how much is enough?
kike924
PostPosted: Fri Feb 03, 2006 10:58 am    Post subject: how much is enough? Reply with quote
Because of lack of parking space I had to move my 924 rather far away from where I live.
As a result I only drive it once or twice each 7-10 days.
I wonder if any of you know what is the minimum use our cars need to keep running perfect.
I know car companies have this item figured out but I donīt know the correct answer
Euro 924 1980 N/A
Daily driver + week end racer
PostPosted: Fri Feb 03, 2006 6:38 pm    Post subject: Re: how much is enough? Reply with quote
Twice a day!
Seriously, if the car sits for two or three days at a time, there shouldn't be a problem.
Rooy
PostPosted: Sat Feb 04, 2006 10:22 am    Post subject: Reply with quote
Once or twice a week or so is not too bad. The important thing is that when you do drive it that you get everything up to temp; especially the oil. This usually takes a bit longer after the water reaches operating temp. This will drive out moisture and other combustion byproducts which will quickly degrade the oil if the car is only driven on short trips.
Andrew
Neenah, WI
'78 924 with dual Dellortos
