00Smurf
Joined: 29 Jun 2008 Posts: 60 Location: Canal Winchester, Ohio
Posted: Fri Jul 04, 2008 3:51 am Post subject: what are these for? |
According to my factory manual, these wires should be for the timing retardation? But they are unhooked. Which goes to which?
Posted: Fri Jul 04, 2008 7:43 am Post subject: |
The one at lower left is a test connector. The ones at upper-center are for various uninstalled features like headlight washers and foglights. The barely visible wire at lower-right - for an '81-up NA would be for disabling EIS (electronic idle stabilization), for an '81-up 931 it's for timing retard. _________________ "..it's made in Germany. You know the Germans always make good stuff."
00Smurf
Posted: Fri Jul 04, 2008 8:14 am Post subject: |
| Smoothie wrote: | | The one at lower left is a test connector. The ones at upper-center are for various uninstalled features like headlight washers and foglights. The barely visible wire at lower-right - for an '81-up NA would be for disabling EIS (electronic idle stabilization), for an '81-up 931 it's for timing retard. |
so the lower right one would have no effect on an '80 931? I'm not sure entirely where your describing though. I don;t suppose you could mark on the picture the barely visible wire?
My car doesn't have fog lights, but it has the fog light switch in the center console? |
Posted: Fri Jul 04, 2008 8:41 am Post subject: |
| 00Smurf wrote: | | so the lower right one would have no effect on an '80 931? |
All that's visible there is part of the wire. An '81-up would have a single wire connector on that wire laying on top of the wheel well that can be disconnected. For an '80, there's probably no connector.
No need for another label - just look at the extreme bottom-right corner.
If you have it, the factory foglight switch would be mounted on the vertical surface within a few inches of the cig lighter. _________________ "..it's made in Germany. You know the Germans always make good stuff."
00Smurf
Posted: Fri Jul 04, 2008 10:51 am Post subject: |
| Smoothie wrote: | | 00Smurf wrote: | | so the lower right one would have no effect on an '80 931? |
If you have it, the factory foglight switch would be mounted on the vertical surface within a few inches of the cig lighter. |
gotcha now i see where your pointing. I have a 3 position switch to the left of the cig lighter that looks like it would be a fog light switch.
you can barely see it in this pic there is a little bit tht is not covered up by the wheel. |
Chickenwing
Posted: Sat Jul 05, 2008 9:32 am Post subject: |
are all 924's prewired for foglights? i have a '77 _________________ 1977 924 4-speed |
