Where can I buy a torque wrench?
timstar92404
PostPosted: Thu Dec 23, 2004 2:21 pm    Post subject: Where can I buy a torque wrench? Reply with quote
I'm looking for a torque wrench that measures in ft/lbs and has like .5 distance between measruements.
I already checked canadian tire and the mastercraft torque wrench that is 3/8 inches measures in inch / pounds nad the 1/2 inch measures in ft /lbs but it starts at 25.....
they also have a crappy torque wrench (needle type) that measures in ft pounds 0 to 150 but the mearuments are 0, 5, 10 etc. and it doesn't look too acurate.. I can't really uset that to measure 7 or 11 ft/lbs
I also checked the sears website right now (canadian site) and they only have a torque wrench that measures in inch pounds 25-250 inch/pounds and the same crappy needle type.
the us site has the wrench i need, mastercraft torque wrench that measures form 5 to 80 ft pounds with .5 measurements but they only have it in the us stores and you have to pick it up in the store.
This sucks I don't know where else to look.
78 924 sold.
85.5 944
kaffine
PostPosted: Thu Dec 23, 2004 3:20 pm    Post subject: Reply with quote
Well if you can do a little math in your head. Divide inch pounds by 12 to get foot pounds.
You didn't specify how much you are willing to spend you can order from Snapon but it wont be cheap.
http://www.snapon.com/canada/
80 931
Sir Arthur Eddington
timstar92404
PostPosted: Thu Dec 23, 2004 4:39 pm    Post subject: Reply with quote
yeah those wrenches are way too expensive for me....
they are like 279 to 500 bucks....
i was thinking of paying around 100 bucks.
78 924 sold.
85.5 944
Chrenan
PostPosted: Fri Dec 24, 2004 1:04 am    Post subject: Reply with quote
You should check www.houseoftools.com
They are a Canadian company, you can order online if you don't have one near you.
I got my inch/pound 1/4 drive torque wrench from them, I think it was around $60.
I got a similarly priced 3/8 drive foot/pound torque wrench from them for the higher torque bolts.
CMXXXI
PostPosted: Fri Dec 24, 2004 4:55 am    Post subject: Reply with quote
http://www.toolsource.com/ost/results.asp?qu=torque+wrench
Surely one of the 200 or so they have listed will fit your budget. To find a wrench that accurately measures down at the 7-10 ft. lb range, you will probably need one that is calibrated in inch-pounds. I understand that although the beam type of wrench isn't the most glamorous, they are actually more accurate throughout their range.
'79 Eurospec 931
PostPosted: Fri Dec 24, 2004 3:05 pm    Post subject: Reply with quote
for small torque amounts go with the needle type and I already told you to go to kmstool.com and find the store locations and go there, they have them really cheap at the moment, they also have the other style click head (cant remember the technical term for them at the moment) for really cheap as well, but when it comes to low amounts the needle type is fine.
3 928s,
PostPosted: Mon Dec 27, 2004 11:49 am    Post subject: Reply with quote
I have two, a smaller one that measures in inch lbs, the other in ft-lbs. Both are craftsman from Sears and both reliably measure to 1-unit increments. About $60US each.
Why don't you try your local Sears again, they'll have it. If not, try sears.com and order online.
924guy
PostPosted: Tue Dec 28, 2004 12:11 am    Post subject: Reply with quote
yep, sears is the place.. ive got one in inch pounds and another in foot pounds, both sears products..
Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha
