924er
Joined: 10 Jan 2006 Posts: 339 Location: Los Angeles California
Posted: Sat Jul 26, 2008 8:19 am Post subject: Another one of my dumb Q's |
if you guys seen me post before you should know ive opened threads always complaining about my car's poor performance, but after i while i came to accept my car is a slow peice of shit..
until today im back here to because i came from a drive and i tried to hit at least 5000 rpm which i rarely ever do and my car only reved no higher then 4500 rpm and kinda got stuck there, and that was only on first gear! my car is REALLY ABNORMALLY SLOW and gets 15 mpg on the city! i notice it mainly picks up slow but once im at 55mph it runs fine. i remember dispite how slow my car is it still could hit redline rpm but not it cant even do that.
let me first tell you what i first done to the car:
-rebuilt engine head
-changed all belts
- plugs/wires, a basic tune up.
- fuel filter
- new cat
so im guessing maybe my ignition timming is off, but i adjusted the timing about 3 months ago, can it still go back off adjustment?
or my a/f mix is off, but i had that adjusted by a mechanic, but i have no clue where im at with that. oh yeah and i beleive my WUR is ng because it idles really low when cold, and normal when warm, but can that also effect performance also?
also, can it just be that the o rings in the fuel dist in cracked? i am thinking on getting those replaced but is there anyway to find out without opening the thing?
thanks all, i know i have ALOT of questions but i will greatly appreciate this, _________________ 80' Porsche 924 NA - Slower then a S L O W
86' Porsche 951- New toy |
RC
Posted: Sat Jul 26, 2008 3:17 pm Post subject: |
Hmm, bit short of 110 HP eh?
First up would suggest a compression test. Dry and wet. Search here as Smoothie has detailed the procedure previously or should be in haynes.
Post the numbers here for comment.
May be fuel or ignition but eliminate low comp before wasting much time or money.
Roger |
924er
Posted: Sat Jul 26, 2008 5:19 pm Post subject: |
yeah i was thinking of giving it a compression test, but how can it be losing compression when i rebuilt the head and changed all the gaskets, i dont know of any exhaust leaks... any other suggestions? does my case sound like a timming problem? _________________ 80' Porsche 924 NA - Slower then a S L O W
sparky
Posted: Sat Jul 26, 2008 5:40 pm Post subject: |
| 924er wrote: | | but how can it be losing compression when i rebuilt the head and changed all the gaskets |
Piston rings is 1.. _________________ When the checkered flag drops... The Bull$hit Stops
1976 Euro 924 (The 945) - Full 951 Brakes/Suspension
1998 Boxster with goodies
2002 3.0 Xtype 4wd sport |
RC
Posted: Sat Jul 26, 2008 7:21 pm Post subject: |
Hey Sparky, long time no see.
Trust you`ve been busy in the garage rather than on your computer. So your beast is on the road now?
Besides worn or broken rings, other causes include worn cam, incorrect cam timing or valve clearance. Even though the head was rebuilt it is still possible to have a leaking valve or gasket. Did you pour gas down all the ports to check the valve seal before refitting? Also the rare chance of a crack.
Its a logical process of elimination really rather than taking pot luck and your money replacing everything till its fixed. If you have or borrow a gauge it is a free test that eliminates the most expensive possibility.
Not familiar with your other threads as to when/ how your problems occurred or if you bought the car like that. The history can lead to a faster diagnosis.
Assume the headjob made no difference.
Sure the cam timing is accurate, pulley the correct way? With #1 TDC on firing stroke, cam pulley in alignment, the valves on #4 should be nearly symmetrically on the rock, both slightly open.
Then a pressure test on the CIS is really necessary to correctly assess the system. Main pressure reading will indicate the valve O ring sealing but it only takes 2 minutes to remove and check or replace. A faulty WUR may or may not affect WOT operation depending on how the system is tuned. Fairly pointless setting AFR with a bad WUR or sus system pressure.
Timing shouldn`t vary with the dizzy clamp tight. What is it set at? Did you rev it with the timing light on to check the advance? No or incorrect advance will cause your symptoms too.
