help
skitzo 4 snow
PostPosted: Sun May 25, 2008 9:27 am    Post subject: help Reply with quote
im replacing the master clutch and slave cylinder, what type of hose do i use for connecting the master to the brake master cylinder? the auto store told me i should order one from the dealer? do i have to or can i use something else? i have some fuel line hose i can use, but dont think it could handle the pressure.. please help. gotta get this car on the road its killing me just looking at it in this good weather we are having.. thanks.
another project car...omg
PostPosted: Sun May 25, 2008 9:49 am    Post subject: Reply with quote
If you talking about the hose that runs from the brake master cylinder reservoir to the inlet of the clutch master cylinder, any low pressure hose that is rated to be used with brake fluid is ok.
PostPosted: Sun May 25, 2008 9:51 am    Post subject: Reply with quote
Something like THIS
PostPosted: Sun May 25, 2008 9:59 am    Post subject: Reply with quote
I used reinforced clear plastic tubing with great success on one of my cars.
skitzo 4 snow
PostPosted: Sun May 25, 2008 10:14 am    Post subject: Reply with quote
cool, thanks, i should b on the road my today then. i will buy the round this time..
skitzo 4 snow
PostPosted: Wed May 28, 2008 7:53 am    Post subject: Reply with quote
ok, is there some trick to taking out the starter? ive got the bolts undone and all i have to do is take it off and install the new slave. but the starter doesnt want to come out of its home.. is there something i am missing? or do i have to use some force to pull it out?
PostPosted: Wed May 28, 2008 10:05 am    Post subject: Reply with quote
As long as you have also removed the wiring, yank it out (rocking it back and forth usually works).
bcblase
PostPosted: Wed May 28, 2008 1:19 pm    Post subject: Reply with quote
Try turning the engine/flywheel a little with the front crank bolt, then tap the starter loose with a BFH. (big hammer). Also, you might try disengaging the clutch to free up any tension on the flywheel.
After you get the two bolts out, it should come right off.
BC
1987 Porsche 924S - track toy
2001 BMW 325xi - daily driver
PostPosted: Wed May 28, 2008 3:15 pm    Post subject: Reply with quote
Mine fell on the ol' head.
skitzo 4 snow
PostPosted: Fri May 30, 2008 6:26 am    Post subject: Reply with quote
the BFHammer worked. all installed, pedal feels great.. only war wound was when the starter fell on my pinky! its all good tho. thanks for youre help guys... got a six pack of shipyard for ya..
bcblase
PostPosted: Fri May 30, 2008 12:15 pm    Post subject: Reply with quote
Mmmmmm....beer....ale....
send to Winchester, VA USA
skitzo 4 snow
PostPosted: Sat May 31, 2008 12:57 am    Post subject: Reply with quote
shipyard is a local brew here...mmmm good. always use a beer to steam the clams and lobster. i noticed my brakes pulse a bit, should i of bleed them also?
PostPosted: Sat May 31, 2008 1:05 am    Post subject: Reply with quote
Air in the lines from insufficient bleeding would cause a soft pedal feel. Pulsing might be caused by something like warped rotors (or dirty(with grease) rotors - They should be wiped with brake cleaner and a clean rag after servicing).
-And yes...bleeding is always part of the procedure any time the brake lines have been opened.
skitzo 4 snow
PostPosted: Thu Jun 05, 2008 10:22 pm    Post subject: omg Reply with quote
bleed the brakes, cleaned the rotors, there was some rust on them. the pulseing is sort of gone . its verry light now. my prob now is that i left the door a bit open and drained the battery. now the car wont start when i try to jump it. it ran fine the other day. so now im confused .
