GRATIAN Guest
Posted: Fri May 31, 2002 3:43 am Post subject: |
| I clean up my injectors and put back on the engine.How can i fill the entire fuel line whith fuel to start the car.I know that fuel pump will start only when engine begin to rotate itself. |
Paul Guest
Posted: Fri May 31, 2002 12:09 pm Post subject: |
| Just crank it until it starts, the system will fill itself very quickly. |
gohim Guest
Posted: Fri May 31, 2002 12:10 pm Post subject: |
The fuel pump will run when the key is in the "start" position, regardless of whether the engine is running or not.
When the key is in the "run" position, the fuel pump will only run when the engine is running. |
Lizard Guest
Posted: Sat Jun 01, 2002 11:37 pm Post subject: |
| while the injector is out and you are spraying fuel light a smoke kaboom |
GRATIAN Guest
Posted: Sun Jun 02, 2002 6:37 pm Post subject: |
| Hey Lizard I will make that if you come and take the injector in hand. |
Lizard Guest
Posted: Sun Jun 02, 2002 11:14 pm Post subject: |
ok can i point the injector at someone though, haha
[ This Message was edited by: Lizard on 2002-06-02 23:14 ] |
