peterld
Joined: 10 Dec 2006 Posts: 987 Location: Noosa Heads QLD Australia
Posted: Mon Jun 29, 2009 12:09 am Post subject: Here we go Again - Another NLA Toofah Part! |
Hi Guys - Anybody know of anywhere/anyone who might stock Little End Bushes p/n 059 105 431 for the 924/931 con rod?
I have obviously tried all the usual suspects such as EBS, Paragon, Auto.Az, etc. Is there somebody else I should be trying?
Cheers Pete |
Posted: Wed Jul 01, 2009 12:46 am Post subject: |
About 3-4 years ago a porsche master mechanic friend handed me a set and said "Hang onto these, they're getting hard to find..." which was code for: Porsche was going to stop making them available...
I believe they're NLA. If you find someone with a NOS set sitting on a shelf, buy the set, or maybe two because they're getting hard to find... |
peterld
Posted: Wed Jul 01, 2009 7:41 am Post subject: |
Yup! NLA! Wanna sell your set? Or two or three?
Geez this is getting to be a real pain in the a... |
Raceboy
Posted: Wed Jul 01, 2009 4:22 pm Post subject: |
I've had them made. Not for stock 24mm wrist pins but for 22mm pins to use VW flat top pistons... Cost me around 50usd for all four and get them installed. _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
peterld
Posted: Wed Jul 01, 2009 10:04 pm Post subject: |
| Hi Raceboy - made from what? Did you use bronze or brass? |
Posted: Wed Jul 01, 2009 10:14 pm Post subject: |
Yeah, I can't imagine these bushes being that big of a deal...seems like it should be pretty easy to have a reasonably equipped machine shop turn some out on a lathe...
...I hadn't encountered this yet because my Crower rods have integral bushes. At the moment, I am leaning toward stock rods with clearanced block on the post-UWB stroker that is in the works, so I will need these eventually.
Pete, I'm sure you can find a machine shop there to do the work, but if you guys want, I can certainly look into having some made up over here. Or maybe min could do some on his lathe? Or maybe there's an interchange available somewhere? What are the specs on the bush, anyone know? _________________ erstwhile owner of just about every 924 variant ever made |
El Chato
Posted: Thu Jul 02, 2009 1:35 am Post subject: |
this is one more part that I have no idea what it is, but i keep reading to learn more, _________________ 1979 924 N/A, Snail Shell
1980 924 N/A
1976 924 N/A
It may be that your whole purpose in life is simply to serve as a warning to others.
Today's weirdness is tomorrow's reason why. |
Posted: Thu Jul 02, 2009 1:53 am Post subject: |
El Chato
Posted: Thu Jul 02, 2009 7:32 am Post subject: |
thanks Ideola, preciate it _________________ 1979 924 N/A, Snail Shell
1980 924 N/A
1976 924 N/A
peterld
Posted: Sat Jul 04, 2009 11:32 am Post subject: |
| OK guys, I've finally got some measurements. Width of little end of con rod is 28mm. Internal diameter is 24mm ie. wrist pin contact area. While the external diameter is 27.5mm. The guy who took the measurements says the bush appears to be made from steel!!! Can anyone who has a con rod handy confirm what the bushing material is made from. On such a vital part, given I'm going to have to find someone to make something up, I certainly don't want to stuff up. Thanks Pete |
Min
Posted: Sat Jul 04, 2009 4:22 pm Post subject: |
Aluminum bronze is a common material for this part.
fox 20_12
Joined: 17 Jun 2009 Posts: 13 Location: Maple lake, Minnesota
Posted: Sat Jul 04, 2009 10:30 pm Post subject: |
It's definitely not steel, it's a bronze alloy. Your machine shop will have this material in stock. _________________ Teaching my son that there is just as much fun knowing how your car works as there is driving it.
1981 931 |
gegge
Posted: Fri Feb 26, 2016 7:15 am Post subject: |
According to Kolbenschmidt it is actually made of sintered copper lead on steel base _________________ Carl Fredrik Torkildsen
daniel
Posted: Fri Feb 26, 2016 8:02 am Post subject: |
| Quote: |
According to Kolbenschmidt it is actually made of sintered copper lead on steel base |
I think that may be talking about big end and main bearings
PeterID, I have had this done cheaply by engine machinist in the past. I can recommend a guy I use in Sydney: Harris engines, cnr Queen St & Milperra Rd Revesby _________________ Over the top of skyline, total brake failure.... hit the wall at over 200 kp/h at the dipper, so anyone who has to brake for the esses is a pussy.
1989 944 Cabriolet |
gegge
Posted: Fri Feb 26, 2016 8:23 am Post subject: |
The small end bushing:
https://infopart.org/audi-059105431-part
Manufacturer AUDI
Number 059 105 431
KOLBENSCHMIDT 74254690
Description Small End Bushing, connecting rod
Available Undersizes SEMI
To shaft diameter [mm] 24
For housing diameter from [mm] 27
To housing diameter [mm] 27.021
Width 1 [mm] 27,8
Supplementary Article/Supplementary Info 2 Sintered copper lead on steel base
Cross numbers AE GS399SASEMI
AE S4646LSEMI
AUDI 059105431
GLYCO 552527SEMI _________________ Carl Fredrik Torkildsen
