Pca944
Posted: Sun Jan 29, 2006 7:44 am Post subject: Dumb Q of the Day: Opening Hood |
Here is the dumb question of the day. How do you open the hood on a 82' 931?
Before you answer though.. the hood release latch is broken. The cable doesn't feel like it is even connected to anything when you pull on it. The owner of the car said it was probably his brother's fault, but whoever screwed with it detached the cable from its proper positon.
So.. how do i open the hood? _________________ 1986 944 | 1978 924 (FS) | 1982 931 | 1980 931 |
Neil924
Posted: Sun Jan 29, 2006 8:10 am Post subject: |
| Try to get at it from under the car. I don't have an answer other than to try somthing "out of the box". |
Pca944
Posted: Sun Jan 29, 2006 8:26 am Post subject: |
| Neil924 wrote: | | Try to get at it from under the car. I don't have an answer other than to try somthing "out of the box". |
That is what I was thinking.. But there should be an easier way. _________________ 1986 944 | 1978 924 (FS) | 1982 931 | 1980 931 |
garyj19
Posted: Sun Jan 29, 2006 8:28 am Post subject: |
you might be able to find the cable and attach it to the right place? _________________ early 77 924 na |
Posted: Sun Jan 29, 2006 9:20 am Post subject: |
Check to see which end is disconnected.
If its the lever end, great, if not then you could have some difficulty coming in from the front and underneath. _________________ Porsche 924 1984 (UK import) NA
Pca944
Posted: Sun Jan 29, 2006 10:23 am Post subject: |
Does anyone have a daigram of what hte lever is suposed to look like?
The cable is disconnected from teh lever, but I assumed that if you pulled the cable the hood should open. RIght? _________________ 1986 944 | 1978 924 (FS) | 1982 931 | 1980 931 |
Posted: Sun Jan 29, 2006 10:41 am Post subject: |
Sounds logical- needs a good bit of pulling though. _________________ Porsche 924 1984 (UK import) NA
Posted: Sun Jan 29, 2006 11:50 am Post subject: |
Use vise grips and a wire stripper like this:
Find a hole in your plier type wire stripper that's bigger than the center cable but smaller than the housing and place it against the cable with the center cable coming through the hole. Then use vise grips on the center cable and using both hands push against the wire stripper and pull on the vise grips. _________________ White 87 924S "Ghost"
numbbers
Posted: Wed Feb 01, 2006 10:57 am Post subject: |
Well, I wish you luck, but a break in the cable is almost always under the hood. The cables tend to rust at the lowest point inside the insulated sleeve, because water settles there. When the rust gets bad enough, the hood pull will get very hard to operate. Then you pull harder, and it breakes.
I would try locating the cable from underneath the car, where it leaves the firewall, and routes along the top of the frame rail. It has a black rubberized coating. But, be carefull, because the speedometer cable is black also. However, the speedo cable is larger diameter than the hood cable, so find the smaller one. Find what you think is the lowest point, and cut the cable in front of that point, with some heavyduty wirecutters.
Then try the vicegrips to pull the cable to open the hood. It will probably take a very hard pull, but it should work. The replacement cables are relatively cheap, and include a new lever. _________________ 1980 924 Turbo |
Min
Posted: Wed Feb 01, 2006 12:19 pm Post subject: |
If all else fails, apparently you can unbolt the hood latch from underneath, I don't know for certain that you can becuase I was able to pop my hood using the visegrips/pliers method when the cable broke.
Min |
Posted: Wed Feb 01, 2006 12:23 pm Post subject: |
Under the hood yesterday and there is a small gap between the top of the radiator and the hood latch.
You may be able to get a lever in there and slide the latch over to release the hood.
You would have to remove the lower valance cover and come up thru there. _________________ Porsche 924 1984 (UK import) NA
