Ceramic Exhaust Coatings
PostPosted: Wed Jun 02, 2010 3:39 pm    Post subject: Ceramic Exhaust Coatings Reply with quote
These coatings work, work, work, period. No brainer level, especially on a 931 (manifold, hotside, downpipe, if you please). Wow.
And if you also do your head (exhaust ports, valve faces, combustion surface) and pistons? Erg. . .
PostPosted: Wed Jun 02, 2010 8:08 pm    Post subject: Reply with quote
PostPosted: Wed Jun 02, 2010 8:43 pm    Post subject: Reply with quote
its normal to act like this....you know..the moments right before actually getting in and enjoying the fruits of your work...many strong man have lost controll and sprayed just moments before actually doing it
PostPosted: Wed Jun 02, 2010 9:03 pm    Post subject: Re: Ceramic Exhaust Coatings Reply with quote
Rasta Monsta wrote:
Work, work, work, period.
Welcome to my world, Monsta.
skemcin
PostPosted: Wed Jun 02, 2010 9:55 pm    Post subject: Reply with quote
Does any of that heat (now that it's not escaping) do any harm being contained? The heat has to be channeled somewhere - so its either back up to the block (higher running temperature) or out the back (hotter exhaust) so are either subject to problems as a result? Or do the ceramics truly absorb the heat?
Interesting, nonetheless. I'm not sure if you posted a thread on the process - but did you DIY with something like this:
http://www.amazon.com/Techline-Ceramic-Exhaust-Coating-High-Temperature/dp/B001E6FLBW
924.org (no time to complete)
9249206347 - 8k – waiting its resurrection, no power at the fuel pump and fuse #7 blows w/power
Rich H
PostPosted: Wed Jun 02, 2010 10:01 pm    Post subject: Reply with quote
Quote:
What's the difference between a duck?
One of it's legs is both the same.
PostPosted: Wed Jun 02, 2010 10:09 pm    Post subject: Reply with quote
Actually, it does the opposite of what you're thinking. The ceramic keeps the heat IN the gas so that it doesn't radiate or convect into the metals. This has two primary benefits: keeps the engine components themselves cooler, and keeps the exhaust gases moving as fast as possible (i.e. they escape faster!). On a turbo, this is particularly helpful since it's the exhaust gases that cause the turbine to spin; keeping the heat IN those gases helps with turbo spooling and theoretically reduces lag.
skemcin
PostPosted: Wed Jun 02, 2010 10:18 pm    Post subject: Reply with quote
Ahh, I see. Thanks for the explanation. So this, ideally, is applied like a powder coating spray and back - I'm assuming.
PostPosted: Wed Jun 02, 2010 10:31 pm    Post subject: Reply with quote
Did you mean "spray and bake"? If so, the answer is yes, the ceramics are baked on. I'm having my exhaust components ceramic coated inside and out, while the turbine will only be on the outside. The ceramics also prevent corrosion. I'll be doing the manifold, the j-pipe, the wastegate dump pipe at a minimum. I am also hoping to do the primary exhaust (that connects directly to the turbo) and the cat-delete section.
skemcin
PostPosted: Wed Jun 02, 2010 11:18 pm    Post subject: Reply with quote
back - bake - yes, I meant bake sorry for the typo.
Is this for the UWB or the 924CS?
PostPosted: Thu Jun 03, 2010 12:38 am    Post subject: Reply with quote
Both The UWB manifold and turbine are already done. I have a pile of exhaust parts, enough for three cars, on my garage floor, waiting to go to the coaters. Now that I have the j-pipes back, I can run them over there to have the coating done.
PostPosted: Thu Jun 03, 2010 1:52 am    Post subject: Reply with quote
During the cam break-in (which I feared was going to be thermal torture on the motor, 2000 RPM for 20 minutes!), the temp never got off the second mark, the cooling fans never came on, and the engine compartment was quite cool. And yes, there was substantial heat coming out of the tailpipe.
Later, when I was messing around with idle mixture, and checking under the car for leaks, the downpipe was cool to the touch, while the oil filter console was hot enough to burn you. It is working beautifully.
Dan, I would strongly encourage you to add "downpipe" to your "bare minimum" list. I think the downpipe radiates far more heat than the j-pipe, and will drastically reduce under hood temps when coated.
PostPosted: Thu Jun 03, 2010 2:29 am    Post subject: Reply with quote
Huh?
The temp got up to the half-way mark and the fans did come on per normal. You then added coolant, which then brought the temp down a bit, which is also normal.
Keep in mind, the hood hasn't been reinstalled yet either and you had a fan pointed at the turbo from underneath.
I'm not saying the coatings don't work, but lets get a little more real-world data going here
PostPosted: Thu Jun 03, 2010 2:40 am    Post subject: Reply with quote
OK, perfesser, I didn't recall the fans coming on. The point, though, is that an uncoated exhaust during that breakin exercise would likely have been glowing and radiating substantial heat, and they did neither.
Oh, and you'll be glad to know I drained the break-in oil as you suggested!
gegge
PostPosted: Thu Jun 03, 2010 2:47 am    Post subject: Reply with quote
Interested to hear your views on DIY coating. I have Techline-coated the manifold, turbine housing, J-pipe and downpipe. Left the wastegate without "paint", it would be counterproductive considering the cooling fins.
Carl Fredrik Torkildsen
