mikebola
Joined: 07 Sep 2009 Posts: 361 Location: Parkside, PA
Posted: Sun Sep 13, 2009 2:51 pm Post subject: Passenger window won't go back up! |
| I recently purchased a '79 924, and after working on the electrics for a week, I got most of the wiring sorted out. The thing is, the passenger window will only go down. If I reverse the leads to the motor, it will go up. I've tried 3 sets of switches, including two known working ones (I eventually tested out all 7 of the switches on the drivers' side window). I looked at wiring diagrams, but no luck there. Anyone see something like this happen before? |
Posted: Sun Sep 13, 2009 4:55 pm Post subject: |
Have you inspected the wiring harness connectors on BOTH sides? They sit behind the kick panels, and you can access them by removing the carpet there and fishing them through a hole in the sheet metal that is about 3" in diameter. It sounds like you have a bad connection somewhere on the passenger-side up circuit, and these would be the next places to check. The pins could be loose, corroded, or even the wires could be broken going to the pins. It's not uncommon to see lots of moisture get into those areas and cause problems with corrosion. _________________ erstwhile owner of just about every 924 variant ever made |
mikebola
Posted: Mon Sep 14, 2009 10:54 am Post subject: |
Yep. That was it. One of the wires was actually broken at the gaiter. I'm gonna replace the line tomorrow and see what happens. (now I have another dozen questions...)
Thanks! |
Posted: Mon Sep 14, 2009 11:01 am Post subject: |
| mikebola wrote: | Yep. That was it. One of the wires was actually broken at the gaiter. I'm gonna replace the line tomorrow and see what happens. (now I have another dozen questions...)
Thanks! |
Cool, that's what we're here for  _________________ erstwhile owner of just about every 924 variant ever made |
