Front sway bar
PORSCHEV
PostPosted: Sun Aug 12, 2007 5:46 am    Post subject: Front sway bar Reply with quote
I just got this off ebay with plans to "upgrade" my front sway bar on the 924.
This was from a 944 which I understood was a direct bolt on. Regardless it is no bigger in diameter and does not look like it would ever fit a 924.
Here's a picture...you guys set me straight would ya
1978-#53 "D" track racer.
PostPosted: Sun Aug 12, 2007 6:24 am    Post subject: Reply with quote
That does look like a 944 bar, but it would only be a direct bolt-on for late '82-up 924,931,944,etc. You'd need the later mounting hardware that goes with it to use it + would need to provide at least one more threaded hole on each side of the frame to fit the inboard drop-links + have to drill the a-arms to fit the end mounts (which attach directly to the undersides of the a-arms). Then when you're done, your old ptotection plate (aka- "belly pan") wouldn't fit back on, so you'd need a later belly pan if that's important to you.
The late '82-up 924-931-944 bar and mountings -
The earlier bar and it's mounts which you already have -
Notice your current bar mounts higher-up and uses long end-links to attach to the a-arms.
The 944 bar mounts lower-down with long inboard mounts and the ends attach to the bottoms of the a-arms..
PORSCHEV
PostPosted: Sun Aug 12, 2007 8:25 am    Post subject: Reply with quote
Wonderful ...you'll soon see this in the for sale section!
Thanks for the explanation Smoothie!
-nick
PostPosted: Sun Aug 12, 2007 8:41 am    Post subject: Reply with quote
Yep, you could still switch to it with Smoothie's directions. There are factory 944/968 front bars up to 30mm I believe. The largest 924/early front bar is 23mm.
1980 931S
1991 964 C4 Cabriolet
PORSCHEV
PostPosted: Sun Aug 12, 2007 10:06 am    Post subject: Reply with quote
This one is only a 26 mm so hardly worth the effort to change it. I am planing to run in the modified class next year so I will be able to run some heavier gear then was available stock. Anyone want this thing for $10.00..thats what I paid.
Vince Ponz
PostPosted: Mon Aug 13, 2007 12:20 am    Post subject: Reply with quote
I have one that size on the 77.5. Not a problem at all. I welded on the straps and bolted the sway bar on and the ends fit perfectly too.
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock
Eturbo924
PostPosted: Mon Aug 13, 2007 10:15 am    Post subject: Reply with quote
Yeah that does not look like a 944 bar.
I have a 944 sport suspension bar for sale. It is much larger in diameter than that one. I have all the drop links with it. The thing I would note... and maybe it was above and I missed it... is that the mounts to the control arms are also different and I do not think the 924 arms would work. I do have a set of the 944 control arms to also go with the bar if interested.
One of the control arms would need a new ball joint. I manged to wreck the boot when trying to sepperate it from the suspension and brakes.
Eric
eturbo924@yahoo.com
1992 968
2003 C4S
E-mail me for parts you need!
Drive Fast!
hawkman
PostPosted: Wed Aug 15, 2007 6:29 am    Post subject: Reply with quote
might want to look at a larger diameter sway bar and then switch it out.
'81 924 n/a "The Baby" Modified!!!!!
'93 3000GT VR4 "Un-Touchable"