We can keep guessing here until you give us some figures on your tests and further info.
Roger |
sparky
Posted: Sun Jul 27, 2008 5:45 am Post subject: |
| RC wrote: | Hey Sparky, long time no see.
Roger |
Hey Roger,
The beast is still leashed.. Alot of progress has been made and the front lights to replace the pop-ups should be in this week I hope.. After the lights are in all it needs is the brakes/suspension bits (saving up for them now) and it will be on the road!
I am spending every moment that I can on it, but time is always limited in summer.. A few more saturdays work and a clean up of the interior and I will post some pics.. The sound system is all in place and during the week I will pick up some wood and finish off the boot area..
Im sure you will love the place where I mounted the front speakers this morning
SparkY _________________ When the checkered flag drops... The Bull$hit Stops
924er
Posted: Sun Jul 27, 2008 5:55 am Post subject: |
I watched my mechanic adjust the valve clearance according to the factory specs,
no i dont remember him pouring any gas the check if its sealed,
and no i did not rev the engine when i was adjusting the timming, he watched him disconnect a small vacuum hose on the dist while he was using the timming gun...
when i first bought the car and opened the engine, i found a bent valve, blown head gasket, throttle body gasket cracked, as well as the manifold gasket, but i got them all replaced when i rebuild the head.
thanks alot sparky
im thinking about giving my car a two hour inspection at a porsche mechanic downtown, and the guy said he checks mostly everything such as the balance belt timming, a/f mix, CIS pressure test, and they carry most diagnosis tests over there i heard. he is charging me $90 for that!
what you think? _________________ 80' Porsche 924 NA - Slower then a S L O W
RC
Posted: Sun Jul 27, 2008 12:15 pm Post subject: |
Cool Sparky.
Overlooked that its summer on that little party island. Acceptable excuse.
Keep at it mate.
| 924er wrote: |
what you think? |
Probably the best idea if you don`t have the experience or tools to DIY. Good price if he`s a COMPETENT Porsche mechanic familiar with CIS.
Describe your symptoms and am sure he will do a compression and/or leakdown test, check cam and ignition timing/advance, then proceed to diagnose the CIS pressures. Hopefully it is just something basic and cheap like stuck dizzy weights or a vacuum leak.
Good luck.
Roger |
Forest924
Joined: 03 Jun 2008 Posts: 4 Location: Los Angeles, CA
Posted: Sun Jul 27, 2008 2:09 pm Post subject: Another one of my dumb Q's |
Hey 924er,
I see that your local (well that is a relative term in Los Angeles). I pickup a 80' 924 for my son (that's the story I'm sticking too) and have been working on things but your post about a Porsche mechanic who does inspections got my attention.
Would it be possible for you to pass along his info? The previous owner gave me a name of someone in Pasadena, it was a second mechanic he found after a great one closed up shop.
Thanks,
Forest _________________ '80 924 Red
Actually it's my kids car |
924er
Posted: Sun Jul 27, 2008 4:57 pm Post subject: |
im sorry i meant $190! forgot the 1
he sounds like an iranian guy so i think i could probably bring it down to $150 if i try. its in canoga park. i actaully live in palmdale, its about an hour north of LA. the number is (818) 888-7366
there are other competitors around him so you may want to check also!
i have a local mechanic here thats real cheap, but he dont speak spanish real good hes a mexican. he rebuilt my engine head and done all the work on my car. he mickey mouses things around sometimes to get them to work, its hard to explain my problem to him, on monday ill ask him to do a compression test and check for some leaks but thats all i can do from my end for now until i get enough money for something like that because the mechanic just said INSPECTION, not REPAIR
he RC what do you mean by stuck dizzy weights? _________________ 80' Porsche 924 NA - Slower then a S L O W
924guy
Posted: Sun Jul 27, 2008 10:45 pm Post subject: |
a few suggestions:
clean all your grounds and electrical connections, sometimes a bad connection in a seemingly unrelated area and wreak havoc on these cars..
check your compression, and injector spray pattern and flow, plenty of info here on what acceptable results are and in the haynes manual.
