Boostsideways
Joined: 11 Feb 2009 Posts: 100 Location: CT, Southbury
Posted: Tue May 12, 2009 2:23 am Post subject: Posted this question before but.. |
My car randomly died pulling out of a bad parking lot.. It likes to die out to when coming off highways or after pushing her, have to feather the gas to keep her alive an pull over, kill it, sit for awhile then restart.. I'm noticing im not getting spark.. I checked all m electrical connections nothing seems loose or looks bad.. im even getting volts to the ignition coil(which i replaced Again just encase..) Car cranks and everything but even with a bat charger on it it just cranks really slow and wont ever crank over.. sounds like a dragging crank.. you know, the im out of battery crank kinda only.. without the out of "battery-ness" =p _________________ Just wait 'till my turbo starts firin' the RPM LZR!
My car= Porsche 924 turbo, 1982. |
Posted: Tue May 12, 2009 3:22 am Post subject: |
Might be low voltage (battery and/or alternator and/or wiring to either or both problem). Check your voltage while running however you can. (I use a cig lighter plug with short leads and female spade connectors attached - then attach my multimeter probes to them, and just plug into the cig lighter.. ) _________________ "..it's made in Germany. You know the Germans always make good stuff."
Boostsideways
Posted: Tue May 12, 2009 3:29 am Post subject: |
Like i said the battery is brand new, and testing fine, and im 90% sure my alternator is working. I don't SEE any problems (corroding or anything) with the wires to and from.. _________________ Just wait 'till my turbo starts firin' the RPM LZR!
Posted: Tue May 12, 2009 4:24 am Post subject: |
It's been confirmed ! ! !
Timstar has another brother... |
StienbargerR
Joined: 28 Oct 2005 Posts: 1362 Location: Richmond, IN
Posted: Tue May 12, 2009 4:27 am Post subject: |
what's your voltmeter read while driving? I had a bad alternator one time, and it read pretty low, especially with the lights on. You should probably have it tested. the testing is free and alternators are not that bad to get out. _________________ 1978 924 NA
-250lb lowering springs, Euro Pistons |
Boostsideways
Posted: Tue May 12, 2009 4:47 am Post subject: |
I wish i could tell you what the volts where well driving, the car won't start for nuffin' =/ _________________ Just wait 'till my turbo starts firin' the RPM LZR!
StienbargerR
Posted: Tue May 12, 2009 5:05 am Post subject: |
My money is on the alt. then. You can always try to bump start her. If the dash lights aren't coming on, and she won't bump start, it's likely the alt. _________________ 1978 924 NA
924guy
Posted: Tue May 12, 2009 11:54 am Post subject: |
positive battery cable is shorting out, probably in the area of the exhaust manifold...
replace cable with off the shelf long cable, bridge alt wires to appropriate posts on starter. if you get it wrong, it will not start... _________________ Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha |
Posted: Tue May 12, 2009 4:31 pm Post subject: |
i think it could be ignition related, next time you try to start, turn the ignition distributor slowly (!) to the right.If that makes it start, you had a too early timing.  _________________ NA 924 - april/1977- 4-speed-audi gearbox.
500.000 km with fun.....and new toy:Porsche 944 S2 Cabriolet.Other car Daimler c-class cabby,brandnew..Plus : DEUTZ 4005 tractor Built 1967 |
Boostsideways
Posted: Wed May 13, 2009 12:19 am Post subject: |
Nobbi thanks man I thought it could be that too, but already tested an nothing.. im about to run down and test the alt and check out the positive battery cable for shorts.. Hey i noticed you know that ground wire that goes to my ignition coil? it sparks ? _________________ Just wait 'till my turbo starts firin' the RPM LZR!
Boostsideways
Posted: Thu May 14, 2009 1:30 pm Post subject: |
also like to add, this was probably a important note, my apologize to the board members, im doing a spark plug spark test, (tried more then once to make sure) an' no spark.. _________________ Just wait 'till my turbo starts firin' the RPM LZR!
924guy
Posted: Thu May 14, 2009 8:01 pm Post subject: |
test coil as per haynes... _________________ Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Scorpio
Posted: Thu May 14, 2009 8:08 pm Post subject: |
p.s change your avatar....square cars scare me  _________________ 1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
GT BASED CUSTOM BODYKIT
Brisbane , Australia
Think mean think fast
all youll see is
my Porsches Arse!!! |
rkn
Posted: Thu May 14, 2009 8:45 pm Post subject: |
 _________________ 1980 924NA ROW |
D Hook
Posted: Thu May 14, 2009 9:22 pm Post subject: |
^^^Must be the newest GM/Chrysler design work.
You can certainly see the government's influence. _________________ '80 924 n/a SOLD |
