engine cooling to much?
Goto page Previous  1, 2
doomer77
PostPosted: Tue Feb 14, 2006 5:23 pm    Post subject: Reply with quote
will do, thanks!
Why drink and drive when you can smoke and fly?
Carpe diem. and if that doesnt work; get drunk!
1980 924 n/a - engine swap begun
1989 Volvo 480ES
doomer77
PostPosted: Tue Feb 14, 2006 8:09 pm    Post subject: Reply with quote
i have to find one in europe, but around 25€ would be a good price right? EDIT: just found one on ze german ebay, the chooise is between a 82* and a 88*, but it says both are only for a 2.5l 924S, is there a difference between the 2.0l and 2.5l thermostat?
side note to the original problem:
when the engine gets to hot (ie. after ive been doing donuts for a while), it loses oil pressure as soon as the tach gets under 1,000. but the gauge is only a little over half by then. so i suspect its actually reading low all the time and when its half way the engine is in reality overheated... sound logical?
erik
1989 Volvo 480ES
Neil@Bournemouth
PostPosted: Tue Feb 14, 2006 8:46 pm    Post subject: Reply with quote
I had the same problem and thought my car never heated up.
Ive recently replaced the temperature sender and now the gauge reads correctly!
Could be the same problem you’re having?
PostPosted: Tue Feb 14, 2006 10:55 pm    Post subject: Reply with quote
temperature sender ? what do you mean ?
Tigger937
PostPosted: Wed Feb 15, 2006 4:26 am    Post subject: Reply with quote
This is what the rear coolant flange under the dizzy on the S2 turbos looks like. I'm guessing your's is probably similar. My sender (sensor) did not have full thread engagement and was causing my gauge to read lower than the engine temp actually was. The threads on it were damaged (not sure if it was deliberate or accidental) allowing it to only be screwed in about half way.
1981 931 (Concours)
1982 931 (Daily Driver)
"Think outside the box"
PostPosted: Wed Feb 15, 2006 11:40 am    Post subject: Reply with quote
erik
They are different, you need to find an 88 degree one for a 2.0 liter 924.
Page 2 of 2
