Is someone driving a 924 on LPG or gas?
Goto page Previous  1, 2, 3, 4  Next
PostPosted: Sun Dec 16, 2007 5:09 am    Post subject: Reply with quote
Bravo Khal!
Nice find,i am sure you safed that one for a rainy day!
I am ready for a Warsteiner, see ya tomorrow mate!
miniver
PostPosted: Mon Dec 17, 2007 2:02 am    Post subject: Reply with quote
Hi everyone - my first post on this forum, so hi...
LPG is very popular here in Poland because it's half the price of petrol. Some people have it in their 924's - apparently the K-Jetronic works fine with LPG. As for the effect on the engine - if it's the right system and it's properly installed, it should not be harmful to the engine. LPG is not right for racing, though.
But as someone said before: "it just doesn't feel right" to have a sports car like the 924 run on LPG. My 924 is very economical with petrol anyway - there's always something wrong with it and most of the time I can't drive it so I don't spend much on petrol...
PostPosted: Mon Dec 17, 2007 6:24 am    Post subject: Reply with quote
miniver,
here in germany a lot of people driving to poland for the lpg installation,cause it much cheaper!? Do you now approx. prices?
PostPosted: Mon Dec 17, 2007 8:29 am    Post subject: Reply with quote
hahaha nice one. well..yea...i dont drive the 924 much because the city is under heavy road reconstruction and it eats ALOT of gas its by far the most non economical car i have ever driven. if i give it some stick...it drinks 35 liters in 100 Km....yea..its worth it when you have the money and the roads....not my case
miniver
PostPosted: Mon Dec 17, 2007 9:17 am    Post subject: Reply with quote
Nobbi wrote:
miniver,
Didn't realise that... I've never had an LPG system in any of my cars, but looking at the website of one of the most reputable (=expensive) specialists in the region, the simplest carburettor system costs about 390 EUR, injection systems are between 420 EUR and 530 EUR. Sequential gas injection systems are about 890 EUR. As I said, that's 4-cylinder engines at a rather expensive company.
Hope this is helpful.
PostPosted: Mon Dec 17, 2007 9:26 pm    Post subject: Reply with quote
danke !
sleepy
PostPosted: Wed Dec 19, 2007 8:33 am    Post subject: Reply with quote
i'v a laguna with an lpg system done in poland. it's got a burnt exhaust valve now because lpg burns so hot & i'm looking for another engine because its cheaper than having the head removed, skimmed, new bits etc .
lpg may be half the price of petrol but you loose 15% power & fuel efficiency. You need to do a lot of miles to make lpg pay off. & if ur unlucky enough to something go wrong its not a cheap thing to have serviced.
meteor silver 1981 924 lux. -UK
Martijnus
PostPosted: Wed Dec 19, 2007 8:41 am    Post subject: Reply with quote
Most of the heads I get at my work (rebuilding shop) are LPG heads.
valve seats which are, how do you call it... anyway...they got some sort of edge because the valve is slammed to the seat, which makes the valve go deeper into the head, which decreases the valve clearance which causes burnt valves.
yeah that's how it works.
I've put (=am still putting) a lot of money in my MS system, but suddenly LPG still seems a nice option (overhere, you pay more taxes with LPG, but since my 924 is a classic, I don't pay nothing (ok... I don't pay anything... just want to sound black).
So, all my costs stay the same, but my fuelcosts will be 1/3 of the normal (cuz I need 98 RON).
Turns out LPG has a higher octane level, which is nice with my raised compression.
Let's say I can build LPG in for 1000 eur. Fuelprice is 1,50 eur/litre. Let's say the porsche does 1 liter on 15km (if I'm very lucky).
That means every km costs 10ct. With LPG the consumption is higher. Let's say it does half...60ct for a litre LPG, 8km on a litre = 7,5ct/litre.
Saves 2,5ct /km. On 10000km a year thats 250 eur. I need 40000km to get my investment back, but in 40000km my engine has suffered from the gas.
Conclusion... probably not I'll calculate again... I should save more than 2,5ct/km.
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
PostPosted: Wed Dec 19, 2007 5:25 pm    Post subject: Reply with quote
Does Magasquirt have an LPG setting, Martijnus?
Martijnus
PostPosted: Mon Feb 25, 2008 9:09 am    Post subject: Reply with quote
I guess it has... some guy I know has a beretta that runs on LPG and MS...
I've been thinking....and I'm probably going to convert to LPG the euro 98 fuel is way too expensive... and since LPG has a higher octane level I guess my engine could run better on lpg.
The liquid petrol injection LPI appears to have almost as much power as regular gasoline and can be controlled with ms.
I've estimated the price for conversion parts at 500eur which means that in 5000km I've earned my money back. The problem is that my car papers have to be adjusted to mention the LPG... that means I have to use qualified parts which are expensive... but it can all be done... if i don't buy everything new...
first I'll let it run on normal fuel... for the break in period.
PostPosted: Mon Feb 25, 2008 9:18 am    Post subject: Reply with quote
Over here we have ethanol, E85 everywhere. I know a guy who adjusted his kjet and it worked fine. Its an option, but i dont know how much e85 tou have down there in germany..
Rich H
PostPosted: Mon Feb 25, 2008 9:36 am    Post subject: Reply with quote
MS does not have a setting as such, its totally flexible, you can specify everything you want! This can be done by setting 2 maps and switching between them LPG/petrol. It should be easy enough to get a map sorted, the higher octane will mean you can run a lot more advance. Stoich for LPG is 15.5:1 so you will need to run a bit richer, but not a lot (Petrol is 14.7:1) More advance will mean a bit more power so you will probably achieve the same economy.
R
Martijnus
PostPosted: Mon Feb 25, 2008 10:05 am    Post subject: Reply with quote
R
that's the fun MS just needs a switch and there's my LPG map... switching the injectors isn't a problem too...
In theory I could use my petrol table and just modify the multiplier-value in the equasion... but afaik that's not doable in MS and multiplying the values in the second table does the same... and is finetunable
we'll see...I'm not in a hurry, but when my car runs, this is high on my list
isuras2
PostPosted: Mon Feb 25, 2008 10:56 am    Post subject: Reply with quote
I don't know about the 924, but my father has a Chevrolet 1978/1979 pickup truck that runs on propane. In the US, it used to be about half of gasoline, but now it is about the same. The engine is carbureted and has a few extra things, but runs better on LPG. The first engine would still be there, but apparently they don't like to go about 80 mph in 2nd gear (truck has 3 gears) and the engine overheated. LPG burns cleaner than gasoline. The truck has both gasoline and LPG with some wiring to a 3 way switch. I would be a little hesitant with ethanol due to its corrosive properties when it is in plastics, which my 924 has.
Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew
Rich H
PostPosted: Mon Feb 25, 2008 5:57 pm    Post subject: Reply with quote
I'm interested again as I'm looking at ITBs which have injector ports but my fuel rail is bolted to the head and using the original injector ports, so a second set of injectors could be fitted easily. Will an normal petrol injector work with vapourised LPG or is that silly?
Page 2 of 4
