Transmission mounts same on 924 and 944?
Magnus K
PostPosted: Thu Dec 30, 2004 12:32 am    Post subject: Transmission mounts same on 924 and 944? Reply with quote
Hi!
Is the transmission mounts (silent blocks) the same on 924 and the 944?
I trying to swap the transmission , bought a 5 speed (016/8 ) instead of the old 4 speed (probably a 88/6), and the silent blocks are falling to pieces...
PelicanParts seems to only list the 944 parts? And in the PET, the 924 and 944 silent blocks has different parts number?
/Magnus
Another curious Swede...
Asleep in Sweden, Europe, when you US guys are awake...
Diesel
PostPosted: Thu Dec 30, 2004 3:27 am    Post subject: Reply with quote
If it's an Audi based transmission that you have in your 924 then the trans mounts are the same as a 944.
Dan Flanagan--2002 VW Jetta TDI, 83 Mercedes 300D,83 Mercedes Euro-240D
Magnus K
PostPosted: Thu Dec 30, 2004 5:01 am    Post subject: Reply with quote
Yes, it's a 5 speed Audi gearbox.
At least they do look the same? But in the PET there is:
477 399 153 J = the 924 suspension mounts (or silentbloc)
944 375 045 = the 944 suspension mounts
IIRC the rear cross member is different on the 924 compared to the 944... Could this be a reason why a 944 transmission mount wouldn't fit on a 924?
/Magnus
Diesel
PostPosted: Thu Dec 30, 2004 9:16 am    Post subject: Reply with quote
The older 924 trans mounts had one bolt through the rubber to the mount, the newer ones( and the 944's) had 2. That's it. I have a set of 944 mounts in my car right now.
Magnus K
PostPosted: Thu Dec 30, 2004 7:00 pm    Post subject: Reply with quote
OK, thanks, Diesel!
/Magnus
RC
PostPosted: Sun Aug 24, 2008 4:14 pm    Post subject: Reply with quote
Dug up this old thread and blew the dust off it.
Would like something more substantial than stuffed tranny mounts with some 10mm rubber jammed in them. Not worth using S/H mounts IMO but the genuine replacements are an outrageous price. The 944 ones are only half as ridiculously priced.
Now I dont know what the 924S has but has anyone got the 944 type to compare to. If one of the 2 holes line up thats all we need hopefully. A picture will tell a thousand words nearly. Unfortunately Pelican`s pic is of the other side.
Anyone help?
Raceboy
PostPosted: Sun Aug 24, 2008 5:06 pm    Post subject: Reply with quote
I can verify that early 944 (pre-85) mounts are the same as 924 mounts with two bolts. Late 944 hase one central mount with crossmember.
924S has standard 924 mounts.
'83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
RC
PostPosted: Mon Aug 25, 2008 7:43 am    Post subject: Reply with quote
Thanks Raceboy for confirming that.
Looks like I`m going shopping for early 44 mounts then.
Cheers
