alanf_uk2002
Posted: Sat Oct 14, 2006 1:49 am Post subject: |
Hi Lizard
Yeah been there already. Except without the bottles - that's for girls. But I did put my cigarette out so I guess I'm a bit of a wimp.
The injectors are atomizing but it's not brilliant. And they're not dribbling either. It'll be something simple...
I'll work on it over the weekend and report back on my disappointment on Monday.
Cheers
Alan |
Posted: Sat Oct 14, 2006 2:33 am Post subject: |
| alanf_uk2002 wrote: | | the control plunger moves up and down real sweet |
If it's moving too easily with the system pressurized (fuel pumps currently or recently running), that's a sign of a lack of control pressure (brings us back to the CIS tester) - if your new WUR is good, that leaves you with the possibility of a problem with the hot start solenoid as was mentioned. If you can't get a CIS tester, is there a way to take this hot start solenoid contraption out of the system for a test?
Of course if it's way rich you should be seeing black smoke out the exhaust - have someone drive behind you to check.. _________________ "..it's made in Germany. You know the Germans always make good stuff."
alanf_uk2002
Posted: Sat Oct 14, 2006 3:35 pm Post subject: |
Hi Smoothie
Interesting comment. When the system pressurised, you can move the plunger easily - just how much resistance would you expect?
There's no guarantee the WUR is good as they were both old.
The hot start solenoid can be removed so I could always have a look at this.
As for someone driving behind me....this car can't move it's own weight let alone be propelled along something as daring as a road.
Checked the TDC last night manually with no reference to the flywheel markings. When I got it to where I thought it was, I checked the flywheel and it was spot on - which was a bit of a fluke because you've only got to move the crank pulley a touch and the markings have disappeared!
The cam timing mark seems to be right too. With the mark lined up, the first lobe is on the left (10 o clock) which would give the piston time to travel down on the power stroke before opening the exhaust valve.
The hunt goes on.
Alan |
TonyBray
Posted: Tue Oct 17, 2006 11:45 pm Post subject: |
Alan,
You said: "The injectors are atomizing but it's not brilliant". I just went through this same situation myself. The car would flood the plugs when I tried to run it with the fuel pump relay in place. It would fire and run for a few seconds without the relay installed. On mine, I could hear the fuel injectors scream when the pressure hit them. Not a click but a high pitched scream. I replaced the 4 injectors and the air meter and it fires up and runs now. Do the test mentioned in the Haynes manual on measuring flow at the injectors. Watch the pattern as well. They should make a barely audible clicking when it runs.
BTW, I had very little resistance on the air meter. The secondhand unit I installed has some resistance. Have someone crank the car over with the throttle closed and watch and see how much movement you get on the air meter. Mine would nearly bottom out during cranking. It should only open about 2-4mm if the control pressure is right. From what I understand, it can't be the WUR as it only bleeds off pressure. When it's warmed up, it closes the return fuel which will raise the control pressure. When cold, it allows some fuel to return, lowering control pressure. If the port in the air meter is clogged, or the pressure adjuster is set wrong, then no pressure gets out to the WUR or even into the control pressure circuit.
--Tony _________________ 67 912 2.0 Type 4
94 968 Cabriolet
82 924 Turbo |
Posted: Wed Oct 18, 2006 12:07 am Post subject: |
| alanf_uk2002 wrote: | | When the system pressurised, you can move the plunger easily - just how much resistance would you expect? |
The difference between no control pressure and control pressure - with none, you can tap the air metering plate and it will easily swing one way, then back on its' own. With control pressure, it feels like you're pushing against a bit of hydraulic pressure and tapping on the plate doesn't make it swing - it'll stay in contact with your finger as you tap it and the hydraulic pressure will return it. -It might still meet the definition of "moves easily", but doesn't "swing easily". _________________ "..it's made in Germany. You know the Germans always make good stuff."
alanf_uk2002
Posted: Wed Oct 18, 2006 3:02 am Post subject: |
Hi Guys
I've not made much progress due to the fact the damn thing wouldn't start! Turns out that I had a repeat of the same problem that plagued the car about a year ago - the plugs are knackered. That's the second brand spanking new set - and neither have done any mileage!! Basically when they get wet they short out or something and never work again. These certainly didn't.
So a new set of plugs and it strikes up first time, sounding super sweet (for my car anyway). Set the timing to +10. Adjust mixture (by ear - no fancy gimmicks in my garage), adjust idle, and then go for revs.........and same problem.
I've got a lovely set of R1 bike carbs all ready to fit..... it is getting very close to ripping the whole lot out. Fibreglass bonnet and brand new adjustable and lowered front suspension also wait in the wings.
