Need help selecting wheels
Octane
PostPosted: Mon Jul 27, 2009 1:07 pm    Post subject: Need help selecting wheels Reply with quote
I came across a set of wheels I really like on eBay, I was looking at less-expensive Rota's, Enkei's, etc. I have always had good luck with Enkei rims so I think these would be a pretty good buy.
I have a '77 924 N/A with the stock 4-bolt (4x108?) bolt pattern. Where I am lost is the wheel offsets and widths. The wheels I am looking at are a 15x6.5 with a 38 offset. I don't want to go bigger than 16" or 7" wide. Will these fit without spacers or anything? Seems like a pretty basic offset but I just wanted to check before I pulled the trigger. Thanks...
http://cgi.ebay.com/ebaymotors/4-NEW-15x6-5-4x100-4x108-Enkei-J10-Wheels-Rims_W0QQcmdZViewItemQQ_trkparmsZQ7c293Q3a1Q7c294Q3a30QQ_trksidZp4634Q2ec0Q2em14Q2el1262QQhashZitem53dac8ebd3QQitemZ360152886227QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
- Brendan
1977 Porsche 924
Octane
PostPosted: Mon Jul 27, 2009 1:09 pm    Post subject: Reply with quote
Also, what would I be looking at for tire sizes for those wheels? Thanks.
- Brendan
1977 Porsche 924
Vince Ponz
PostPosted: Tue Jul 28, 2009 3:10 am    Post subject: Reply with quote
This may sound silly but I had 205s Yokahamas on the 14in rims stock and I liked the ride and the handling. With the money saved if I were you would be to lower car front and rear and with competition pads you will have a ncice car. Add larger swaybars front and rear.
I speak from little experience. These cars can take all your money for little gain. Ask me how I know.
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock
billson
PostPosted: Tue Jul 28, 2009 5:06 am    Post subject: Reply with quote
Wheel offset is the distance between the centre of the wheel and the hub mounting point. The higher the offset, the further away the hub mounting is, and hence the further towards the inside of the car the wheel will sit on the hub.
Try this
http://www.1010tires.com/WheelOffsetCalculator.asp
Your new wheels will be 11mm closer to suspension and the wheel will stick out a further 1mm. Might be a bit tight. See if you can measure the gap between the stock wheel and the suspension to see you much room you have to play with.
195/60/15 tires would be exactly the same size/height as the stock ones (assuming you have 185/70/14 ?) Have a look at this page
http://www.tyresave.co.uk/tyresize.html
1983 924 NA
Guards Red
Carrera GT bodykit
Larger VW throttle body
tuurbo
PostPosted: Tue Jul 28, 2009 11:51 pm    Post subject: Reply with quote
If you go aftermarket get 5 spoke, dude.
1980 924 turbo, MSD, Meth. Inj, otherwise stock.
texastwofour
PostPosted: Sat Aug 15, 2009 11:36 am    Post subject: old Ford/Mercury wheels Reply with quote
There are a lot of older wheels like this on ebay. I think some of them are pretty cool looking if you removed the centercap. I picked up a similar set for $50.
Most of the older wheels are 15" but there are some 16" out there. Offset again is hit or miss so ask the seller, and some may need spacers. Make sure you ask how heavy they are too, as adding heavier wheels is a big performance negative. Also, they tend to be either 6 or 7 inches wide so you don't add a lot of width, but I'm not sure that there is a lot to be gained with a real wide tire on these cars anyway. There is no question, however, that lower profile tires, and a stiffer tire/rim combo will improve handling. Alhtough I like the OEM wheels, 14 inches with a 70 or 75 aspect ratio tire leaves a lot of room for improvement. Like everything else, wheel technology has improved in the last 30 years.
TX24
'79 924 NA
WIP!
texastwofour
PostPosted: Sat Aug 15, 2009 11:37 am    Post subject: Reply with quote
here's the wheel link:
http://cgi.ebay.com/ebaymotors/Mercury-Wheels-Ford-front-drive-wheels_W0QQcmdZViewItemQQ_trksidZp3286Q2ec0Q2em14QQhashZitem35a2e00c16QQitemZ230365858838QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
TX24
'79 924 NA
WIP!
Rocco R16V
PostPosted: Sat Aug 15, 2009 4:08 pm    Post subject: Reply with quote
I like those 10 spoke enkei's and think they would look great.
when considering wheels, lighter is better! heavy wheels will really hurt performance. those enkeis look like they would be light too!
I would recomend 205/60/15
"Government exists to protect us from each other. Where government has gone beyond its limits is in deciding to protect us from ourselves. "
Ronald Reagan
