Magnus K
Joined: 25 Oct 2003 Posts: 151 Location: Linkoping, in Sweden
Posted: Thu Dec 30, 2004 12:32 am Post subject: Transmission mounts same on 924 and 944? |
Hi!
Is the transmission mounts (silent blocks) the same on 924 and the 944?
I trying to swap the transmission , bought a 5 speed (016/8 ) instead of the old 4 speed (probably a 88/6), and the silent blocks are falling to pieces...
PelicanParts seems to only list the 944 parts? And in the PET, the 924 and 944 silent blocks has different parts number?
/Magnus _________________ Another curious Swede...
Asleep in Sweden, Europe, when you US guys are awake...
Diesel
Posted: Thu Dec 30, 2004 3:27 am Post subject: |
If it's an Audi based transmission that you have in your 924 then the trans mounts are the same as a 944. _________________ Dan Flanagan--2002 VW Jetta TDI, 83 Mercedes 300D,83 Mercedes Euro-240D |
Magnus K
Posted: Thu Dec 30, 2004 5:01 am Post subject: |
| Diesel wrote: | | If it's an Audi based transmission that you have in your 924 then the trans mounts are the same as a 944. |
Yes, it's a 5 speed Audi gearbox.
At least they do look the same? But in the PET there is:
477 399 153 J = the 924 suspension mounts (or silentbloc)
944 375 045 = the 944 suspension mounts
IIRC the rear cross member is different on the 924 compared to the 944... Could this be a reason why a 944 transmission mount wouldn't fit on a 924?
Asleep in Sweden, Europe, when you US guys are awake... |
Diesel
Posted: Thu Dec 30, 2004 9:16 am Post subject: |
The older 924 trans mounts had one bolt through the rubber to the mount, the newer ones( and the 944's) had 2. That's it. I have a set of 944 mounts in my car right now. _________________ Dan Flanagan--2002 VW Jetta TDI, 83 Mercedes 300D,83 Mercedes Euro-240D |
Magnus K
Posted: Thu Dec 30, 2004 7:00 pm Post subject: |
OK, thanks, Diesel!
RC
Posted: Sun Aug 24, 2008 4:14 pm Post subject: |
Dug up this old thread and blew the dust off it.
Would like something more substantial than stuffed tranny mounts with some 10mm rubber jammed in them. Not worth using S/H mounts IMO but the genuine replacements are an outrageous price. The 944 ones are only half as ridiculously priced.
Now I dont know what the 924S has but has anyone got the 944 type to compare to. If one of the 2 holes line up thats all we need hopefully. A picture will tell a thousand words nearly. Unfortunately Pelican`s pic is of the other side.
Anyone help? |
Raceboy
Posted: Sun Aug 24, 2008 5:06 pm Post subject: |
I can verify that early 944 (pre-85) mounts are the same as 924 mounts with two bolts. Late 944 hase one central mount with crossmember.
924S has standard 924 mounts. _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
RC
Posted: Mon Aug 25, 2008 7:43 am Post subject: |
Thanks Raceboy for confirming that.
Looks like I`m going shopping for early 44 mounts then.
Cheers |
