Slam
Posted: Tue Apr 29, 2008 2:15 am Post subject: |
For those of us without access to your PC, that link is bad.
EBS has your injectors HERE, $75 per. _________________ Toofah King Bad
Slam
Chrenan
Posted: Tue Apr 29, 2008 2:27 am Post subject: |
There was a change in injectors for 1980. Usually the early ones are cheaper.
You can see here:
http://www.pelicanparts.com/catalog/shopcart/944M/POR_944M_FULinj_pg1.htm#item1
The earlier injector is a few bucks cheaper.
Hope the weekend was good, I ended up picking up that hatch in Red Deer so I am in good shape. If you head to Edmonton let me know and we'll connect, I'll take a spin out your way soon in any case. _________________ 1987 951 - M193 Version for Japan |
Posted: Tue Apr 29, 2008 2:28 am Post subject: |
Urgh, those chassis numbers don't really make sense, and the 79 PET does not show a chassis split. _________________ Toofah King Bad
Slam
Posted: Tue Apr 29, 2008 2:37 am Post subject: |
Rasta - that's kinda why I'm asking.
Chrenan - glad you got the hatch issue sorted. Excellent gig this weekend. The pic from Pelican for the early injector matches the $53.95 one on my link. That'll be the one, I figure.
Thanks, guys. _________________ '88 944 Auto - may or may not resurrect
Chrenan
Early cars have the braided fuel lines from the distributor to injector, later cars have the steel hardlines with plastic hose sections. The change happened sometime around 79/80. _________________ 1987 951 - M193 Version for Japan |
Slam
Posted: Tue Apr 29, 2008 2:40 am Post subject: |
Are the banjo bolt sizes/setups the same? If so, it may not matter which injectors I use. _________________ '88 944 Auto - may or may not resurrect |
Posted: Tue Apr 29, 2008 5:39 pm Post subject: |
The '85 edition PET, which usually shows earlier chassic splits, only lists the one part number for the injector 'valve': 049 133 551.
Having said that, it only lists one part for the injector lines; but it is the 'B' version, so that implies at least two earlier versions ('A' and 'unlettered')... _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
