PORSCHEV
Posted: Fri Apr 11, 2008 6:48 am Post subject: New Look |
The 53 car needed a new nose panel after all the bumping and grinding at the local track. I took a mold off of Neil's car..from the headlights over the front edges of the fenders and the lower valance. So I can make these in one piece if I smash it up. The light openings have been converted into front brake duct cooling vents. I have the car fitted with spider web wheels and 8.5" foot print goodyear racing slicks.
 _________________ 1976 924
1978-#53 "D" track racer. |
Joined: 29 Jul 2001 Posts: 9138 Location: Royal Oak, MI, USA
Posted: Fri Apr 11, 2008 10:21 pm Post subject: |
Excellent!!!
Can you put a splitter on too? That'll REALLY make the nose stick... _________________ Vaughan Scott
Chrenan
Posted: Sat Apr 12, 2008 12:02 am Post subject: |
Is that the paint scheme from Herbie? _________________ 1987 951 - M193 Version for Japan |
PORSCHEV
Posted: Sat Apr 12, 2008 5:18 am Post subject: |
Yeah..that was last years paint scheme.
I had a splitter last year and some of the other competitors complained it wasn't "stock".  _________________ 1976 924
Neil924
Posted: Sat Apr 12, 2008 7:08 am Post subject: |
| One thing, that chin spoiler will create some drag, more than the stock front. |
Posted: Sat Apr 12, 2008 7:22 am Post subject: |
At least is doesn't create lift. . . _________________ Toofah King Bad
Posted: Sat Apr 12, 2008 7:57 am Post subject: |
| Rasta Monsta wrote: | | At least is doesn't create lift. . . |
EXACTLY!!!
Not to mention, reducing airflow under the car can actually reduce drag. And that nose will already help front downforce. Now he just needs the 944 or LeMans rear wing to balance it! _________________ Vaughan Scott
Neil924
Posted: Sat Apr 12, 2008 7:58 am Post subject: |
Uh huh. |
Neil924
Posted: Sat Apr 12, 2008 8:00 am Post subject: |
| 924RACR wrote: | | Rasta Monsta wrote: | | At least is doesn't create lift. . . |
EXACTLY!!!
Not to mention, reducing airflow under the car can actually reduce drag. And that nose will already help front downforce. Now he just needs the 944 or LeMans rear wing to balance it! |
Faster air moving under the car compared to over the car increases down force. If the air under the car is properly channeled, then drag can be reduced and down force can be gained. But who wants to spend time and cash on an under wing? |
PORSCHEV
Posted: Sat Apr 12, 2008 9:17 am Post subject: |
Guys..I am only hitting around 120-130km/h.
I forgot to mention the Turbo vents actually have duct work in place to channel ALL the air into the radiator which should really help keep it cooled down. The stock 924 does a terrible job at cooling the engine in the way of good radiator airflow. _________________ 1976 924
Neil924
Posted: Sat Apr 12, 2008 10:32 am Post subject: |
| PORSCHEV wrote: | Guys..I am only hitting around 120-130km/h.
I forgot to mention the Turbo vents actually have duct work in place to channel ALL the air into the radiator which should really help keep it cooled down. The stock 924 does a terrible job at cooling the engine in the way of good radiator airflow. |
Acceleration will be affected as much as top end would be.
Just a FYI. |
