EFI rail and injector bungs
PostPosted: Mon Jan 12, 2009 5:46 pm    Post subject: EFI rail and injector bungs Reply with quote
Not really a performance mod...but something to make performance mods work
I've read around that a certain Ford mondeo fuel rail is a PERFECT fit...is it really? Anyone of you guys using it? i'd rather go to the brakers and get one instead of buying a custom rail or making one.
What about injector bungs? where can i get a set of screw-in ones ? just to replace the factory ones...i dont want to mod the head one bit.
Rich H
PostPosted: Mon Jan 12, 2009 10:08 pm    Post subject: Reply with quote
Ford Duratec engines have a bore spacing of ~96mm, our engine is ~95mm. I have one fitted to my car OK, but you need to fit a fuel return line fitting as its a no-return system (Which is generally bad)
PostPosted: Mon Jan 12, 2009 11:02 pm    Post subject: Reply with quote
034 Motorsports makes injector inserts, or you can buy 4 transaxle plugs and use them.
RC
PostPosted: Tue Jan 13, 2009 12:15 am    Post subject: Reply with quote
Or you can simply get new stock inserts bored out. Don`t know if Endwrench is still doing them as he hasn`t been around lately.
Look in the 4sale section for a rail and insert kit.
71vdubturbo
PostPosted: Sat Feb 07, 2009 1:15 pm    Post subject: Reply with quote
I'm using a Mitsubishi Eclipse GST fuel rail with it's stock fuel pressure regulator (since it is boost referenced). It isn't exact on the injector spacing, I think it is off by 1 mm. I did have to drill the injector holes of the rail with a 35/64 inch drill bit to accept the bosch injectors. For injectors, I use stock VW 1.8T injectors, which are 30 lb injectors. I am also using the 034 motorsport inserts.
Just thought I'd give you an idea of some other possible options.
1977 Porsche 924 - going away...
2001 Audi S4 - 2.7T, Tip
PostPosted: Sat Feb 07, 2009 5:20 pm    Post subject: Reply with quote
thankyou very much.
haroldk
PostPosted: Sun Feb 08, 2009 12:38 pm    Post subject: Reply with quote
I've got a spare rail for my Focus (with the Zetec) and it looks like the spacing is pretty much spot on. It's got a Ford fuel line fitting bolted to one end and what looks like a blanking plate bolted to the other. I keep meaning to pull it off and see if it's actually open on that end. If so, it'd be dead simple to get another one of the fittings and put one on each end for a return line. It might also be easy enough to make a plate with whatever fitting you want, but I haven't seen what the sealing surface looks like yet.
xpernet
PostPosted: Mon Feb 09, 2009 11:26 pm    Post subject: Reply with quote
I used a fuel rail off of a 1993 Ford Escort. Comes with a pressure regulator & return line, and bosch injectors fit perfect. I didnt use injector inserts and the fit is not bad at all. No leaks so far *knock on wood*
1977 Porsche 924
Sunroof Delete
Megasquirt II EFI & EDIS
Carrera GTS / 944 Body
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche
Rich H
PostPosted: Mon Feb 09, 2009 11:56 pm    Post subject: Reply with quote
How do you get a seal without some sort of insert?
I drilled a recess into the top of eachinjector hole about 5mm deep so the injector O ring would seal properly.
To check for leaks I use some brake cleaner, with the engine runing a little squirt on each joint will quickly show if you haev a leak as the engine will stumble a bit. I've got a slightly leaky thropttle spindle and I found 2 injector seals ahd gone with this method a while ago.
alexvex
PostPosted: Tue Feb 10, 2009 12:11 am    Post subject: Reply with quote
If anyone needs escort fuel rails I've got several sitting around
--Alex--
2010 Touareg TDI
Past Pcars: 80 931, 87 924S, 87 951
