Posted: Tue Feb 07, 2006 12:40 am Post subject: |
ok it is the big fronts I am talking about as iirc they are the same as the 928 S4 brakes, however I would love to see a pic of a 15" rim on the S4 calipers as I have them on my 928S and couldnt see them fitting _________________ 3 928s, |
sequential
Posted: Tue Feb 07, 2006 1:45 am Post subject: |
| Lizard wrote: | | ok it is the big fronts I am talking about as iirc they are the same as the 928 S4 brakes, however I would love to see a pic of a 15" rim on the S4 calipers as I have them on my 928S and couldnt see them fitting |
You had stated 4 piston calipers and 951 . The standard 951 4 piston calipers will fit in the front on 15 inch wheels the s package will not. _________________ 928 gts prototype
baby blue engine block
steam in 1,2,3,4 sometimes
cold star issues while on stands
112 whp with new 4 valve head and MIS 2 |
john h
Posted: Tue Feb 07, 2006 10:14 am Post subject: |
I run 15 inch cookie cutters on my car which has now been fitted with 951 brakes.
To fit these I installed spacers front and rear which are 10mm thick. I tried some at 7mm and they rim just touched caliper for one rim but not the others. This rim seems to be fractional out so I installed the 10mm spacers I had made ages ago for some other rims and they work perfectly. _________________ Remember a Porsche is not just for Christmas,
Raceboy
Posted: Tue Feb 07, 2006 2:54 pm Post subject: |
| sequential wrote: | | Lizard wrote: | | ok it is the big fronts I am talking about as iirc they are the same as the 928 S4 brakes, however I would love to see a pic of a 15" rim on the S4 calipers as I have them on my 928S and couldnt see them fitting |
You had stated 4 piston calipers and 951 . The standard 951 4 piston calipers will fit in the front on 15 inch wheels the s package will not. |
SOME 15" wheels will fit with big fronts, and in most cases require spacer like John H said. _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
kaffine
Posted: Tue Feb 07, 2006 3:17 pm Post subject: |
How do you tell the diffrence between the big fronts and the normal ones? _________________ 80 924
80 931
Sir Arthur Eddington |
sequential
Posted: Tue Feb 07, 2006 4:06 pm Post subject: |
I just don't see how the S brakes , would fit with a 15 inch wheel the standard 951 fits like a glove on 15 inch wheels in the front and in the rear the calipers will rub unless you space the wheel out so the caliper does not get close to the wheel rim , Wow that is a lot of spacing you would have to be using the 924 steel banana's _________________ 928 gts prototype
john h
Posted: Tue Feb 07, 2006 8:34 pm Post subject: |
Nope using the ali 951arms and 951 torsion bar carrier modified to suit the 931 dogleg gearbox.
Back fenders will be the boxed Le Mans GTR type so the wider the track at the back the better - means Idon't have to buy 10 or 11 inch wide wheels just yet as the 7 or 8 inch fill the fenders nicely with the spacers _________________ Remember a Porsche is not just for Christmas,
pkt1213
Posted: Thu Feb 09, 2006 3:49 am Post subject: |
| Aren't the 931 brakes and the N/A 944 brakes similar? Could you use the Wilwood N/A 944 brake upgrade for this ap? You'd get to use 86 Turbo brake discs and it's a hell of a lot cheaper than that buing all that new front suspention |
J1NX3D
Joined: 06 Feb 2003 Posts: 1333 Location: New Zealand
Posted: Thu Feb 09, 2006 4:25 am Post subject: |
| pkt1213 wrote: | | Aren't the 931 brakes and the N/A 944 brakes similar? Could you use the Wilwood N/A 944 brake upgrade for this ap? You'd get to use 86 Turbo brake discs and it's a hell of a lot cheaper than that buing all that new front suspention |
yes, theyre the same and bass gt has already done it you dont get 86 turbo discs with the kit. _________________ '86 944 |