these things are free to do yourself, and you can usually rent compression test kits at some auto parts stores....the more areas you can eliminate (keep notes), the less you'll pay later on if you have to hire someone to do the work. could be something as simple as a corroded fuel pump connection, or as bad as toasted rings...when i had a similiar issue, it turned out to be electrical...
also, on a side note, I dont think most people care what nationality the people your talking with are. It would be a mistake imo to judge anyone on that type of information, and unfair... find out the quality of their work and let that speak for them... _________________ Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha |
RC
Posted: Sun Jul 27, 2008 11:07 pm Post subject: |
Inside the dizzy is a centrifugal advance mechanism that employs 2 counterweights, springs and a cam to increase the advance at higher RPM. If not working correctly will severely limit your power and RPM, same as you describe. A basic test is to remove the cap and twist the rotor clockwise. You should feel some resistance (spring pressure) but easily be able to turn it about 10-15*. Should spring back CCW by itself.
To check properly a timing light is used to ensure the timing mark on the flywheel moves the prescribed amount at the specified RPM. The details are in the book, Haynes, depending on model.
Now to me it sounds like your mickey mouse mechanic may be better employed in a taco shop. Anyone who does`nt know exactly WTF they`re doing on your unusual, imported, performance vehicle can easily dig themselves deeper into the great abyss of your wallet. It is not the initial cost you should consider but the result. IMHO it is better to pay top rate at a dealer for 2 hours accurate diagnosis than give peanuts to a monkey to spend all day screwing with your investment only to offer lame excuses.
Many members are here to learn and share how to DIY, not only to save money but to actually get the job done right. For $190 you could easily buy a comp gauge, timing light and CIS gauge as required. And of course a manual if you don`t own one. Heaps of knowledge here and people willing to advise you. Then you have the tools and the knowledge so your next tune or service is free of labour charges.
Roger |
D Hook
Posted: Sun Jul 27, 2008 11:56 pm Post subject: |
| 924er wrote: | | Iim thinking about giving my car a two hour inspection at a porsche mechanic downtown, and the guy said he checks mostly everything such as the balance belt timming, a/f mix, CIS pressure test, and they carry most diagnosis tests over there i heard. |
You might want to find a mechanic that knows more about the model year of the car you own.
'80 924 doesn't have a balance shaft/belt.
But it does have the CIS. He'll need an exhaust analyzer to check the A/F ratio. And a set of gauges to check the CIS.
Except for the analyzer, as Roger said, the same money would buy you all the tools you'd need to check these things yourself. It may take more than 2 hours to pinpoint the problems by process of elimination.
If you don't have a manual, pm me. I have an extra.
Good luck!  _________________ '80 924 n/a SOLD |
924er
Posted: Mon Jul 28, 2008 4:04 am Post subject: |
so are the electrical grounds ports your talking about is located under the steering wheel am i right? does not look too bad, no corrosion or anything like that.
my mechanic at a CO tester in my exhaust pipe when he was adusting a/f, i think it was about 3 CO and i have a cat.
i bought a haynes manual yesterday and im feeling more comfortable aready. i tells you everything A-Z about this car!
i tried reving again on neutral and it hit 6.5 rpm(not going to try that again) so i guess its not a stuck weight, just my car with a lack of power!
i will purchase a compression test and i will post the number back up on this thread.
now if i purchase a CIS test kit, how would i test it and what will it tell me what wrong, vacuum leaks, fuel injectors? _________________ 80' Porsche 924 NA - Slower then a S L O W
DOCO
Joined: 04 Aug 2006 Posts: 1111 Location: Keswick Ontario Canada
Posted: Mon Jul 28, 2008 5:18 am Post subject: |
hey 924r ya what all they said ,im just suprised no one said to check the cat.and see if its plugged.maybe said in adifferent post.but ussauly when ya cant rev a engine to redline xshast is ussually holding it back.just a thought  _________________ Doco "where am i going and why am i in this handbasket"author unknown
79 924 N/A "Webster"
_______
/______\
[+]___[+]
\0 924 0/
[__]..[__]
"WEBB STR" |
