Help, no injector pulse
RIPDOTCOM
PostPosted: Thu Aug 24, 2006 8:04 am    Post subject: Help, no injector pulse Reply with quote
I have plenty of fuel pressure, I have a tach signal but the car wont start, I get no injector pulse, i can spray starter fluid in the intake and it fires right up on 1/2 a crank but cant seem to get it going. THe resistance on the DME relay is 1 without power and .6 with power. I am going to try the jumper trick tonite but I dont think its going to work. Hopefully the DME is not bad but if it is I have a 28 pin EPROM. Will an ECU with a 24 pin work?
PostPosted: Thu Aug 24, 2006 9:33 am    Post subject: Reply with quote
Pull the connector on one of the injectors and try to start it with the 3 remaining ones.
RIPDOTCOM
PostPosted: Thu Aug 24, 2006 9:42 am    Post subject: Reply with quote
Tried that already, didnt work. We have 12v at the injector but no pulse and when we crank the engine voltage drops to 0v at injector.
PostPosted: Thu Aug 24, 2006 9:48 am    Post subject: Reply with quote
Have you unplugged the DME connector and checked for corrosion yet?
RIPDOTCOM
PostPosted: Thu Aug 24, 2006 9:55 am    Post subject: Reply with quote
Yes I have, looks pretty clean. I might also add that I am getting a tach signal
PostPosted: Thu Aug 24, 2006 9:59 am    Post subject: Reply with quote
I need to find my DME diagram to see what pin(s) provide the injector pulse.....
Meanwhile have you checked the injectors' ground on the block, it has a habit of turning green?
RIPDOTCOM
PostPosted: Thu Aug 24, 2006 10:41 pm    Post subject: Reply with quote
Where exactly should the ground be located?
PostPosted: Sat Aug 26, 2006 9:23 am    Post subject: Reply with quote
Look under the heater control valve.
RIPDOTCOM
PostPosted: Sat Aug 26, 2006 10:39 pm    Post subject: Reply with quote
I looked there, nothing. I think its the ecu. I sent it to a guy in N.Y. to test.
