924man_the_first
Joined: 29 Mar 2008 Posts: 23 Location: silver springs FL
Posted: Tue Sep 23, 2008 2:51 pm Post subject: how to run e85 |
| i want to know how to run e85 in my 924s or any outhere e-fuel some1 told me it as esey as pluging in my laptop to my car but i dont know where to get the plugs or softwere for runing on my mac laptop and would i need a new car computer for my 924 i have looked all over the net and if any1 on here knows how to run my car on e85 thx for any help |
Min
Posted: Tue Sep 23, 2008 3:24 pm Post subject: |
Well, unless you've converted to electronic fuel injection, you can't plug your computer into your car.
So, first, you'd have to convert to a electronic fuel system that supports e85. Or figure out a way to run it on CIS (could be possible, but you need 30 percent more flow out of the CIS system to run e85, so, may not be very easy, and you wouldn't be able to switch back and forth)
Posted: Tue Sep 23, 2008 8:01 pm Post subject: |
Theres a guy here in sweden that converted his 924 some years ago. If i remember correctly he adjusted the CIS to go much richer and it was enough. _________________ 1980 924 Turbo
924man_the_first
Posted: Tue Sep 23, 2008 8:11 pm Post subject: |
the 924s i have has the 1987 944 engen in it and yes it has the electric fuel injector _________________ i got parts to sell |
Posted: Tue Sep 23, 2008 8:18 pm Post subject: |
Then its easy, over here we have a guy that make ecu uppgrades for e85, but you must also get new injectors. This is done for several 944s. I dont know if anyone over there does the same thing. does the us 924s differ from the row ? _________________ 1980 924 Turbo
Posted: Tue Sep 23, 2008 10:55 pm Post subject: |
You should probably make sure you're not running a plastic gas tank, and you should also replace any of the old rubber and neoprene gas lines with modern fuel lines designed to accommodate ethanol.
In addition, as others have noted above, my reading on the topic indicates that you will need injectors that can accommodate up to 40% more duty cycle, you will need to make sure your fuel pump can handle the add'l required fuel flow, and the ECU will need to be modified to deliver the correct air fuel ratio (AFR) as well as correctly adjusted ignition timing.
Be aware, if you head down this path, the proper way to implement this is with an E85 sensor that can detect the amount of ethanol, and communicate with the ECU to adjust the timing and AFR on the fly. I don't believe the stock 924S/944 ECU has this capability. There are ways to manually get around this, but you will have to really stay on top of the mix of ethanol you are running at all times. Also, there are some interesting threads over on Pelican related to E85. Since your car is a 924S with the 2.5L engine, you might want to do some searching over there as well. _________________ erstwhile owner of just about every 924 variant ever made |
