Adismo
Posted: Fri May 01, 2009 4:59 am Post subject: Coolant temperature sensor wire? |
Where do i have to connect the skyblue/yellow wire ?? i chance all the electric system so i dont know where plug it
[/img] _________________ Porsche 924 1977 XK Euro |
Posted: Fri May 01, 2009 8:47 am Post subject: |
Under the distributor is the coolant flange.
screwed into that is the TTS and temp guage.
Both very hard to see and get to.
If you look in the how-to section there is a pictorial on replacing the motor which has a good picture of the back of the head.
The temp guage wire should be on the blue guage. _________________ Porsche 924 1984 (UK import) NA
Adismo
Posted: Fri May 01, 2009 4:46 pm Post subject: |
| Ozzie wrote: | Under the distributor is the coolant flange.
The temp guage wire should be on the blue guage. |
Ohhh But how is connected becouse the blue gauge doesnt have a plug or yes mmm
Thanks ozzie  _________________ Porsche 924 1977 XK Euro |
Posted: Fri May 01, 2009 5:14 pm Post subject: |
it is a round connector like the head of a nail- you can fit the wire from any direction. _________________ Porsche 924 1984 (UK import) NA
Posted: Fri May 01, 2009 9:36 pm Post subject: |
As Ozzie says...however, the wire in your picture appears to be missing the required female spade adapter, which makes fitment a whole lot easier  _________________ erstwhile owner of just about every 924 variant ever made |
Adismo
Posted: Thu May 07, 2009 4:15 pm Post subject: |
What female adapter is??
rkn
Posted: Thu May 07, 2009 4:34 pm Post subject: |
I think it's the good old #31 _________________ 1980 924NA ROW |
Scorpio
Posted: Thu May 07, 2009 5:20 pm Post subject: |
| Adismo wrote: | What female adapter is??
the male adaptor always inserts into the female adaptor
just think..piipii goes in wiiiwiii _________________ 1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
GT BASED CUSTOM BODYKIT
Brisbane , Australia
Think mean think fast
all youll see is
my Porsches Arse!!! |
Adismo
Posted: Thu May 07, 2009 5:30 pm Post subject: |
| Scorpio wrote: | | Adismo wrote: | What female adapter is??
just think..piipii goes in wiiiwiii | ok jajaja _________________ Porsche 924 1977 XK Euro |
Posted: Thu May 07, 2009 10:16 pm Post subject: |
| rkn wrote: | | I think it's the good old #31 |
Yes. _________________ erstwhile owner of just about every 924 variant ever made |
931blackshirt
Posted: Thu Sep 14, 2023 7:05 am Post subject: 1981 turbo coolant temperature sensor |
| I would like to replace the coolant temperature sensor as a first step to getting my temperature gage to work. My Haynes manual does not appear to include "and turbo" as part of the process to access and replace this sensor. Can anyone list the most straightforward steps to take? Thanks. |
Joined: 29 Jul 2001 Posts: 9134 Location: Royal Oak, MI, USA
Posted: Thu Sep 14, 2023 5:33 pm Post subject: |
It's no different turbo vs. NA.
It's hiding at the back of the head; pain to see/get access to, but not much you can do about that.
Removing the distributor would give good visibility, but then you'd have to fight with the timing to get the engine restarted after. I'd suggest removing the ignition coil instead; not as good visibility, but easy to remove and reinstall without trouble for restarting.
Once you can see it/put a socket on it, pretty straightforward. Maybe drain out coolant to avoid spills, then just disconnect the lead, unscrew the old one, screw in the new and reconnect the lead.
Things to consider while you're back there; you could replace the two twisted little coolant hoses to the heater core. Removing one or both will definitely improve access to the temp sender. But make sure you can source replacements first; I recall hearing they're now hard to come by. _________________ Vaughan Scott
