Rear flare dilemna
Scorpio
PostPosted: Fri Jun 12, 2009 3:28 pm    Post subject: Rear flare dilemna Reply with quote
While fitting the rear GT flares ive found my wheels to sit too far forward in the arch
ie not equidistant from flare sides....ive also custom fit a slotted 944 turbo rear valance
1) Is a rear wheel that sits a little too far forward in the rear arch a mortal porsche sin?
2) Those thin GT side skirts ....how did people attach them and did they mould theirs in?
1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
GT BASED CUSTOM BODYKIT
Brisbane , Australia
Think mean think fast
all youll see is
my Porsches Arse!!!
PostPosted: Fri Jun 12, 2009 5:21 pm    Post subject: Reply with quote
its the way it is...i bashed my head against the wall with this issue too..if you install them according factory specs the wheels will always sit too much to the front of the car...and nomatter what you do the car will look like a tram from the front semi-profile.
one way would be to mount the flares more to the front end...or modify them a little...
the big gap at the back of the wheels is a necesary aerodinamics thing tho...search around the internet for this thing..
PostPosted: Fri Jun 12, 2009 9:10 pm    Post subject: Re: Rear flare dilemna Reply with quote
I'm not happy with them at all - thinking about other options...
Vince Ponz
PostPosted: Sat Jun 13, 2009 4:54 am    Post subject: Reply with quote
My GT flares were thin and that is why I put about 5 layers of FG on the underside. The flares have a 2 in lip to attach to the body. I drilled through the outer and drilled a smaller hole to put screws to mount the flare. Then after they were bolted on I filled in the outer holes.
We bonded with FG glue, the flares and bolted them to the body. Filled in the spaces with bondo and smoothed all surfaces..
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock
Scorpio
PostPosted: Sat Jun 13, 2009 9:08 am    Post subject: Reply with quote
Thanks Vince was actually looking to do the same method..lucky for me my glasser made my flares nice and thick..
what im more interested about is how people attached those thin side skirts?
1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
all youll see is
my Porsches Arse!!!
PostPosted: Sat Jun 13, 2009 1:15 pm    Post subject: Reply with quote
From memory there are tabs along the top - they looked conspicuously like something to hold bolts/rivets etc. Maybe Fezza can chime in...
Scorpio
PostPosted: Sat Jun 13, 2009 2:12 pm    Post subject: Reply with quote
im pretty sure tabs go along the bottom to push the skirt out a bit
1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
all youll see is
my Porsches Arse!!!
PostPosted: Sat Jun 13, 2009 6:40 pm    Post subject: Reply with quote
Quite possibly. It's been 18 months since I even looked at mine...
(you back home yet?)
Vince Ponz
PostPosted: Sat Jun 13, 2009 11:02 pm    Post subject: Reply with quote
Skirts in the US cover the wheel arch on the rear of cars.
If you have tabs on the flares that is where they get attached. Use the method I wrote above. Problem is what do you do with the spaces next to the tabs. As I said I not only bolted them on I also used an epoxy to bond the flares on.
79 931 Euro stock
88 924S SE
87 911 Targa stock
tuurbo
PostPosted: Sun Jun 14, 2009 12:10 am    Post subject: Reply with quote
Pics would help Scorpio - ya got any? Or can you point me to the thread that has some pics?
Any update?
1980 924 turbo, MSD, Meth. Inj, otherwise stock.
PostPosted: Tue Jun 16, 2009 4:38 pm    Post subject: Reply with quote
Pics man ya gotta have some pics.
Scorpio
PostPosted: Tue Jun 16, 2009 4:58 pm    Post subject: Reply with quote
Boys Boys Boys......its hard cause pics at the moment will seriously ruin my custom rear flare vent design...
1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
all youll see is
my Porsches Arse!!!
Scorpio
PostPosted: Mon Oct 12, 2009 10:38 pm    Post subject: Reply with quote
ok rear flare side 1 is 90 percent done...some welding some riveting reinforcing bar...a bit of fibreglassing etc etc.....ohhh and my custom vent design....guaranteed to slow the car down..but looks hella mean!
1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
all youll see is
my Porsches Arse!!!
ZODIAC
PostPosted: Tue Oct 13, 2009 2:42 am    Post subject: Reply with quote
but really, i want to see this beast pretty bad...
"Kraut cars, they know how to build 'em".
1977 924 N/A - Red with waterdamage interior
yes...waterdamage is now a color...
Kroggers
PostPosted: Tue Oct 13, 2009 3:02 am    Post subject: Reply with quote
+1
Kroggers
CoolCavaRacing.com
1983 924 (aka Scruffy)
1978 911SC (aka Wanda)
