jpv
Posted: Sat Sep 02, 2006 5:42 am Post subject: oil temperature |
Hi
I haven't posted here for a while. Good to be back!
My 924 NA has the habit of heating the oil exaggeratedly with fast driving.
The water temp stays ok but the oil temp gauge reaches the max temp (150ºC).
On normal driving it varies within 90ºC to 110ºC (I consider it normal temperature) but on fast highway driving (140km/h or 80mph upwards) or fast mountain road driving it heats up very quickly.
Once I made a 10km (7 miles) of a highway at 200km/h (120mph) and the oil gauge went through the roof (>150ºC)
Is this normal?
Thanks for the help!
Best regards!
João Vale _________________ 1969 Alfa Romeo GT 1300 Junior
1972 Alfa Romeo 2000 GT Veloce
1976 Porsche 924
1991 Mazda Miata MX5 |
Joined: 29 Jul 2001 Posts: 9113 Location: Royal Oak, MI, USA
Posted: Sat Sep 02, 2006 7:21 am Post subject: |
150C? Woah, that's way too hot!!! Sounds like you'd better get an oil cooler on there...
My racecar, with oil cooler, usually runs 105-115C in the hot days. Highest I've seen it get to is maybe 125-130C. That's outside temp of 95F (35C), running basically close to full-throttle for 20-minute periods, average lap speed of 65mph (top speed of 85mph). Revs between 3000-6000rpm, never lower.
I'm using an 8x11" cooler from Racer Parts Wholesale, very happy with it. Installation details are shown on my webpage... _________________ Vaughan Scott
D Hook
Posted: Sat Sep 02, 2006 8:32 am Post subject: |
That's hot! Sure you got the right sender for the gauge? _________________ '80 924 n/a SOLD |
jpv
Posted: Sun Sep 03, 2006 5:16 am Post subject: |
I've never checked the sender because the gauge always worked ok since I've bought the car...
But the reading on normal driving is ok. So I guess the rules out the sender.
My car is totally stock. Do you think that I really need an oil cooler or is there someting wrong?
I never rebuilt the engine (just replaced the head gasket once...) and it has around 100k miles on the clock...
What should I check to cure this overheating?
Thanks! _________________ 1969 Alfa Romeo GT 1300 Junior
1976 Porsche 924
D Hook
Posted: Sun Sep 03, 2006 5:46 am Post subject: |
I didn't think the 924's came with an oil temp guage. I thought that would be an add-on. That's why I asked about the sender because I know you can get mismatched when adding a gauge and sender.
What's the water temp reading when the oil gets this hot? _________________ '80 924 n/a SOLD |
jpv
Posted: Sun Sep 03, 2006 7:23 am Post subject: |
Yeah, I forgot about that. My console has oil temp, oil pressure and clock gauges. Most of Euro models 924 I've found are like that.
I've noticed that a lot of US 924 have the Volt meter instead of the oil temp...
The water temp indicator sits ond 2nd mark (the mark before the midle of the gauge...). _________________ 1969 Alfa Romeo GT 1300 Junior
1976 Porsche 924
johnathan1
Posted: Fri Oct 26, 2007 6:53 pm Post subject: |
Ever figure out what the problem was? _________________ -1977 924, 4-Spd...Gone
-1987 Toyota Supra Turbo, Pearl White, BPU, 300RWHP @ 10psi.
-1989 Mercedes-Benz 300SEL
WARNING: MAY CONTAIN TRACES OF AUDI OR VW! |
D Hook
Posted: Fri Oct 26, 2007 7:37 pm Post subject: |
| jpv wrote: | Yeah, I forgot about that. My console has oil temp, oil pressure and clock gauges. Most of Euro models 924 I've found are like that.
The water temp indicator sits ond 2nd mark (the mark before the midle of the gauge...). |
Helpful if you'd put in your location since it's sometimes difficult to tell if someone is here in the states or across the pond. Tough to hear those accents through the keyboard.  _________________ '80 924 n/a SOLD |
Posted: Fri Oct 26, 2007 8:07 pm Post subject: |
Hello,
also over the pond !?
My 4 / 1977 NA in germany has all the gauges and the clock as standard.
Oil temp,oil pressure, water temp, volt meter and clock.
Jpv, what you discribe is normal to my car also. When the water temp stays ok there isnt much to worry.After a fast run on the autobahn its normal that the oil pressure is on the down side and the warning light is coming on in the dash.(Engine in idle) But ! That should go away quickly when driving in normal traffic condidions.Check youre gauge while driving.
It depends also a little bit on the oil youre using, if you use ow-50 you want see that high readings, but, i wouldt stay with the usual 15w40 stuff.Its best for normal, daily driving.
There are some reports over cleaning a part in/at the oil pump in the board but i never did that till now....?!
Nobbi |
D Hook
Posted: Fri Oct 26, 2007 8:38 pm Post subject: |
I'd love to see a picture of all those gauges. Where are they located on the stock euro model? _________________ '80 924 n/a SOLD |
Posted: Fri Oct 26, 2007 11:06 pm Post subject: |
3 of them in the center console and the clock is at the left from the glovecompartment.
Nobbi  |
Posted: Fri Oct 26, 2007 11:36 pm Post subject: |
Ah so, your clock is where I put my A:F gauge..
 _________________ "..it's made in Germany. You know the Germans always make good stuff."
D Hook
| Nobbi wrote: | 3 of them in the center console and the clock is at the left from the glovecompartment.
Nobbi  |
The clock is mounted in the dash pad? I'm confused. There's only three holes in the center console. Where's the other two gauges go?
By water temp, are speaking of the multi guage or a stand alone water temp gauge?
Sorry to be so inquisitive. I'm just curious how the euro came with 5 gauges and the US only came w/the one oil pressure guage. I'd like to add a couple more like oil temp and water temp and looking for ideas where to mount them.
Any pics you can email to me?
Thanks! _________________ '80 924 n/a SOLD |
D Hook
Posted: Fri Oct 26, 2007 11:38 pm Post subject: |
| Smoothie wrote: | Ah so, your clock is where I put my A:F gauge..
But that's not a stock-from-the-factory mounting position, is it? _________________ '80 924 n/a SOLD |
Posted: Sat Oct 27, 2007 12:18 am Post subject: |
No, not in my case. Me and my trusty hole saw made that one. There's not much room behind there, but the A:F gauge is very shallow, and is probably the only one of my gauges that'd fit there easily without altering stuff behind. _________________ "..it's made in Germany. You know the Germans always make good stuff."
