brake proportioning valve
Benino
PostPosted: Sat Jul 30, 2005 8:16 am    Post subject: brake proportioning valve Reply with quote
I want to clean out or replace my proportioning valve(s) for the brakes on my 1980 N/A. Where is it located? Is there just one or is there one for each rear brake? Anyone replaced it before? My rears brakes seem to be too strong.
(front calipers not locked up, no leaking, working master cylinder swapped from car with perfectly working brakes, brakes bled multiple times, new front disks rear drums, new front pads rear shoes)
1980 Porsche 924 N/A USA
1980 Porsche 924 turbo USA
1987 Porsche 944S USA
Gram
PostPosted: Sat Jul 30, 2005 8:27 am    Post subject: Reply with quote
Wasn't aware there is one on 924's..
'82 924 NA Euro (hers)
'98 Audi A4 TDI (ours)
Benino
PostPosted: Sat Jul 30, 2005 11:44 am    Post subject: Reply with quote
I don’t know for sure that it has one but since it's a system with 2 diagonal circuits, and 3 lines come out of the master cylinder, that means at least one of the lines includes a front and rear wheel, so it seems to me it would have to have a proportioning valve. Nobody knows where it is or has ever worked on it?
PostPosted: Sat Jul 30, 2005 11:37 pm    Post subject: Reply with quote
No, it doesn't have one. The proportioning is built into the sizing of the hydraulic components. You may need to either rebuild or replace your calipers and/or slave cylinders - most likely the calipers aren't working strongly enough. When were the hoses last replaced?
PostPosted: Sun Jul 31, 2005 4:20 pm    Post subject: Reply with quote
I was gonna add one..still might just to see what it does.
PostPosted: Mon Aug 01, 2005 12:09 am    Post subject: Reply with quote
Not recommended. All it's going to do, unless you put in a different master cylinder, is make your rear brakes even less effective.
