Control Arm Bushings
isuras2
PostPosted: Fri Mar 30, 2007 3:15 am    Post subject: Control Arm Bushings Reply with quote
I have gotten the front bushings out of the control arms, but am having trouble getting the rear bushing off. Does the bushing have metal that goes around the control arm, kind of like a metal sleeve?
Thanks,
Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew
-nick
PostPosted: Fri Mar 30, 2007 5:14 am    Post subject: Reply with quote
I just went through this. I had a shop press them on/off and they said it was a pain -
http://www.924board.org/viewtopic.php?t=15903&highlight=control+arm
1980 931S
1991 964 C4 Cabriolet
isuras2
PostPosted: Fri Mar 30, 2007 6:43 am    Post subject: Reply with quote
I saw that post while searching. I wonder if a bearing puller would do it...I'll find out this weekend.
Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew
PostPosted: Fri Mar 30, 2007 10:32 pm    Post subject: Reply with quote
I've used a geear splitter to grab the inner metal sleeve and then a hyd. press to push the arm out.
isuras2
PostPosted: Sat Mar 31, 2007 1:14 am    Post subject: Reply with quote
I tried a gear puller and just bent the metal, while pushing the control arm. The metal sleeve seems to be rusted/corroded onto the control arm rod. I'll keep working on it though.
Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew
PostPosted: Sat Mar 31, 2007 1:22 am    Post subject: Reply with quote
Yeah; depending on condition it may come off in more than one piece!
isuras2
PostPosted: Tue Apr 03, 2007 11:32 am    Post subject: Reply with quote
I used a grinder with cut-off wheel to cut through the metal sleeve. Then I used a screw driver to get the sleeve off. I only made very minor scratches on the post. Now if I can only get the rivets off for the ball joint...
Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew
leadfoot
PostPosted: Tue Apr 03, 2007 4:55 pm    Post subject: Reply with quote
drill them out, first with a 2mm pilot bit then the rest with a 5mm bit IIRC... the head should just pop off when you get the right size bit...
Make sure you center the pilot bit well, the rivot are quite hard metal too.
Leadfoot
1981 ROW 924 Turbo -
carbon fiber GT mish mash
LS1 conversion in progress...
PostPosted: Tue Apr 03, 2007 9:53 pm    Post subject: Reply with quote
I usually use an air chisel on the rivets, easy to pop the heads off, just be careful to not damage the arm.
