| How old should the little guy be before he starts pulling wrenches? |
| He should be already! |
21% |
[ 5 ] |
| 1 |
4% |
[ 1 ] |
| 2 |
4% |
[ 1 ] |
| 3 |
17% |
[ 4 ] |
| 5 |
30% |
[ 7 ] |
| 10 |
21% |
[ 5 ] |
| Total Votes : 23 |
!tom
Posted: Sat Dec 12, 2009 5:09 pm Post subject: The Ultimate Father Son Project |
Well, it's time I start my own thread here with my own ideas.
I've started collecting parts for my own project. However, I don't have a plan yet.
So, hopefully I can come up with a plan with the help of all of you guys.
My son is turning 9 months old next week, so there's a bit of time to finalize the plans before work begins.
Stage 1
5-lug kit that I've verbally committed to buying from CBass.
Stage 2
Engine refresh
New lifters (from Newmans)
Euro pistons (from Raceboy)
New bearings (from Dan)
New rod bolts, head studs (from Dan)
Still need to think about other bits, such as seals, gaskets, oiler elbow, etc.
I'm also thinking about the EuroRace Big Valve job.
And, I'm also thinking about a Cometec head gasket.
Cam? Read on for things that may influence this choice. However, given the new lifters, it's probably a good idea to replace the cam at the same time.
Coolant flow modifications? What's the best way to route the coolant flow so that there is still cabin heat.
Stage 3
Megasquirt.
Min, I might be calling on you.
Stage 4
Supercharger!
RC, I might be calling on you.
Lotsa choices. What thickness head gasket would I want? What type of blower would I want? Size of intercooler? These things all depend on the target goals, which I haven't worked out yet.
Oil cooler will be needed at this stage too, I'm sure.
Goals
So, the type and size of blower depend on the HP goals, which dictate the I/C size, and the C/R.
So, just to toss a number around, 200 HP?
Raceboy says the 924 starts to fall apart with more than this, and nowhere in my plans so far have I considered any 931/924S/944/951/968 driveline stuff. It's a nice round number, sounds like it should be possible to achieve with this method without too much grief, and should be plenty.
Let the discussion begin!
I'm still at the parts acquisition phase, so I need some help formulating my ideas. I'd like to keep track of everything here so I don't loose track of it. _________________ 78 924 NA
5-lug
Vince Ponz
Posted: Sat Dec 12, 2009 11:42 pm Post subject: |
I started late with my sons. They were 12 and 14 when I attempted to get them interested in cars. I bought them an Austin Healey Bugeye Sprite. _________________ "Never let them see you sweat"
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock |
924guy
Posted: Sat Dec 12, 2009 11:55 pm Post subject: |
I think i was four or five when i started showing a mechanical aptitude, by dissection of the household telephones and appliances looking for the little people inside them... never did find any Lilliputians though. I was about ten when i started rebuilding motorcycle engines, which then evolved into cars.
I would suggest not over encouraging , let the little guy develop his own interest and make it fun. when hes old enough to want to help, give him jobs he can complete on his own and achieve success, with progressively more difficult tasks. before you know it, hell be an ace mechanic and dragging home junk lawnmowers to build his own go carts with...  _________________ Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha |
Posted: Sun Dec 13, 2009 12:13 am Post subject: |
| Quote: | I bought them an Austin Healey Bugeye Sprite.
...and they haven't turned a wrench since.
I think car guys know who they are at a early age. I used to tie a small plastic indy car to the back of my bike and drag it around the court like a madman in the most incredible power slide ever (string taught, car barely on the ground, the first drifting ever, I'm sure of it). But that wasn't because my dad wanted me to do it, I did it because it was fun and there wasn't anything I could think of that was more fun than that.
So I guess my point is that if they're interested, they'll come to you. Have him around handing you wrenches as you work on the car. He'll ask questions, probably lots of them. And he'll wander off when he gets bored (in 10 sec or 10 min or 10 hours, depending on age and level of "carguyedness"). Be patient, encourage him, and if he's into it, there will be *nothing* more interesting that all things mechanical.
You'll know... |
Posted: Sun Dec 13, 2009 12:28 am Post subject: |
Fun thread! I like this: 'dragging home junk lawnmowers to build his own go carts with.' My buddies and I would go to junkyard, see a lawnmower wheel sticking out of the ground, and start digging. Then we'd drag it home behind our bikes, then cobble parts from 2-3 mowers, and then cut the lawn. My mother was always not far away with a fire extinguisher!
My heritage goes back to both grandfathers. One would have the engine from his Model A Ford laid out in pieces, and the other was a farmer. My Dad was a farmer till he was 32 and then ran or owned farm equipment dealerships. Unfortunately for me, he hated the business and wouldn't let us kids on the property. So, spinning wrenches didn't happen till I was in my 30's. Lots of money 'well' spent since then!
