Vince Ponz
Posted: Mon Apr 07, 2008 10:56 pm Post subject: Parts for sale |
Euro bumper
Euro pads
Euro fog lights
front fender*
front alum bumper
bumper shocks
brown shade
Hatch from my 924S with wiper*
calipers various
email for others I cannot remember.
three 16 in Boxster rims in perfect order never used but are dealer takeoffs 1 front and two rears I think they are 6 & 7s and look grear on the car.......may be spoken for
* pick up only _________________ "Never let them see you sweat"
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock |
thirdgenbird
Joined: 29 Feb 2008 Posts: 367 Location: Pella, IA USA
Posted: Thu Apr 10, 2008 8:32 am Post subject: |
will the euro pads work with my US bumper or do i need to convert to the new bumper as well, im wanting to run a replica german front tag on the car... _________________ 17in caymans, koni yellow coilovers, hypercoil springs, kla solid upper mounts, 968 sway bars, kla drop links, kla strut brace, fidanza flywheel, dansk catback, wilwood front calipers, ss brake lines, e-codes, 944 duckbill, manual rack,momo steering wheel |
Vince Ponz
Posted: Thu Apr 10, 2008 10:34 am Post subject: |
All you have to do is drill holes for the upright Euro rubbers. If you look at my avatar you will see a US bumper with the Euro uprights. The Euro bumper have a larger plate area, I think. _________________ "Never let them see you sweat"
79 931 Euro stock
88 924S SE
thirdgenbird
Posted: Thu Apr 10, 2008 10:40 am Post subject: |
so there is nothing unsightly underneath the stock black pads???
what are you wanting for the euro ones? _________________ 17in caymans, koni yellow coilovers, hypercoil springs, kla solid upper mounts, 968 sway bars, kla drop links, kla strut brace, fidanza flywheel, dansk catback, wilwood front calipers, ss brake lines, e-codes, 944 duckbill, manual rack,momo steering wheel |
Vince Ponz
Posted: Thu Apr 10, 2008 11:26 pm Post subject: |
You will be removing a large piece of rubber. Under it is just the bumper. You have two choices leave it stock or cut out a section for a fog light. One of our guys did this.
You will most likely fill in the holes to hold the larger rubber in place.
Remove the bumper[2 bolts] remove the rubber but first WD40 the nuts and wait a while. You will see what I mean. Lay on the ground and look up at the bumper. You will see two holes. In them is a bolt either 15 or 17mm. You will need a long shafted socket to remove. _________________ "Never let them see you sweat"
79 931 Euro stock
88 924S SE
