bruni
Joined: 26 Jul 2008 Posts: 114 Location: South Africa
Posted: Sat Nov 22, 2008 8:58 am Post subject: |
Thanks, really interesting articles, amazing how much water you can put in without putting the fire out  _________________ 1982 931
1975 harley sportster |
Posted: Mon Nov 24, 2008 1:28 am Post subject: |
Fascinating articles, one thing to remember though, or not, during the war, what was the average life-span of an aircraft engine? Maybe longevity wasn't a major concern. dave. _________________ '83 944 Track car.
2001 Ford F350 powerstroke |
tuurbo
Joined: 08 Aug 2007 Posts: 1446 Location: East Windsor, New Jersey
Posted: Tue Nov 25, 2008 7:24 pm Post subject: |
Yeah that's a really good point Dave and I didn't pay attention to any discussion (if there's been much) about the long term life of the engines.
I think they did have a concern for reliability while it was up and flying.
Thankfully, Porsche didn't make aircraft engines for the Allies (duck!).
They ran something like RON 80 back then, and with what I presume was a lot of lead it wasn't the same fuel as nowadays, which might account for lack of life, if it's true that they wore out. No synthetic oil then either. They probably used methanol or alcohol in their rads - don't think they had ethylene glycol back then, I don't know.
Working from sort of first guesses, barring any other dysfunctions that can come from using alcohol and water injection, the cooling effect should make the whole engine run harder without getting comparably hotter, when compared to no alcohol and water injection at all. Add to this the cleaner cylinders, which 'should' translate into less carbon to build up and ignite the gas/air, and you'll get less ping, which should combine with the cooler temperature to lengthen the life of the engine.
But if the alcohol and oil get together too much, I think that's a real problem for long term engine life. Surely they changed the oil after each run, but if the mix was off I can see there being room for some alcohol and water in the engine oil screwing up the viscosity, which would make things heat up quite a lot. Still, the temperatures of the head don't jive with that possibility - I got the impression the head was cooler. And I can't imagine them sending planes into the air without the mix (air, fuel, methanol, and water) being 'spot on' as the Brits say. I mean, they're the military, so they're doing everything completely by the book, with zero variation. _________________ 1980 924 turbo, MSD, Meth. Inj, otherwise stock. |
bruni
Posted: Wed Mar 25, 2009 9:47 pm Post subject: |
Well finally got around to fitting the water injection. After considering various options including multiple injectors and controllers i settled on a very simple system using cooling mist components, pump, nozzle, check valve ,pressure switch and relay. My objective was to be able to run 10lb boost on 95 octane fuel on full advance. At the moment I am using water only and fully meeting my objectives, subjectively performance is improved (no pinking) and pulling very strong. Will get around to measuring inlet temperatures soon  _________________ 1982 931
RC
Posted: Wed Mar 25, 2009 11:31 pm Post subject: |
Cool.
Would you mind sharing a few details on your set up Bruni? What type of pump and pressure, nozzle details and position, what you used for tank and where it`s mounted. Have been thinking about H2O too and always good to get ideas from others.
An overall picture would be nice too. |
Kenodog
Posted: Thu Mar 26, 2009 2:25 pm Post subject: |
Allied fighters,the Spitfire,Hellcat etc., did indeed have methenol injection. Pilots were told that it was to be used as a last resort for getting out of a life and death situation. In the Spitfire it was a lever on the left-hand side of the cockpit that,when pushed to the full forward position,would give the pilot 300 extra horsepower to either climb to safety or pull ahead out of trouble. It was to be used ONLY in case of emergency and if left on for more than a few seconds could possibly destroy the engine. In short Tuurbo,they didn't run anything other than gasoline for 99.99% of the engine's life. _________________ 1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140 |
tuurbo
Posted: Thu Mar 26, 2009 2:42 pm Post subject: |
| Quote: | | It was to be used ONLY in case of emergency and if left on for more than a few seconds could possibly destroy the engine. |
Can you please explain how this destruction happens if it's on 'for more than a few seconds'?
Here's a report on the Hellcat you mention, but there's no discussion of using it for only seconds or engine destruction:
http://www.wwiiaircraftperformance.org/f6f/jv224-b.pdf
Just because I've been reading up on this, can you pass along a citation where such destruction is discussed? I prefer reading the reports - it helps comprehension. _________________ 1980 924 turbo, MSD, Meth. Inj, otherwise stock. |
bruni
Posted: Thu Mar 26, 2009 6:46 pm Post subject: |
Fantastic old documents. I am sure than any increase in performance will have an effect on the life of an engine, however, I think it is worth considering the following.
Prior to fitting the water injection, my engine was experiencing detonation, this definitely will have a detrimental on engine life, admittedly I could of retarded the ignition and reduced the power output
I use my car only on the road, so the amount of time I use full throttle and full boost is minimill, cruising and about town is rarely on boost.
Turbo in my situation is there any advantage to adding alcohol or do I just stick with the water? _________________ 1982 931
RC
924guy
Posted: Thu Mar 26, 2009 11:18 pm Post subject: |
anyone have any thoughts on dual port water injection where one nozzle injects pre turbo, and the second injects pre TB? _________________ Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha |
Posted: Thu Mar 26, 2009 11:41 pm Post subject: |
IMO, pre-turbo is a really bad idea because the water droplets can damage the fins on the compressor wheel. _________________ erstwhile owner of just about every 924 variant ever made |
RC
Posted: Thu Mar 26, 2009 11:50 pm Post subject: |
Have no experience with it Eric but from my understanding is probably not a good idea. More so if you run through an IC where it will condense and loose cooling efficiency. May theoretically cool the compressor however high pressure as a water jet does damage, also thermal cycles may initiate metal fatigue and lead to cracking.
