antenna replacement
speedyts49
PostPosted: Wed Apr 09, 2008 11:09 pm    Post subject: antenna replacement Reply with quote
I have a 1987 924S with a snapped off antenna. I do not know if it was manual or not but need to replace it. I don't want a roof mount which are cool, just a simple replacement so I can hear the radio. A short generic style would be perfect.
Do I have to remove the wheel well cover or go from the kick panel or what?
I have searched but have not found how to get to the antenna wiring.
thanks
thirdgenbird
PostPosted: Thu Apr 10, 2008 8:48 am    Post subject: Reply with quote
i need this information as well.
17in caymans, koni yellow coilovers, hypercoil springs, kla solid upper mounts, 968 sway bars, kla drop links, kla strut brace, fidanza flywheel, dansk catback, wilwood front calipers, ss brake lines, e-codes, 944 duckbill, manual rack,momo steering wheel
PostPosted: Thu Apr 10, 2008 9:11 am    Post subject: Reply with quote
My antenna had a 3 pin plug behind the side kick panel on the RHS for the electric aerial and it was just a matter of running the shielded cable to the head unit.
speedyts49
PostPosted: Thu Apr 10, 2008 10:10 am    Post subject: Reply with quote
I picked up a universal but that is not the correct way to do it. Where is the switch for the antenna or is it an automatic when you start the car?
I found my old antenna that had fallen down in the hole and it had a yellow two prong fork looking thing on it for what it's worth.
They sell one on Pelican and I wonder if that would work for my '87
PostPosted: Thu Apr 10, 2008 1:06 pm    Post subject: Reply with quote
Look on eBay. There are OEM Hirschmann antennas on there frequently (power or manual).
PostPosted: Thu Apr 10, 2008 7:38 pm    Post subject: Reply with quote
my new antenna didnt connect to the 3 pin plug so I had to solder them together.
It worked off the stereo and only goes up when switched on.
speedyts49
PostPosted: Thu Apr 10, 2008 11:54 pm    Post subject: Reply with quote
The eBay antennas look good. Now if I can figure out which one I have and how to get to/route the cable I'll be set.
speedyts49
PostPosted: Wed Apr 16, 2008 12:23 pm    Post subject: Reply with quote
I got one of these and it fit pretty good. I can not find where the old cable routes through though. Too bad I can't some how spice the new cable to the old. I am afraid to rip too much apart or I'll be fixing something else.
I tried pushing and pulling the old cable and it will not budge. (insert hair pulling icon here)
PostPosted: Wed Apr 16, 2008 12:33 pm    Post subject: Reply with quote
It should come through the side somewhere - behind the carpet, no? I don't remember exactly where, but look in that area and maybe further forward and up next to and beyond the fuse-relay panel.
speedyts49
PostPosted: Wed Apr 16, 2008 11:34 pm    Post subject: Reply with quote
I ran out of light last evening but will give it another go this afternoon. Although the directions are from the fatherland the little diagram shows the plug going through the wall and then down. It looks like they are saying NOT to go straight/ horizontal to the ground. If this fails I have a German friend and will get the darn instructions briefly translated.
Guess I am going to have to dig a little deeper under the carpet to see if I can find it.
Also I am assuming the cable plugs directly into the radio. Does this sound right?
Mahatma Gadhni
PostPosted: Fri Jan 30, 2009 8:06 am    Post subject: Reply with quote
I apologize for raising this thread from the dead, but I'm in a need of a new antenna. I'd like it to be an original so I was wondering if this Hirschmann antennas are really OEM or just an aftermarket replacement.
My car already came with some crapy replacement one so I've never seen "the real deal"
Does anyone know if Hirschmann is OEM or not?
Thank you!
Dom
1984 924 2.0 NA
PostPosted: Tue Feb 03, 2009 9:16 am    Post subject: Reply with quote
Ya, that's my understaning - that Hirschmann is the OE antenna. I installed one in about '92 when my 931 was new (to me). Never had a problem with it, it still works like new, and the cars' been parked out on the driveway for the past 16 years. -And uncovered for 99.9% of that time.
Mahatma Gadhni
PostPosted: Wed Feb 04, 2009 4:18 am    Post subject: Reply with quote
Vielen Dank!
I was surprised how cheap it was, and I've read somewhere that it's a bit longer compared to ones that came with the car.
I guess I'll get me one now
Cheers!
1984 924 2.0 NA
dash16
PostPosted: Tue Mar 03, 2009 12:33 am    Post subject: Reply with quote
how do you physically remove the antenna from the front fender?
I see a canister-type thing behind the front wheels.
I am hesitant to remove anything unless I have to, so please a little advice =)
1987 Porsche 924S Black/Black. 5-spd.
Options: AFX C79 261 398 423 650 651 657
1987 Mercedes 190E 2.3-16 Cosworth Pearl Black/Black. 5-spd.
STUTTGART PREVAILS
PostPosted: Tue Mar 03, 2009 1:18 am    Post subject: Reply with quote
That's the charcoal canister for the evaporative emissions system. Remove it for access to the antenna - may have to disconnect a hose or two to it in the engine compartment, I don't remember exactly.. Should be a screw or two holding it also. Just look, see, and whatever's required should become obvious.
