CBass
Posted: Mon Jul 10, 2006 12:56 pm Post subject: Car weight? |
So has anyone here weighed their car? I have weighed mine at a few truck scales and they all tell me 1070/2350lbs with a full tank of gas.
My car seems to have a hefty rear weight bias as well. I think it was something like 40kg heavier in the rear! _________________ '81 931 in various states of assembly |
Vince Ponz
Posted: Mon Jul 10, 2006 1:05 pm Post subject: |
remove tire, cut shocks, or use euro bumpers, remove insulation, use lighter muffler, remove the top of the rear seats and you will get lighter.
Oh yes, go on a diet. _________________ "Never let them see you sweat"
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock |
flosho
Posted: Mon Jul 10, 2006 1:10 pm Post subject: |
Local junkyard, I weighed my car at, I believe, 2650lbs with 7/8's tank of gas and few things in the hatch. _________________ [This Space For Rent] |
CBass
Posted: Mon Jul 10, 2006 2:43 pm Post subject: |
| Vince Ponz wrote: | remove tire, cut shocks, or use euro bumpers, remove insulation, use lighter muffler, remove the top of the rear seats and you will get lighter.
Oh yes, go on a diet. |
Way ahead of you Vince. No tire, shocks are being replaced shortly by aluminum brackets. Muffler is slated for replacement eventually. All interior behind the doors is gone. All carpet, trim, etc.
Sound deadening is gone. All power components have been replaced by manual, air conditioning is gone, so is the entire HV assembly in fact.
Working on a plan to cut out the entire rear deck including spare tire well and put a fuel cell where the spare tire well once was. This should lower the centre of gravity, shave a few pounds and give me a good deal more cargo room. It seems there is a structural brace above the gas tank between the frame spars that will be the limiting factor in this plan.
Also, I'm the lightest I've been in about 7 years. _________________ '81 931 in various states of assembly |
CBass
Posted: Mon Jul 10, 2006 2:48 pm Post subject: |
Something occurred to me, the rear ride height is still too high on this car. I'm betting that the weight distribution will change somewhat once the rear ride height is set to the correct level. _________________ '81 931 in various states of assembly |
seanski44
Joined: 13 Mar 2006 Posts: 532 Location: Nottingham UK
Posted: Mon Jul 10, 2006 3:08 pm Post subject: |
and the petrol tank is at the rear.... so that will push the weight back surely? _________________ 1998 BMW Z3 2.8 arctic silver & red
1981 168HP 931 S2 blue/tan leather - SOLD
1985 121HP 924 2.0l na modded - SOLD!
1992 968 lux SOLD
1989 944 2.7 lux SOLD |
Joined: 29 Jul 2001 Posts: 9114 Location: Royal Oak, MI, USA
Posted: Mon Jul 10, 2006 9:56 pm Post subject: |
My car weighs 2620 with:
me (160lbs)
40lbs lead ballast
3/8 tank gas (about 4-5 gal?)
cage (estimate 120#)
no interior except dash and HVAC system (probably compensates for the cage).
So weight without me we're talking 2440#. That's the racecar
My other cars, sans driver, weigh closer to 2750-2800# - no mods or equipment removed.
Corner weights - 650 per corner, except (as of last weigh-in) a 20# bias in the rear - so 650# each front, 660# each rear corner. _________________ Vaughan Scott
Posted: Tue Jul 11, 2006 11:35 am Post subject: |
Get rid of the lead ballast by drinking more beer!!!  _________________ White 87 924S "Ghost"
bass gt
Posted: Tue Jul 11, 2006 12:46 pm Post subject: |
Guy's,
Mine is down to 943 kg,(2074lb) with a perfect 50:50 weight balance. She could be a lot lighter without the cage. As for me...ahem, lets say i'm somewhere north of 200, but in fine fettle you understand.....  |
endwrench
Posted: Tue Jul 11, 2006 2:29 pm Post subject: |
2560lbs with 1\2 tank and SC mounted. Should be down to 2460 with removal of a few things outlined in the Body and Interior section.
Posted: Tue Jul 11, 2006 7:27 pm Post subject: |
started with 1130 Kg....thats what the papers say.
nothing is "power" on this car...everything is manual.
-25Kg removed spare weel,rear seats upper part and rear hatch carpets.
-10Kg removed front bumber complete with valance or whatever its called.
+10Kg removed old style 4 lugs system added heavyer(i guess) all vented disks 5 bold system.
Added Carrera body-kit:
rear arches alone ~ 4 Kg or smth like that
side skirts ~ 1 Kg
front bumper ~ 6 Kg
+ A SHIT LOAD OF FILLER...around the rear arches, front end and where the side skirts meet the rear arches...
this alone i think its ~ 5 Kg
so i've lightend my car by ~35 and added an extra ~30Kg of weight.
buuuuulllllllllshit if you ask me
next thing is remove all the exhaust piping, replace it with a ~2.3 inch(58mm interior) INOX pipe form front to back and use just a 944 final exhaust piece(55mm interior).
hopfully this will save 5 more Kilos and still be quiet enough to drive on the street.
anyway i think its around the same weight....but it looks better and drives nicer. _________________ Supercharger and EFI kits
Raceboy
Posted: Tue Jul 11, 2006 7:43 pm Post subject: |
But if you convert your brakes to 951 ones with aluminium calipers, they'll be lighter. _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
CBass
Posted: Wed Jul 12, 2006 5:17 pm Post subject: |
| Raceboy wrote: | | But if you convert your brakes to 951 ones with aluminium calipers, they'll be lighter. |
Or the wilwood brakes, those are a good option too.
Most importantly, this weight is unsprung weight at the very end of the control/trailing arms, making it very very very important weight to lose. _________________ '81 931 in various states of assembly |
Posted: Wed Jul 12, 2006 7:43 pm Post subject: |
i'll keep that in mind.... _________________ Supercharger and EFI kits
