Posted this question before but..
Boostsideways
PostPosted: Tue May 12, 2009 2:23 am    Post subject: Posted this question before but.. Reply with quote
My car randomly died pulling out of a bad parking lot.. It likes to die out to when coming off highways or after pushing her, have to feather the gas to keep her alive an pull over, kill it, sit for awhile then restart.. I'm noticing im not getting spark.. I checked all m electrical connections nothing seems loose or looks bad.. im even getting volts to the ignition coil(which i replaced Again just encase..) Car cranks and everything but even with a bat charger on it it just cranks really slow and wont ever crank over.. sounds like a dragging crank.. you know, the im out of battery crank kinda only.. without the out of "battery-ness" =p
Just wait 'till my turbo starts firin' the RPM LZR!
My car= Porsche 924 turbo, 1982.
PostPosted: Tue May 12, 2009 3:22 am    Post subject: Reply with quote
Might be low voltage (battery and/or alternator and/or wiring to either or both problem). Check your voltage while running however you can. (I use a cig lighter plug with short leads and female spade connectors attached - then attach my multimeter probes to them, and just plug into the cig lighter.. )
Boostsideways
PostPosted: Tue May 12, 2009 3:29 am    Post subject: Reply with quote
Like i said the battery is brand new, and testing fine, and im 90% sure my alternator is working. I don't SEE any problems (corroding or anything) with the wires to and from..
PostPosted: Tue May 12, 2009 4:24 am    Post subject: Reply with quote
It's been confirmed ! ! !
Timstar has another brother...
StienbargerR
PostPosted: Tue May 12, 2009 4:27 am    Post subject: Reply with quote
what's your voltmeter read while driving? I had a bad alternator one time, and it read pretty low, especially with the lights on. You should probably have it tested. the testing is free and alternators are not that bad to get out.
1978 924 NA
Boostsideways
PostPosted: Tue May 12, 2009 4:47 am    Post subject: Reply with quote
I wish i could tell you what the volts where well driving, the car won't start for nuffin' =/
StienbargerR
PostPosted: Tue May 12, 2009 5:05 am    Post subject: Reply with quote
My money is on the alt. then. You can always try to bump start her. If the dash lights aren't coming on, and she won't bump start, it's likely the alt.
1978 924 NA
924guy
PostPosted: Tue May 12, 2009 11:54 am    Post subject: Reply with quote
positive battery cable is shorting out, probably in the area of the exhaust manifold...
replace cable with off the shelf long cable, bridge alt wires to appropriate posts on starter. if you get it wrong, it will not start...
Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha
PostPosted: Tue May 12, 2009 4:31 pm    Post subject: Reply with quote
i think it could be ignition related, next time you try to start, turn the ignition distributor slowly (!) to the right.If that makes it start, you had a too early timing.
Boostsideways
PostPosted: Wed May 13, 2009 12:19 am    Post subject: Reply with quote
Nobbi thanks man I thought it could be that too, but already tested an nothing.. im about to run down and test the alt and check out the positive battery cable for shorts.. Hey i noticed you know that ground wire that goes to my ignition coil? it sparks ?
Boostsideways
PostPosted: Thu May 14, 2009 1:30 pm    Post subject: Reply with quote
also like to add, this was probably a important note, my apologize to the board members, im doing a spark plug spark test, (tried more then once to make sure) an' no spark..
924guy
PostPosted: Thu May 14, 2009 8:01 pm    Post subject: Reply with quote
test coil as per haynes...
Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Scorpio
PostPosted: Thu May 14, 2009 8:08 pm    Post subject: Reply with quote
p.s change your avatar....square cars scare me
1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
GT BASED CUSTOM BODYKIT
Brisbane , Australia
Think mean think fast
all youll see is
my Porsches Arse!!!
rkn
PostPosted: Thu May 14, 2009 8:45 pm    Post subject: Reply with quote
1980 924NA ROW
D Hook
PostPosted: Thu May 14, 2009 9:22 pm    Post subject: Reply with quote
^^^Must be the newest GM/Chrysler design work.
You can certainly see the government's influence.
'80 924 n/a SOLD
