Neil924
Posted: Mon Sep 10, 2007 5:23 am Post subject: On a hoist, is there anything to be careful of? |
Where should the 4 pads rest on the underside of the car?
Thanks.
I know about the jacking points but I think the hoist pads are larger and will hold all of the weight of the car. |
endwrench
Posted: Mon Sep 10, 2007 5:47 am Post subject: |
It is usually best to lift at the body pinch points along the edge if possible. Most hoist have arms too long to do this so I usually place the front ones under those two unibody "frame rails" near the tunnel and the rear ones under the lowest point of the torsion tube. Hard to explain without a picture. Just don't lift off the belly pan or any moving suspension parts.
Posted: Mon Sep 10, 2007 6:30 am Post subject: |
| Quote: | | two unibody "frame rails" near the tunnel and the rear ones under the lowest point of the torsion tube |
+1 _________________ erstwhile owner of just about every 924 variant ever made |
PORSCHEV
Posted: Mon Sep 10, 2007 6:47 am Post subject: |
I like to use 2 points on the front. The pivot point for the rear mounting part on the control arms and on the rear I like the rear suspension mount points. They are meant to carry the weight of the car already. _________________ 1976 924
1978-#53 "D" track racer. |
Posted: Mon Sep 10, 2007 8:24 am Post subject: |
Whatever you do, do not place the hoist lift pads under the shock mounting cups/points on the trailing arms. What will happen is that you will crack and break the shock mounting cups off the trailing arms, requiring replacement of the trailing arms.
I have had the idiots at two different tire shops cause this disaster when having my tires replaced at different times.
Needless to say, I always stand right there now, and make sure that the guy lifting the car is placing the hoist pads in places that I direct they be placed. |
Neil924
Posted: Mon Sep 10, 2007 11:26 am Post subject: |
| gohim wrote: | Whatever you do, do not place the hoist lift pads under the shock mounting cups/points on the trailing arms. What will happen is that you will crack and break the shock mounting cups off the trailing arms, requiring replacement of the trailing arms.
That's one way to get free trailing arms though it may not be the easiest way of replacing them! |