Theres good info to learn by the time you have read through those links. Know I wont be injecting into my blower, also with teflon coated rotors, after seeing this:
http://v6supercharged.com.au/workshop.asp?ProjectID=8 |
tuurbo
Posted: Fri Mar 27, 2009 12:43 am Post subject: |
| Quote: | | Turbo in my situation is there any advantage to adding alcohol or do I just stick with the water? |
Good question. Not a clear answer. This is where it's a black art and there's a lot of bullshit to be consumed. But I suspect guys who have a wideband have less bullshit to offer. But here's mine.
My brother has tried all three possibilities: Water, no alcohol; Alcohol and no water; and 50:50 mix. In the summer he runs entirely water on his 350 Vette engine. In winter he mixes 50:50. He's found no benefit to overloading on the alcohol as he already runs the car on the rich side, as do I.
If I were you and you're in a warm climate, I would try just the water and see if you detect detonation. If there's none, Bob's your uncle and it's done it's job! Cheap and cheerful.
I've also tried all three combinations and I stick to the 50:50 mix year round. I reason that if there's some small amount of richness to be gained, I want it. Many of the commercial products suggest a 50:50 mix of water and alcohol as you know. I think the only trick is in trying the various combinations and seeing which works best on your application, but if in doubt, the 50:50 split is a compromise most people accept.
| Quote: | | ...any thoughts on dual port water injection where one nozzle injects pre turbo, and the second injects pre TB? |
Yes I do it this way. Dan is echoing the concerns of others in the industry: Injecting alcohol before the turbo - many companies advise this is a bad idea because it impacts on the compressor wheel and damages it. However, it should be noted that very often, in terms of the actual real true application, what this means is that users are dealing with huge amounts of water - somewhere around 250-350 ml/min. In Roger's example, the V6 Supercharged M90 powered engine is about 260 HP which would translate to this guy pumping about 175-250 ml/min into the supercharger. That's a shitload of water mass. I have set up the 175 and 250 ml/min injectors and trust me it's a torrent of water. Point it at your buddy, turn it on, and it'll totally soak him in seconds. And if you try to run these on our 931, you will experience 'quench' which will not be pleasant - it's inappropriate for our engine. The engine spark is extinguished at speed. This will not be in keeping with your objectives.
So in terms of degree - I think I can get away with this small amount (15-25% of the volume) pre turbo. We'll see anyway. Smoothie I think also injects a small amount before the turbo. I don't see it as a big deal - I have a spare turbo - and I can move it sometime this summer if my fear of turbo compressor degradation rises. I inject 60 ml/min before the turbo, and 60 ml/min after the turbo, before the throttle. The car runs great.
I will be replacing my turbo this summer so maybe I'll inspect the compressor and report back on my findings. If there's a compressor wheel that's wonky, we'll have good reason to suspect why this happened.
If degrading your compressor wheel is a worry - don't do it. Just set up one injector (about 100-150 ml/min for the 931). _________________ 1980 924 turbo, MSD, Meth. Inj, otherwise stock. |
Scorpio
Posted: Fri Mar 27, 2009 8:48 am Post subject: |
hey Tuurbo so if youre injecting 100ml/minute then you have to be "on boost" or around 20min to empty a 2 litre water/methanol tank...
20 minutes of "on boost" at say 7psi plus(or whatever your set boost entry point is) seems like a long time for a street car... ie how often do you need to top that water tank up? _________________ 1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
GT BASED CUSTOM BODYKIT
Brisbane , Australia
Think mean think fast
all youll see is
my Porsches Arse!!! |
tuurbo
Posted: Fri Mar 27, 2009 9:38 am Post subject: |
My boost comes on at 1 PSI so it's on even longer. I notice this most when I'm at 70 mph the juice is on quite a lot. I have more than one tank but I think the one in the car is about 7 litres. I've tried the little 1 or 2 litre tanks but I believe bigger is better so I opted for a converted 1 gallon or whatever gas can. It just fits in the back of the vehicle. In fact I just bought another that is I think double - the next size up anyway. I can swap plastic yellow caps and the same pieces will thread onto the new can. I'll just take some black plastic-based spray product and paint the large red one flat black this spring.
I'm sure I don't change it more than every 3rd or maybe 4th tank of gas. I always check it when I fill up the car because it's on the right near the gas hole. I treat my car a bit like an old lady - I don't have long boost sessions because I've been trained to fear running the car hard - every time I do it with impunity something breaks. So I run it at full boost in 2nd, 3rd and 4th gears, on the very occasional night trip in the country, or during the day on on-ramps, but (a) only if everything is running right and (b) just until I find my place in traffic, then I just drive the same as everyone else. Or slower. The boost controller when I put the car up for the winter was at 12 PSI I think when she was sent to hibernate.
I don't know if that helps you gauge it any Scorp - my brother's tank is about as big as our 931 overflow tank and he tops his up every 2nd tank. His is on a lot because he's had serious heat issues with a very high compression setup.
I think the strategy in the industry is to make the small tanks to get you hooked on the product, then up sell you the larger units you will eventually want for big bucks. Some of these tanks are north of a hundred bucks. _________________ 1980 924 turbo, MSD, Meth. Inj, otherwise stock. |
