'83 924 N/A got turbo (Updated pics on page 12)
Goto page Previous  1, 2, 3 ... 7, 8, 9 ... 11, 12, 13  Next
PostPosted: Fri Mar 21, 2008 1:38 am    Post subject: Reply with quote
ignorantporscheowner wrote:
i wanted to do this because of insurance reasons
You should check on that. . .I looked it up for mine, and found the 931 was less than $20 more per year than an NA.
924inMN
PostPosted: Tue Mar 25, 2008 5:14 pm    Post subject: Reply with quote
First off I would like to say that this thread has been interesting and very helpful. I've been milling around on 924board for a while and decided to finally post. I've got a '79 Stock 924, with 55,000 miles. My plan is to try to throw a turbo in it, and I'm going to try to copy as best I can the work of Raceboy and 71vdubturbo. Awesome posts by the way. I'd like to try a used Garrett t2/25 at 7psi(ebay about 200$), with the stock CIS if possible, and pretty much the same set up as raceboy or vdub as fars as tubing and routing. I have access to a cnc plasma, tig, mandrel and all that good stuff so I'm not really worried about the actual fabrication part. I'm not sure if I should water cool the Garrett or if thats even a good turbo choice for a 924 N/A? Also, I'm sure this a rookie question but where does the oil feed to the turbo from? Is an intercooler necessary for a mild upgrade? If I could get to 150rwhp I would be thrilled. Is there any science to richening the fuel mixture in the stock cis? How do I know how much to advance/retard the timing without a dyno? One final one, do I need to replace any vacuum lines with an electrical pump or other source? I haven't really started yet but spring is about here and I'm trying to from a loose plan and learn as much as I can before I start. I'll definitely check through all the other posts here but this one really rocks and it would be cool if everybody kept updating. Appreciate any answers, concerns,wisdom that you guys can give me. Thanks, I'll take some pictures once it gets a little warmer up here in MN.
PostPosted: Tue Mar 25, 2008 10:42 pm    Post subject: Reply with quote
Welcome to the board! Where are you in MN? You should hook up with Applebit. He's having a firesale up north of the Twin Cities and might have some useful stuff for you.
This diagram depicts the oil cooler lines for the stock 931 K26 unit. The feed line comes off of the top of the filter adapter, and there were three different drain lines that evolved, which plumb into the second (higher) plug on the back side of the oil pan (above the oil drain plug).
Depends what you mean by mild and it depends on what CR you plan to run. For stock 931 pistons (7.5:1 or 8.0:1 CR) conventional wisdom seems to be that one can safely run at "euro" levels of boost (~10psi) without too much concern for intercooling. Of course, thermal management is the name of the game for any forced induction application, so there is typically significant benefit to intercooling if you can achieve 70% or better effeciency on your IC setup.
Yes. Contrary to what the EFI bigots will tell you, there are a range of options for improving CIS fueling. They including simple things like shimming the springs, to more sophisticated setups such as adding add'l CIS fuel distributors, adding a secondary fuel circuit with a rising rate FPR and add'l injectors, adding a water/methanol injection system, etc. You might be interested in the recent thread on a digital replacement for the stock WUR (warm up regulator, aka control pressure regulator). Converting to EFI is by far the best approach for proper engine management, with Megasquirt being a popular choice due to its ability to integrate other engine management functions.
Dyno is best but crude tuning could probably be accomplished with a gas analyzer and a wide-band O2 setup.
To my knowledge, no, as long as you tap into sources of manifold vacuum you shouldn't need to supplement it. But you would be better served to get answers directly from someone who has converted an NA motor to a forced induction setup to see how they accommodated vacuum signal requirements.
Again, welcome, and good luck. Seems like you've used the search feature already, so continue to do so and I'm sure you'll find a wealth of info to point you in the right direction.
Min
PostPosted: Tue Mar 25, 2008 11:22 pm    Post subject: Reply with quote
There you go insulting me again. Your post certainly could have done without this part. I'm not intolerant of other fuel management idea's, I just don't think you should be suggesting vague/incomplete ones to new board members. Feel free to blow up your own projects. Suggesting that others blow up theirs is pretty irresponsible.
Megasquirt is a good choice because of its DIY aspect, its inexpensive, has alot of nice features. And most of all has broad support at the megasquirt forums. Putting EFI on your motor is the easy part. Understanding what your motor needs to make it run well is the tougher part.
924inMN: get a wideband oxygen sensor they are important for any non stock turbocharger application in my opinion, and read maximum boost by corky bell. It should give you a wide variety of idea's for how to deal with your turbocharger setup.
Min
PostPosted: Tue Mar 25, 2008 11:50 pm    Post subject: Reply with quote
I never said "Hey look! Min is an EFI bigot!". If you assume the mantle, that's your problem, not mine. Quit being so damn sensitive and immature. It's the height of conceit to assume that everything written on this board is about you. There are plenty of EFI bigots to go around. I wasn't referring to any one single individual, just the general attitude.
I will NOT retract what I said. Furthermore, as I have pointed out on many many occasions, examples abound of people that have added fuel enrichment to their cars and SURPRISE! not blown them up. What I am suggesting is not irresponsible. I provided a direct and sensible answer to the question based on the facts as I have uncovered and understood them. You are free to disagree, and I have no problem with people disagreeing. But this ego-maniacal insistence that everything I write is an personal attack on you is utterly ridiculous. Grow up.
