OP Sender Readings. . .HELP?!?
PostPosted: Fri Dec 29, 2006 3:49 am    Post subject: OP Sender Readings. . .HELP?!? Reply with quote
Anyone know the correct resistance for the OP sender when no pressure is present (ie, what resistance makes gauge read "0")?
Also, is it a mistake to use thread sealer on the sender (for grounding purposes)?
TIA
rasta
PostPosted: Thu Jan 04, 2007 12:55 am    Post subject: Reply with quote
I know someone knows the answer to this. . .
PostPosted: Thu Jan 04, 2007 5:19 am    Post subject: Reply with quote
infinite (open circuit) will cause it to read 0.
PostPosted: Thu Jan 04, 2007 5:22 am    Post subject: Reply with quote
So that means, disconnected should read zero, right? So, if the gauge is pegged when disconnected at the sender, I have a short in the sender wire?
Thanks, V
PostPosted: Thu Jan 04, 2007 7:09 am    Post subject: Reply with quote
Exactly!
PostPosted: Thu Jan 04, 2007 7:29 am    Post subject: Reply with quote
So, seems like I should just rewire it with a fresh length of wire doesn't it?
931Tony
PostPosted: Mon Jan 22, 2007 6:36 pm    Post subject: Reply with quote
You're right on not using any sort of thread sealer on the OP sender. Almost all single wire sender/sensors ground through the block, so you might check that too. G'luck!
