worn cramshaft
924er
PostPosted: Tue Jan 31, 2006 10:26 am    Post subject: worn cramshaft Reply with quote
Quote:
1. Worn camshaft. Listen for 'ticking' noise from top of engine.
i found that on the FAQ on this website. i guesss then i got a worn camshaft i got ticking noise. can i easily replace the camshaft??
80' Porsche 924 NA - Slower then a S L O W
86' Porsche 951- New toy
View user's profile Send private message Visit poster's website AIM Address MSN Messenger
PostPosted: Tue Jan 31, 2006 11:03 am    Post subject: Reply with quote
You need to pull the valve cover and have a look first. Worn cam lobes will be easily apparent - they'd be rounded at the edges. The problem might only be that the valves need adjustment. While in there, also verify that the cam oiler elbow (small plastic piece at the front) is intact.
924er
PostPosted: Tue Jan 31, 2006 2:24 pm    Post subject: Reply with quote
thanks alot ill see what i can do
PostPosted: Tue Jan 31, 2006 2:40 pm    Post subject: Reply with quote
This is the same problem you stated in this thread?
I totally agree with Smoothie. And with the previous suggestions.
Check the lifter adjustment first. Also check the oiler elbow.
These engines all "tick" when starting from cold and may "tick" more than some other engines, due to the design. If you've never heard this type of engine before, it may sound abnormal. But it's not.
That's not to say you don't have a worn camshaft or other problems. I'm just suggesting, like others, that it's probably something more simple.
924er
PostPosted: Tue Jan 31, 2006 5:39 pm    Post subject: Reply with quote
ok ill look at it thanks alot