Min
PostPosted: Wed Mar 26, 2008 12:28 am    Post subject: Reply with quote
All I have to do is read through your previous postings on this forum to know your referring to me. Hardly a big leap, who else do you argue with regarding EFI constantly? ...... you talk about maturity, yet throw out potshots (even if they aren't directed at me as you claim) in a otherwise very informative thread. Why not just .... stop?
Min
PostPosted: Wed Mar 26, 2008 12:39 am    Post subject: Reply with quote
A. I never started
B. You should follow your own advice
Min
PostPosted: Wed Mar 26, 2008 12:43 am    Post subject: Reply with quote
A. I never started
A. Which time? ....... The moment you start getting into a 'he started it' conversation you may as well turn into a 5 year old.
B. If you think I'm going to let you give out bad advice without saying anything, and then not respond when you insult me. Your sorely mistaken.
Min
Min
PostPosted: Wed Mar 26, 2008 12:47 am    Post subject: Reply with quote
I won't be responding in this thread anymore, rather not take it anymore off-topic than we already have.
Min
PostPosted: Wed Mar 26, 2008 1:05 am    Post subject: Reply with quote
Once again, a big "WHATEVER" to everything you just said. For crying out loud, I HAVE NOTHING AGAINST YOU other than your ego-maniacal insistence that any post I make about fuel delivery is a targeted attack against you.
And for the record, I DIDN'T GIVE OUT ANY ADVICE. I suggested that there are a variety of proven alternatives for modifying stock CIS. ANYONE who doubts this should go cruise around the 928 circles for a while. There are PLENTY of guys there who have modified the stock CIS using exactly the techniques I've described. In fact, a good place to start is with David Lloyd, president of the 928 Owner's Club, and part-owner of Musante Motorsports. Also, a little bit more research into the 924 GTR that surfaced on Rennlist about a year ago reveals yet another example of successful modification to stock 924 CIS without requiring a secondary fuel dizzy or a 928 fuel dizzy.
Bottom line: there are ways CIS can be modified without endangering your motor. EFI is probably the best way, but not the only way. And furthermore, even on modern EFI systems, where it is undesirable (for whatever reason) to replace the injectors and where injector flow is a limitation, rising rate FPRs are an accepted method of supplementing fuel flow.
How any of that can be construed as "bad advice" is beyond me. I'm simply pointing out alternatives.
Min
PostPosted: Wed Mar 26, 2008 1:27 am    Post subject: Reply with quote
Then by all means, post it. This is valuable information, lets see how its done? You've been surfing the 928 scene for a long time, post some links? no reason this can't become a meaningful discussion.
I agree, I just disagree with the particular method you were posting. I'd like to see a implementation of that method. And talk about how people are metering the extra fuel sprayed by the additional circuit. Its entirely possible I was wrong, and I have no problem admitting that.
and I'm simply asking for elaboration. EFI may be best, but as you've already mentioned, it requires alot of work, quite a bit of money (though we disagree on the amounts) and a whole lot of learning that many people may not be up to doing.
something we haven't talked about much is using megasquirt as a piggyback system instead of a full EFI solution. You could setup a couple extra injectors, and use megasquirt to tune the extra flow when the boost hits. Might be a less costly solution.
Min
PostPosted: Wed Mar 26, 2008 1:50 am    Post subject: Reply with quote
I'll work on digging up some references. I have a bookmark file that is pages and pages and pages. Give me a few hours and I will post back.
924inMN
PostPosted: Wed Mar 26, 2008 2:54 am    Post subject: Reply with quote
Thanks. I need to read up more on this whole thing, I'll check out a few books. I am also going to look into megasquirt. Vdubturbo wrote that he just richened the fuel mixture on the stock cis by adjusting an allen screw. Looking at his photo album, everything appeared to be stock. So can the stock cis and injectors deliver enough fuel for mild forced air? Is the stock ignition workable? And finally, do I have to estimate timing settings before I get to a dyno so it will run w/o damaging the engine? If dyno's the way I'll spring for some dyno time I'm not looking to get as much horsepower as raceboy did, just enough to beet those pesky Acura Integras down the road a bit. Any stock parts on the porsche which will work for turbo I would like to use/modify. Thanks for all the ideas so far. Oh yeah, I live near Minneapolis/St. Paul.
924inMN
PostPosted: Wed Mar 26, 2008 3:00 am    Post subject: Reply with quote
Also, its nice to see people who try to help with N/A to turbo on 924's instead of just telling me to get a 931 or 944. Granted I would love to have either of those cars but I already have a pretty cherry 924 so why not squeeze a little horsepower out of it. Plus the challenge of the project will keep me sane/entertained, like vdubturbo I too get quite bored without a project.
Min
PostPosted: Wed Mar 26, 2008 3:15 am    Post subject: Reply with quote
Maximum boost is a very very good book for this kind of thing.
Stock CIS/injectors are will 'work' for mild forced induction, however there are alot of bae kits out there that make 'how long' the question(meaning, bae kits installed, motors blown up, bae kits sold again). I think with proper monitoring, and maybe some CIS tweaks you could make things work without blowing up. Hoping ideola will provide some better info on what CIS tweaks are availible. Turning the mixture screw does not really change things much overall. Mostly just idle and off idle response(could be wrong here, but I recall a thread detailing just how much it changed the overall fueling curve and it was almost negligible at WOT)
It would probably be ok.
In my opinion, if you install a wideband oxygen sensor, and a TIT gauge(turbo inlet temperature) ... just pay attention and you should be fine. The moment you turn the boost past 6psi or so, the whole ballgame changes completely. I think reading maximum boost will answer a ton of your questions.
Min
Page 8 of 13
