warning with new springs..
paulsmaroon924
PostPosted: Wed Nov 11, 2009 10:53 pm    Post subject: warning with new springs.. Reply with quote
got my new front springs delivered today, basically 30mm reduction in ride height with a stiffer spring.
it says on the warning with the springs, BEFORE FITTING BUMP STOPS MUST BE REDUCED BY MINIMUM 20mm
where and how T.F. would one go about doing this AND more importantly IS it necessary?
bemused, confused, not amused.
RC
PostPosted: Thu Nov 12, 2009 12:26 am    Post subject: Re: warning with new springs.. Reply with quote
20mm up from the bottom (larger end). A hacksaw will be fine.
Most likely, or they wouldn`t advise it.
Hardly rocket science, if the distance between the top of the strut and the upper mount is reduced 30mm, even with heavier springs the standard length bump stop will be too long for proper travel without bottoming out.
Think Koni bump stops are shorter. Better using shorter new ones if you can find something at local suspension shop or cutting down new OE ones. Generic VW Golf parts IIRC and very cheap. 30yo rubber will be quite deteriorated by now and possibly split even if cut down.
PostPosted: Thu Nov 12, 2009 12:44 am    Post subject: Reply with quote
What he said - you don't want to be cornering on your bumpstops! Just get new ones, the old ones will be shot likely...
paulsmaroon924
PostPosted: Fri Nov 13, 2009 1:17 am    Post subject: Reply with quote
coolio can and where would i get new ones and ones that are made for the shorter springs?
thanks guys
PostPosted: Fri Nov 13, 2009 1:29 am    Post subject: Reply with quote
Here in the states, Paragon is one of the better sources for suspension components. Not sure about your side of the pond. If you call them, ask for Jason.
Rocco R16V
PostPosted: Fri Nov 13, 2009 3:44 am    Post subject: Reply with quote
prothane makes a universal urathane "adjustable" bump stop kit thats pretty cheap. adjusted by how many stacking pieces are used.
"Government exists to protect us from each other. Where government has gone beyond its limits is in deciding to protect us from ourselves. "
Ronald Reagan
flosho
PostPosted: Fri Nov 13, 2009 7:16 am    Post subject: Reply with quote
Interesting that I missed this memo on my weltmiester springs..
[This Space For Rent]
PostPosted: Fri Nov 13, 2009 6:57 pm    Post subject: Reply with quote
Probably no problem, at least on my car. The welt 250 springs made it barely lower than stock, and about twice that stiff.
Brockoli
PostPosted: Sat Nov 14, 2009 3:31 am    Post subject: Reply with quote
I thought I read somewhere the bilstien HD shocks for 924's have a bump stop inside them so i didnt need to buy new bump stops. or am I very wrong??
'80 924 M471,Wideband O2, Full coilover susp,23/19 sways,Bilstiens,KLA Strut Brace,Roll Bar,Test Pipe,BBS RS, Willwood BBK
'79 924 Sebring Edition(Sitting)
paulsmaroon924
PostPosted: Sat Nov 14, 2009 4:41 am    Post subject: Reply with quote
i have some issues with the springs as i noticed they are chipped from the transit so ill be contacting the company that made them, ill be able to ask them directly about it then.
cheers lads
jazz guy
PostPosted: Sat Nov 14, 2009 4:58 am    Post subject: Reply with quote
Brockoli wrote:
I thought I read somewhere the bilstein HD shocks for 924's have a bump stop inside them so i didnt need to buy new bump stops. or am I very wrong??
Chrenan was the first one to say this on our board. I just got some Bilstein HD's for my 931. The documentation that came with the struts said that they have an internal bump stop and not to use an additional bump stop. I guess I'll believe them, besides the normal bump rubber won't fit the HD strut shaft which has a much larger diameter.
Brockoli
PostPosted: Sat Nov 14, 2009 7:39 am    Post subject: Reply with quote
jazz guy - you are right, it was Chrenan, I think he told me that in person, lol. my memory is great
smither
PostPosted: Sun Dec 13, 2009 10:14 pm    Post subject: Reply with quote
Hi
I've got Bilsteins aswell and could not get the bump stop to fit. I did read somewhere about an internal bumpstop, guess it makes sense as there really is no way to make the original stop fit.
1978 NA 924 dogleg
1971 Triumph Gitfire with ashley hardtop
2000 MGF (for the wife)