Back to the garage to stare in wonderment at this.....thing
Cheers
Alan |
Posted: Wed Oct 18, 2006 8:11 am Post subject: |
+10 is after TDC. UK cars should be -10 BTDC. _________________ Porsche 924 1984 (UK import) NA
John Brown
Posted: Wed Oct 18, 2006 11:49 am Post subject: |
| Mike924 wrote: | CIS pressure testers are available in the UK - if you don't mind paying £600 for one! On the other hand, they're about $50 in the States... Rip-off Britain! |
Wow. Well, I know this isn't helpful. Other than swap out a bunch of expensive parts it's next to impossible to definitively diagnose CIS without a pressure test setup.
What happens when you buy $150US items for delivery in the UK? Tremendous tarrifs?
I've just begun (my first time actually) to get little things like used micrometers sent UK to US and was surprised that it apprently comes trouble free. And quick too. And not horribly expensive. _________________ John
80 931 - #931 44Cup
99 Escalade - tows track cars
gone but not forgotten: original 924.org car - 82 |
alanf_uk2002
Posted: Wed Oct 18, 2006 4:33 pm Post subject: |
The amount of time I've spent on this thing and I can assure you that +10 comes before 0 on the flywheel, therefore +10 is BTDC. If you add 10 on to the 0 on the flywheel it will reach that point first i.e. before top dead.
Alan |
Posted: Wed Oct 18, 2006 4:59 pm Post subject: |
As long as the 10 reaches the window before 0 TDC.
This is a turbo flywheel. if you take Z1 as zero and the -10 is similar to the mark where I tune mine. _________________ Porsche 924 1984 (UK import) NA
seanski44
Joined: 13 Mar 2006 Posts: 532 Location: Nottingham UK
Posted: Wed Oct 18, 2006 5:45 pm Post subject: |
other poss is that its running on WarmUp due to bad earths - though did you check these when you replaced the WUR etc? - my car had the bogging down thing, but only once warmed up and it was that it was running on choke and massively overfuelling.
otherwise, silly question on the timing but couldn't be 180deg out could it?
where in the UK are you? _________________ 1998 BMW Z3 2.8 arctic silver & red
1981 168HP 931 S2 blue/tan leather - SOLD
1985 121HP 924 2.0l na modded - SOLD!
1992 968 lux SOLD
1989 944 2.7 lux SOLD |
Posted: Wed Oct 18, 2006 6:17 pm Post subject: |
You may have the same problem that i had a while ago. Check the marking on the flywheel, there are actually two of them,one on each side!!
If somebody fooled around with it your timing will never be allright.
See ya on the Autobahn.  |
alanf_uk2002
Posted: Wed Oct 18, 2006 7:13 pm Post subject: |
Hi Ozzie
The turbo thing looks like a different beast altogether. But thanks for the offer of advice - I'll consider anything at the moment.
Seanski
I've got earths running all over the place - just in case. I'm thinking it's something to do with control pressures and possibly the WUR or dirt in the system?
I'm all the way over in sunny Burton on Trent. Or rather overcast as it is today. I have had the timing running off number 4 cylinder and it still does the same thing (as you would expect). I've had the timing all over the place just in case it ran better but I've put it back to standard at the moment. Strikes up first time and sounds fine on idle albeit a bit lumpy.
The one thing I haven't mentioned is the fuel pump relay clicks continuously. Not sure if this is related to the problem as I have had a jumper wire in there and it still did the same thing.
Alan |
seanski44
Posted: Wed Oct 18, 2006 8:14 pm Post subject: |
| alanf_uk2002 wrote: | ...
Alan |
Hmm, might be, but when troubleshooting my bad earth prob I jumpered the FPR and it made no difference either. Though the FPR does control some of the cold start gear as well, but I'm no expert on that.
I also have to confess at this point that I gave in with mine, the actual diagnosis was made by the Nottingham Injection and Carburettor centre, my local Bosch specialist. They tested the Volts at the WUR I think.
The other important difference is that my car only ran badly when warmed up, when cold it ran fine. This could be important! _________________ 1998 BMW Z3 2.8 arctic silver & red
1992 968 lux SOLD
Posted: Wed Oct 18, 2006 9:46 pm Post subject: |
I dont have a pic of the NA flywheel but the 10 degree mark is on the same side from zero as the one on the turbo from Z1.
The NA flywheel has a 10 degree mark on the other side as well and is ATDC as Nobbi said.
I have also heard of flywheels being put on wrong but the valve timing would also be way out if that was the case. _________________ Porsche 924 1984 (UK import) NA
