Putty Froze
JB 924
PostPosted: Sun Nov 05, 2006 7:11 am    Post subject: Putty Froze Reply with quote
I bought some body putty, but left it in the car over night and temps went below 0 Celsius. Can I still use it? I don't see why not since sooner or later it will have to withstand these temperatures, but it was still unused and not mixed with hardener.
Thanks,
JB
dan476
PostPosted: Sun Nov 05, 2006 7:38 am    Post subject: Reply with quote
should be fine, what does it say for storing temperatures on the can?
PostPosted: Sun Nov 05, 2006 7:46 am    Post subject: Reply with quote
dan...dude...could you please size down your avatar ? it makes the forum look stupid.
dan476
PostPosted: Sun Nov 05, 2006 7:58 am    Post subject: Reply with quote
man relax, you seem to be the only one that has a problem with my avatar, don't worry about it. This forum is not for looks, its for useful information that everyone passes onto everyone else.
Dan
Desolation
PostPosted: Sun Nov 05, 2006 8:02 am    Post subject: Reply with quote
I also have problem with its gigantor hugeness, quite annoying imo. But to stay on topic I wouldn't see why you couldn't use it.
1977 924 - sold
1989 Mustang
My MySpace ^_^
JB 924
PostPosted: Sun Nov 05, 2006 8:12 am    Post subject: Reply with quote
Thanks guys. It doesn't say anything about storing temps, so I thought it should be fine.
teo
PostPosted: Sun Nov 05, 2006 8:15 am    Post subject: Reply with quote
Ok, than reconsider it.
dan476
PostPosted: Sun Nov 05, 2006 11:06 am    Post subject: Reply with quote
alright i resized it, but it ain't gonna get any smaller
Dan
koolkarateguy
PostPosted: Sun Nov 05, 2006 12:35 pm    Post subject: Reply with quote
I like it
1979 N/A 924
PostPosted: Sun Nov 05, 2006 1:01 pm    Post subject: Reply with quote
The avitar makes me hard. I
like it.
JB 924
PostPosted: Sun Nov 05, 2006 2:27 pm    Post subject: Reply with quote
Okay, each door has a dent in it. They are not too deep, but cover a large area. I have applied some filler to one of them, so it's perfeclty smooth, but then I saw a little crack at the edge. I took a blade and chipped off the bondo around 2-3 inches around it. The filler is around 2-3mm thick. I've hit the area that was filled with my fist, and there are no more cracks. Should I take all of the bondo off, and fiberglass it, or go over it again with bondo? I'd rather not have it crack later on.
JB 924
PostPosted: Sun Nov 05, 2006 2:39 pm    Post subject: Reply with quote
Or should I take it all off, and hammer it out as much as I can. The reason why I didn't is because it didn't look too deep of a dent before, but I guess I might do that.
PostPosted: Sun Nov 05, 2006 5:34 pm    Post subject: Reply with quote
Bondos strong though idf theres flaky paint it ll
crack later maybe as the bondos not very thick..
I like a light weight polyester filler called easy sand ..it
can be found at auto paint stores or on the net.
PostPosted: Sun Nov 05, 2006 6:52 pm    Post subject: Reply with quote
If you're concerned about cracking, use short strand reinforced fiberglass body filler. I just went through 1.25 gallons of the stuff fixing my car. Didn't use any of the non-reinforced stuff. Short strand goes on just about as easily as non-reinforced - you can't even see the fiberglass in it. It's about twice as much, but that only makes it ~$30/gal vs. ~$15. In addition to being stronger, it's waterproof. Evercoat's "Everglass" is short strand fiberglass and Kevlar reinforced.
I would remove all the old stuff both to be sure there isn't any rust hiding underneath and to straighten the panel more if needed.
PostPosted: Mon Nov 06, 2006 3:01 am    Post subject: Reply with quote
Makes one proud to be a Canadian!!!
