Tips for removing the radiator
Meneer aard
PostPosted: Thu Jul 06, 2006 7:39 am    Post subject: Tips for removing the radiator Reply with quote
My radiator of the 924 is leaking (only with a hot engine, when it is turned off or runs with the cooling fans kicks in).
I look in my Haynes manual, but they say that i must remove the expantion tank and my windshield washer fluid tank??? But i believe it can be easier?
Or is that the only way to remove the radiator? Because the cooling fan removal is easy with 4 bolts, and the radiator is placed to with 4 bolts.
Thanks in advice
Porsche 924 Euro 1977
steeny
PostPosted: Thu Jul 06, 2006 11:14 am    Post subject: Reply with quote
if you undo the 4 bolts on the radiator and undo all the hoses, you should be able to drop it straight out the bottom. but the expansion tank is not that hard to remove. maybe 3 bolts and 2 nuts. that gets the whole mounting for it completely out of the way.
as far as the windscreen washer bottle, i've never removed mine.
1978 924 N/A
she's gone.....
PostPosted: Thu Jul 06, 2006 5:16 pm    Post subject: Reply with quote
It doesn't need to come down. If you remove the expansion tank, even with the fan still fitted, you can lift out of the car from above.
Steeny's right, you don't need to touch the washer reservoir.
Meneer aard
PostPosted: Fri Jul 07, 2006 5:24 am    Post subject: Reply with quote
Thanks for the tips
A couple of weeks ago, i removed the fan of the radiator and it is verry easy.
