Injectors - which ones?
Slam
PostPosted: Tue Apr 29, 2008 1:52 am    Post subject: Injectors - which ones? Reply with quote
file:///Users/ww/Desktop/Fuel%20Injectors%20%7C%20Auto%20Parts%20Online%20Canada.webarchive
Hey, guys, which injectors do we need for Mand's 77.5 924? The cheap ones, I hope.
TIA,
S
PostPosted: Tue Apr 29, 2008 2:15 am    Post subject: Reply with quote
For those of us without access to your PC, that link is bad.
EBS has your injectors HERE, $75 per.
Slam
PostPosted: Tue Apr 29, 2008 2:24 am    Post subject: Reply with quote
Oops. Not paying attention. Hang on - try this.
http://www.autopartsonlinecanada.com/category/fuel-injector/porsche/924.html
Chrenan
PostPosted: Tue Apr 29, 2008 2:27 am    Post subject: Reply with quote
There was a change in injectors for 1980. Usually the early ones are cheaper.
You can see here:
http://www.pelicanparts.com/catalog/shopcart/944M/POR_944M_FULinj_pg1.htm#item1
The earlier injector is a few bucks cheaper.
Hope the weekend was good, I ended up picking up that hatch in Red Deer so I am in good shape. If you head to Edmonton let me know and we'll connect, I'll take a spin out your way soon in any case.
PostPosted: Tue Apr 29, 2008 2:28 am    Post subject: Reply with quote
Urgh, those chassis numbers don't really make sense, and the 79 PET does not show a chassis split.
Slam
PostPosted: Tue Apr 29, 2008 2:37 am    Post subject: Reply with quote
Rasta - that's kinda why I'm asking.
Chrenan - glad you got the hatch issue sorted. Excellent gig this weekend. The pic from Pelican for the early injector matches the $53.95 one on my link. That'll be the one, I figure.
Thanks, guys.
Chrenan
Early cars have the braided fuel lines from the distributor to injector, later cars have the steel hardlines with plastic hose sections. The change happened sometime around 79/80.
Slam
PostPosted: Tue Apr 29, 2008 2:40 am    Post subject: Reply with quote
Are the banjo bolt sizes/setups the same? If so, it may not matter which injectors I use.
PostPosted: Tue Apr 29, 2008 5:39 pm    Post subject: Reply with quote
The '85 edition PET, which usually shows earlier chassic splits, only lists the one part number for the injector 'valve': 049 133 551.
Having said that, it only lists one part for the injector lines; but it is the 'B' version, so that implies at least two earlier versions ('A' and 'unlettered')...