PS, the wife and I have 10 vehicles between the two of us, not counting the WD-45 early '50s Allis Chalmers weed-cutting tractor we have. _________________ '83 944 Track car.
2001 Ford F350 powerstroke |
Vince Ponz
Posted: Sun Dec 13, 2009 1:18 am Post subject: |
Mr.Moore you hit the nail on the head. We never drove the car after a full restoration. It was easier to drive the wifes 5 series BMW or the Acura Legend coupe. It sat in the yard for a long time until I gave it to a friend. _________________ "Never let them see you sweat"
79 931 Euro stock
88 924S SE
Joined: 29 Jul 2001 Posts: 9118 Location: Royal Oak, MI, USA
Posted: Sun Dec 13, 2009 4:01 am Post subject: |
They're never too young... we have a great pic of my crew chief's younger boy in a stroller at the ripe age of maybe 1 and change, in a Mid-Ohio t-shirt (at the racetrack of course), teething on a Longacre tire gauge!!
But it takes the personality, too. He's very much interested in things mechanical. His older brother, OTOH, doesn't care about the mechanicals, only wants to go fast. So, looks like we have a great crew chief/driver team in the making! LOL
Now give 'em another 10 years to get their licenses... _________________ Vaughan Scott
PORSCHEV
Posted: Sun Dec 13, 2009 4:49 am Post subject: |
Not sure what a good age is.... I have tried to get my son into cars by getting him a kart. He liked it for a short time then lost interest. Now he has a 4 wheeler.....seems to rather play video games. He is 10 right now.
I figure it might take him until 16 when he can drive before he really gets into it...maybe never? _________________ 1976 924
1978-#53 "D" track racer. |
!tom
Posted: Sun Dec 13, 2009 6:57 am Post subject: |
Guys, the point of this isn't supposed to be about the father-son aspect, it's supposed to be about the project plans.
If he's not going to be interested, he'll do something else. He's a bit young to ask now, and I'm not going to be forcing him to work on this project if his interests lie elsewhere. He certainly likes playing with tools, wheels and screws now though.
I just thought it would be a fun father-son project -- we'll see if he's interested in due time.
I added the poll as an after-thought, thinking it might be funny.
I know I would have enjoyed a project like this when I was little.
So, although these anecdotes are welcome, let's talk compression ratios, cam shafts, ignition systems, and all that good stuff! _________________ 78 924 NA
5-lug |
Min
Posted: Sun Dec 13, 2009 4:06 pm Post subject: Re: The Ultimate Father Son Project |
| !tom wrote: |
Megasquirt.
Min, I might be calling on you. |
woo woo, bring it on
joecitizennn
Posted: Sun Dec 13, 2009 10:20 pm Post subject: |
| I think I started out taking apart toy tractors and RC cars when I was 4 or 5 to modify or fix them. Naturally my broken-to-fixed ratio got better as I got older. I didnt take a interest to working on automobiles till I was older and got my own. Be careful not to force cars and mechanics on him or he may grow up not liking them. I am sure if you simply raise him around the stuff he will take to it on his own. |
joecitizennn
Posted: Sun Dec 13, 2009 10:23 pm Post subject: |
| oh yeah. keep him away from tv as much as you can. Kids seem to imprint on the tv rather than their parents, and then they have less interest in being like their parents. |
Posted: Sun Dec 13, 2009 11:23 pm Post subject: |
Limited to stock cam, 9.5:1 CR we're getting about 135 hp out of the NA. That's with .040 overbore, balanced but not lightened, fresh stock top end (no big valves, just the stock later bigger ones), and header and race exhaust (not suitable for street use). Stock intake too, including stock CIS.
With a cam, maybe some lightening, maybe a scotch more CR, I'd imagine around 150-160 or so should be possible, and would be quite fun.
Megasquirt would be a nice addition, and likely free up maybe 5 hp peak, not more than 10, but probably build a lot of area under the curve.
But I couldn't see it exceeding around 165 or so without boost. _________________ Vaughan Scott
Rocco R16V
Posted: Mon Dec 14, 2009 5:33 am Post subject: |
| joecitizennn wrote: | | oh yeah. keep him away from tv as much as you can. Kids seem to imprint on the tv rather than their parents, and then they have less interest in being like their parents. |
I agree but beware there is a natural instinct to rebel and want to be nothing like your parents once they reach puberty. _________________ "Government exists to protect us from each other. Where government has gone beyond its limits is in deciding to protect us from ourselves. "
Ronald Reagan |
Min
Posted: Mon Dec 14, 2009 6:33 am Post subject: |
I haven't had a TV for the past 11 years, it was one of the best decisions we ever made regarding raising our kids.
