Coolant temperature sensor wire?
Adismo
PostPosted: Fri May 01, 2009 4:59 am    Post subject: Coolant temperature sensor wire? Reply with quote
Where do i have to connect the skyblue/yellow wire ?? i chance all the electric system so i dont know where plug it
[/img]
Porsche 924 1977 XK Euro
PostPosted: Fri May 01, 2009 8:47 am    Post subject: Reply with quote
Under the distributor is the coolant flange.
screwed into that is the TTS and temp guage.
Both very hard to see and get to.
If you look in the how-to section there is a pictorial on replacing the motor which has a good picture of the back of the head.
The temp guage wire should be on the blue guage.
Adismo
PostPosted: Fri May 01, 2009 4:46 pm    Post subject: Reply with quote
Ohhh But how is connected becouse the blue gauge doesnt have a plug or yes mmm
Thanks ozzie
PostPosted: Fri May 01, 2009 5:14 pm    Post subject: Reply with quote
it is a round connector like the head of a nail- you can fit the wire from any direction.
PostPosted: Fri May 01, 2009 9:36 pm    Post subject: Reply with quote
As Ozzie says...however, the wire in your picture appears to be missing the required female spade adapter, which makes fitment a whole lot easier
Adismo
PostPosted: Thu May 07, 2009 4:15 pm    Post subject: Reply with quote
What female adapter is??
rkn
PostPosted: Thu May 07, 2009 4:34 pm    Post subject: Reply with quote
I think it's the good old #31
1980 924NA ROW
Scorpio
PostPosted: Thu May 07, 2009 5:20 pm    Post subject: Reply with quote
the male adaptor always inserts into the female adaptor
just think..piipii goes in wiiiwiii
1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
GT BASED CUSTOM BODYKIT
Brisbane , Australia
Think mean think fast
all youll see is
my Porsches Arse!!!
Adismo
PostPosted: Thu May 07, 2009 5:30 pm    Post subject: Reply with quote
ok jajaja
PostPosted: Thu May 07, 2009 10:16 pm    Post subject: Reply with quote
Yes.
931blackshirt
PostPosted: Thu Sep 14, 2023 7:05 am    Post subject: 1981 turbo coolant temperature sensor Reply with quote
I would like to replace the coolant temperature sensor as a first step to getting my temperature gage to work. My Haynes manual does not appear to include "and turbo" as part of the process to access and replace this sensor. Can anyone list the most straightforward steps to take? Thanks.
PostPosted: Thu Sep 14, 2023 5:33 pm    Post subject: Reply with quote
It's no different turbo vs. NA.
It's hiding at the back of the head; pain to see/get access to, but not much you can do about that.
Removing the distributor would give good visibility, but then you'd have to fight with the timing to get the engine restarted after. I'd suggest removing the ignition coil instead; not as good visibility, but easy to remove and reinstall without trouble for restarting.
Once you can see it/put a socket on it, pretty straightforward. Maybe drain out coolant to avoid spills, then just disconnect the lead, unscrew the old one, screw in the new and reconnect the lead.
Things to consider while you're back there; you could replace the two twisted little coolant hoses to the heater core. Removing one or both will definitely improve access to the temp sender. But make sure you can source replacements first; I recall hearing they're now hard to come by.
