speedyts49
Posted: Sat Nov 24, 2007 5:54 am Post subject: gear shift can be moved left and right when in gear? |
Just happened.
When in first or any other gear I can move the shift lever left or right as you would when going from 2nd to 3rd.
I can still go through the gears but this is a little scary.
Any ides what might of come loose before I go digging around? |
Joined: 29 Jul 2001 Posts: 9117 Location: Royal Oak, MI, USA
Posted: Sat Nov 24, 2007 8:57 am Post subject: |
Usually due to the shift lever being worn out; replacement is about $45. _________________ Vaughan Scott
Hoboceratops
Posted: Mon Nov 26, 2007 3:23 am Post subject: |
Yeah, had the same deal in my car. Replaced the shift lever (quick and simple) and that just about murdered the problem. You may have a bit of slop left over afterwards, but it won't be anywhere near as bad, and fixing that (at the transmission) is just a pain in the ass. _________________ 1987 924S: Very much in love with it, even if it's all finnicky |
joecitizennn
Posted: Mon Nov 26, 2007 8:30 am Post subject: |
You can fix your existing lever. Tap it and run a bolt through it. That is what I did and it was absolutely reliable. Do a search. I think it might be in the how to. I know it has been discussed somewhere in this forum. _________________ 87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
89 turbo S LSD, ABS etc
86 951 white rocket
85 944 sport everything.
84 944 sold.
87 944 sold |
speedyts49
Posted: Mon Nov 26, 2007 10:01 am Post subject: |
| joecitizennn wrote: | | You can fix your existing lever. Tap it and run a bolt through it. That is what I did and it was absolutely reliable. Do a search. I think it might be in the how to. I know it has been discussed somewhere in this forum. |
It looks like there is a bolt that goes through a clearance hole. I assume that is the hole that needs to be threaded. I'll search the forum to see if I can find the fix.
thanks |
joecitizennn
Posted: Mon Nov 26, 2007 10:42 am Post subject: |
Here. I made you a picture.
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
86 951 white rocket
84 944 sold.
87 944 sold |
speedyts49
Posted: Mon Nov 26, 2007 11:06 am Post subject: |
Excellent!
I can do that now that I see how it is done.
thanks! |
johnathan1
Posted: Mon Nov 26, 2007 12:11 pm Post subject: |
Wow, I guess I'm lucky that my shift lever is super tight still!  _________________ -1977 924, 4-Spd...Gone
-1987 Toyota Supra Turbo, Pearl White, BPU, 300RWHP @ 10psi.
-1989 Mercedes-Benz 300SEL
WARNING: MAY CONTAIN TRACES OF AUDI OR VW! |
