alot. Turbo's came with a different tranny, early year models were only 4 speeds, later only 5 speeds. So please post your year, model, turbo or N/A. |
plyhammer
Posted: Wed Dec 22, 2004 2:43 am Post subject: yup |
| my 924 is no turbo but for $400 it is definately fun to drive! Weeeee |
My924gtc
Posted: Wed Dec 22, 2004 3:04 am Post subject: |
It is also a '79 and that is important. Ply you have a "snailshell" style tranny.
If you go into your profile and change your 'signature' to read
1979 924 NA or some thing to that affect
that will eliminate a lot of guesswork for people trying to help you.
Just take a look at others signatures and include some useful info. _________________ MJ
'81 924 2.0L T
Sponsor of the "2006 Battle in the Badlands" |
Posted: Wed Dec 22, 2004 3:38 am Post subject: |
What I said above applies to the Audi style shifter. If you have the Porsche snailshell type (made by Getrag if I'm not mistakin'), the quick-easy plastic tape trick might still work, but you have another option - replace the bushings at the shift lever. You'll have 2 rods attached to the lever with 2 pins and need a total of 4 of these bushings - part # 999.924.002.40
It's real easy with the Audi style, but someone else would have to fill you in as to the ins 'n outs and how much fun it is/isn't to do with the snailshell-type shifter. -And if you're bushings at the gearbox are more likely to need to be messed with as well. _________________ "..it's made in Germany. You know the Germans always make good stuff."
plyhammer
Posted: Wed Dec 22, 2004 3:45 am Post subject: thanks everyone |
| thank everyone |
Magnus K
Joined: 25 Oct 2003 Posts: 151 Location: Linkoping, in Sweden
Posted: Wed Dec 22, 2004 5:28 am Post subject: |
Wait a second... Even if the car is a -79, it could still have a Audi-style gearbox. If it's a 4 speed, anyway...
Smoothie wrote about the quick&cheap solution to the front end of the shift rod, the same tactics can be used on the rear end of the Audi-style shift linkage.
The linkage ends on top of the audi-style gearbox:
http://www.shell.linux.se/magnusk/projekt/bilder/20040629_panikmek03.jpg
Its the part looking behind the vertical lever thats most likely to cause the problems with a sloppy shifter. This part is made of plastic, and wears out... This part is pretty expensive if you buy it from Porsche, seems to be included in part no: 477 711 103 B...
Simply add som electrical tape in the pins:
http://www.shell.linux.se/magnusk/projekt/bilder/20040630_terapimek02.jpg
Worked for me during this summer anyway!
Good luck!
Magnus _________________ Another curious Swede...
Asleep in Sweden, Europe, when you US guys are awake... |
My924gtc
Posted: Wed Dec 22, 2004 5:32 am Post subject: |
I thought the 4 speed was discontinued in the US after 1978? Might be wrong. I have had a few '79 come through here and all were 5 speeds. _________________ MJ
'81 924 2.0L T
plyhammer
Posted: Wed Dec 22, 2004 5:41 am Post subject: She is a 5 speed |
| 5 speed |
Magnus K
Posted: Wed Dec 22, 2004 5:57 am Post subject: |
| My924gtc wrote: | | I thought the 4 speed was discontinued in the US after 1978? Might be wrong. I have had a few '79 come through here and all were 5 speeds. |
Ah, sorry... I got a Euro-spec car, and they came with a 4 speed Audi tranny as standard...
plyhammer - You got the snailshell, then! I don't have any experience with those so... Good luck anyway!
/Magnus _________________ Another curious Swede...
Posted: Wed Dec 22, 2004 7:39 am Post subject: |
I can't resist a nice cheap-easy tape repair, and a slight improvement just occurred to me while looking at your second pic, Magnus. -And I'll be using it on my own tape repair at the front when that needs redoing... The idea is to simply put a piece or two of heat-shrink tubing over the tape and shrink it down - that should hold the tape repair together, keeping it from unpeeling, plus the thicker, glossy heat-shrink provides a reasonably tough and slippery surface which should extend the life of the fix. _________________ "..it's made in Germany. You know the Germans always make good stuff."
Magnus K
Posted: Wed Dec 22, 2004 9:50 am Post subject: |
| Smoothie wrote: |
I can't resist a nice cheap-easy tape repair, and a slight improvement just occurred to me while looking at your second pic, Magnus... *snip* |
Ah! Great idea, Smoothie! I already got the tranny out of the car and the shift rod is also disassembled so my car will be the guinea pig (spelling?) for this experiment! I think it's best to combine tape and heat-shrinking tube, coz I needed two layers of tape for my previous repairs...
Hehe, it'll probably be red shrink tube for my repairs... I hope it works with the Indishrot on the outside!
/Magnus, who likes cheap repairs at the moment! (unemployed! ) _________________ Another curious Swede...
leadfoot
Posted: Thu Dec 23, 2004 8:15 am Post subject: |
I am thinking that as a more permanent fix you could cut the pivot stud/bolt off, drill a new hole and fit a coach bolt, using a slightly smaller hole you could have a pressure fit, or use a double ended stud, tap the new drilled hole and have enough length on the stud protruding to secure with a locking nut.
The only thing needed might be to cut the extra threaded length off the end of the stud at the free end.
For a semi permanent fix make a sleeve out of brass/steel piping and slip this over the pivot stud.
Leadfoot |
