Problems with setting ride hight with 30mm rear torsion bars
Dutch924-racer
PostPosted: Sun Jan 25, 2009 6:53 pm    Post subject: Problems with setting ride hight with 30mm rear torsion bars Reply with quote
I installed my rear 30mm torsion bars yesterday, i put the bars a few teath lower. But having the car back on the wheels is is even higher then before. Ofcourse this is because the bars are much stiffer.
Does any one know about how much 1 teeth (inside or outside) will lower the car with the 30mm bars ?
937 trackday car
Series 2 engine
951S turbo and intercooler
Fast road camshaft
PostPosted: Sun Jan 25, 2009 9:03 pm    Post subject: Reply with quote
you'll have to give it a few more tries...you can never get it right from the first try even if you know how much the teeth raise/lower it...well unless you get lucky.
right click, save as: http://www.924board.org/downloads/Torsionbarsetup.doc
gegge
PostPosted: Sun Jan 25, 2009 9:49 pm    Post subject: Reply with quote
One tooth is equal to 360/40 or 360/44 depending on inside or outside.
IIRC the orginal setup fro 924 was 19 degrees and 968cs got 8 degrees with 25,5 mm torsion bars? Correct answer was:
All 968 CS 14.0 deg
All 968 CS M030 9.0 deg
USA Coupe 18.5 deg
USA M030 14.0 deg
Stock 951S 18.0 deg
Letīs say that the car weight is 2640 lbs, 660lbs on one rear wheel:
23,5mm bars equals 126lbs/inch = compression of 5,2inch
30,0mm bars equals 334lbs/inch = compression of 2,0inch
So we have to compensate for the lost 3,2 inch. How long are the tailing arms? 16inch? Then arcsin(3,2/16)=11,5 degrees.
I would guess that close to horizontal level is right if you want to lower the car 2inch or to get close to 968 ride height.
Let me know what the result is, because I have to do the exact same thing since I choosed 30mm as well.
Carl Fredrik Torkildsen
PostPosted: Sun Jan 25, 2009 11:57 pm    Post subject: Reply with quote
Yeah, you have to move it a lot - the 30's don't move much when you put the car down. When I switched over, I had to try a couple of times before I got it right.
Make sure you also have the spring plate height adjustment at the same point on both sides; if you don't, you can end up having the two sides at different indexing on the t-bars, which can be a real PITA later on when you're trying to balance the car.
Definitely use a protractor or angle finder/gauge to get both sides set the same.
PostPosted: Mon Jan 26, 2009 1:34 am    Post subject: Reply with quote
There is a very detailed article on Clark's Garage about this.
Dutch924-racer
PostPosted: Mon Jan 26, 2009 2:19 am    Post subject: Reply with quote
I use the car mostly for trackdays and some times on the normal road.
What would be the right hight ?
Measured now:
After the front wheel is now: 5,5 inch
Before the rear wheel is now: 6,7 inch
The guys who race a 944 say the the rear should be lower then the front.
937 trackday car
Series 2 engine
Fast road camshaft
PostPosted: Mon Jan 26, 2009 2:22 am    Post subject: Reply with quote
The right height on a 924 is LEVEL.
Dutch924-racer
PostPosted: Mon Jan 26, 2009 2:36 am    Post subject: Reply with quote
for a 931 also ?
937 trackday car
Series 2 engine
Fast road camshaft
PostPosted: Mon Jan 26, 2009 2:55 am    Post subject: Reply with quote
Yes, definitely. Certainly, it's possible to run a 924/944 nose-high - I have - but not preferred.
PostPosted: Mon Jan 26, 2009 4:43 am    Post subject: Reply with quote
If you don't feel like another round of dissassembly, you have a great excuse to get a coilover sleeve kit with adjustable spring perches. They are ungoldy cheap, IMO, for what they can accomplish.
Example HERE.
And FWIW you may be better off using a level in the door sill instead of trying to measure points on the body.
PostPosted: Mon Jan 26, 2009 5:19 am    Post subject: Reply with quote
Try this excel sheet. It might help:
http://944spec.org/944SPEC/content/view/42/25/
Dutch924-racer
PostPosted: Thu Jan 29, 2009 4:51 am    Post subject: Reply with quote
Second try was just perfect, I will post pictures later
thanks guys !
937 trackday car
Series 2 engine
Fast road camshaft
