eugenechris
Posted: Wed Dec 03, 2008 8:47 am Post subject: mpg what do you get |
i have been driving my Porsche for about two years now and still only get about 15-16 mpg. i drove it to California from Oregon and it was about 25 mpg on the highway seems a little low for a four banger. what do you get about _________________ org. black 1987 porsche 924s |
Posted: Wed Dec 03, 2008 8:55 am Post subject: |
A 944 trans will improve your highway mileage.
My 931 gets 25 on the highway on a good day, my 924S slightly better. _________________ Toofah King Bad
jrrhdmust
Joined: 19 Mar 2008 Posts: 180 Location: Middle Georgia
Posted: Thu Dec 04, 2008 1:28 am Post subject: |
I get 23 in town consistently and 30 on the highway. _________________ 67 Mercury Cougar XR7 under Restoration
71 VW Superbeetle Completed Resto 11/07
73 Mustang Mach 1 10 Year old restoration |
ronined
Posted: Thu Dec 04, 2008 7:36 am Post subject: |
I get about 22 MPG around town and about 26-28 on the highway. _________________ '87 924S |
John_AZ
Joined: 25 Jun 2008 Posts: 130 Location: Arizona ~Carefree Highway~
Posted: Thu Dec 04, 2008 11:12 pm Post subject: |
I have noticed my mileage is related to the price of gas. At $4/gal it improves. Now that the corner Shell is $1.79/gal mileage has dropped.
If you want to improve your numbers a little, I use Lucas Upper Cyl Lubricant in the tank-2 or 3 oz every other tank or so. Benefits to mileage as well as my fuel pump sounds a little quieter and cleaner injectors. Also, tire pressure is 29 lb. front and 36 lb. rear.
GL
John_AZ
1988 924S 58.7K + 1987 924S 112K DD
1979 924 + 1977.5 924 + 1970 914 + MG Midget--all gone, past tutors |
Posted: Fri Dec 05, 2008 12:23 am Post subject: |
My 924S gets 27-29 MPG
My 924 2.0L NA gets ~21 MPG (it has the Audi TB, so it's on WOT more frequently than a bone stock NA )
Haven't measured MPG in the S1 931 because the odo is still awaiting repair. _________________ erstwhile owner of just about every 924 variant ever made |
eugenechris
Posted: Fri Dec 05, 2008 8:51 am Post subject: |
sounds like im running a little low i just put some new plugs in maybe that will help i have the split fire ones this time $5.00 a plug that should help. _________________ org. black 1987 porsche 924s |
Posted: Fri Dec 05, 2008 9:48 am Post subject: |
Tire pressure can make a notable difference in MPG.
The other thing that just occurred to me is that you're on the west coast where some of those refueling locations might be *required* to blend at least 10% ethanol into conventional pump gas. If that were the case, given the 25% less fuel economy of ethanol vs. conventional gasoline, it could account for why your highway mileage is marginally lower than most of the numbers posted.
Just doing some quick math using some round numbers...
Using a 16 gallon tank of conventional gas with a baseline MPG of 30 MPG would yield a range of 480 miles.
That same tank of gas with 10% ethanol blend would only yield roughly 468 miles (at best), a difference of 12 miles, or 2.5%
30 MPG baseline minus 2.5% = 29.25 MPG
But that of course doesn't take into account the fact that the car is not setup to run on that mixture of fuel, so the effects on economy could be even greater. Factor in a few other variables like improper tire pressure, driving style, etc. and it's not hard to imagine how your economy would be less than optimum.
Don't know if my theory holds water, but it's food for thought. _________________ erstwhile owner of just about every 924 variant ever made |
alexvex
Joined: 31 Jul 2006 Posts: 420 Location: Seattle, WA (from Indiana)
Posted: Fri Dec 05, 2008 11:20 am Post subject: |
I used to get ~30mpg in my 924S. I got somewhere between 25-30mph in my 931 (GPS calculated as the odometer is broken). _________________ --Alex--
1992 Porsche 968 (VW 2.5L I5 Turbo swap in the works)
1995 Audi 90 Quattro Sport (4.2L V8 Swap)
2010 Touareg TDI
Past Pcars: 80 931, 87 924S, 87 951 |
eugenechris
Posted: Sat Dec 06, 2008 8:42 am Post subject: |
i will check my tire pressure i just put in a new dme the old one went bad that could be it to. i only use good gass in my car shell mostly when i put ampm/arco gas my car just drives like crap. there is hope for my mpg _________________ org. black 1987 porsche 924s |
Min
Posted: Wed Dec 10, 2008 9:21 am Post subject: |
| ideola wrote: | My 924 2.0L NA gets ~21 MPG (it has the Audi TB, so it's on WOT more frequently than a bone stock NA ) |
my 2.0l na got 32mpg highway last time I checked it (before megasquirt) I should check it again sometime.
flyguy
Joined: 31 Oct 2008 Posts: 75 Location: Hamilton, Ont
Posted: Thu Dec 11, 2008 6:28 am Post subject: |
I get up to 11mpg in city, no idea highway, cause there isnt really a highway out here.
Got about 150 Miles on the odometer on last fill-up. |
Posted: Thu Dec 11, 2008 7:34 am Post subject: |
Food for thought...just make sure your odo gear isn't slipping. I discovered on my recent summer trip to 944 Fest that the 928 odometer, while it appears to be working correctly and doesn't jump or stop, was only recording about .6 miles for every actual mile traveled. Made my mileage numbers look like crap! _________________ erstwhile owner of just about every 924 variant ever made |
mehall
Joined: 15 Dec 2008 Posts: 191 Location: Richmond, MO
Posted: Wed Dec 24, 2008 10:58 am Post subject: |
A couple of thoughts:
If you're getting .6 miles per mile driven, it sounds like someone slipped you a metric setup. A kilometer is about .6 miles.
Also,
Those of you living in Canada will calculate higher gas mileage. Unless things have changed in the past 20 years, Canada is using the Imperial gallon, which is about 25% larger than ours in the states. If you get 30mpg in the US, you should get 37.5 in Canada minus the mileage penalty when driving in cold weather.
If you get only 11mpg, it might be that you taking short trips in town, never actually getting the engine full warm. That will kill your mpg, and wear your drive train out far ahead of it's normal milieage limit.
Mark _________________ Mark
'87 White 924s manual
'94 Lexus LS400
www.kcws.org |
Posted: Thu Dec 25, 2008 1:04 am Post subject: |
It's the other way 'round...my odo is reporting .6 miles for every 1 mile driven...if it were a KM based odo, it would be the other way around, I'd be showing more "miles" than actually driven... _________________ erstwhile owner of just about every 924 variant ever made |
