What is the maximum power for a NA 924
Goto page Previous  1, 2, 3, 4  Next
931fan
PostPosted: Sun Jul 18, 2010 12:16 am    Post subject: Re maximum power Reply with quote
I've sent a mail to a well respected engine builder here in the UK http://www.ricwood.com/ and asked him what he thinks is possible. He's 'the man' when it comes to making the most out of what you've got!!
In the mean time I found another couple of pictures you might be interested in. The first is at Brands hatch but the more interesting one taken at Cadwell is of all the cars on the grid over 30 924 race cars that day I think. My first race at Castle Combe had 39 924 racers on the grid!!
I'll let you know what Rik thinks is possible when I hear back.
Steve
Whether you think you can or think you can't - you are right.
PostPosted: Sun Jul 18, 2010 5:07 am    Post subject: Reply with quote
Onna these days I need to get my FIA license, drop in on the fams in the old country and do a guest spot appearance...
PostPosted: Wed Jul 21, 2010 11:41 am    Post subject: Reply with quote
I have an n/a project coming online in a month or so that I have high hopes for. I don't want to tip my hand on the build sheet but let's say there were some pretty extensive mods being done as part of the build. I would like to get it all running and dynoed before I say too much but stay tuned...
PostPosted: Wed Jul 21, 2010 12:55 pm    Post subject: Reply with quote
Ed, can't wait for the details!
PostPosted: Sun Aug 01, 2010 12:28 pm    Post subject: Reply with quote
Not fully baked yet but coming soon...
PostPosted: Thu Mar 01, 2012 1:59 am    Post subject: Reply with quote
Bump for an update from 931Fan and from Ed on his NA build...
tyfighter123
PostPosted: Thu Mar 01, 2012 1:22 pm    Post subject: Reply with quote
It seems like everytime a thread gets good it goes cold..... there are so many posts that end with "I will post more soon" and then they die! Emoore I would love to see what you did with your build.
Porsche 924 1977 N/A
Mustang GT/CS 2007
Porsche 911S 1976
Porsche 931 1980
Porsche 931 1980 (parts car)
PostPosted: Fri Mar 02, 2012 4:18 am    Post subject: Reply with quote
Mine is out there. Search for "before and after"
PostPosted: Fri Mar 02, 2012 5:00 am    Post subject: Reply with quote
Search terms = "before and after", all words
Author = emoore924
Results = none
simsport
PostPosted: Thu Mar 08, 2012 9:35 am    Post subject: For power add less internal weight! Reply with quote
I think the answer with the NA car is to do the expected stuff, ie sort the flow across the head, yes good old inlet and exhaust, big valves etc and then make the internals as light as possible (light rods, pistons, valves and buckets) and increase the available revs. Power is work and time after all.
The other thing is to make it easy to drive and that does not mean stripping all the weight out, or at least it means being smart about it.
The 924 handles as well as it does because of its great weight distribution, strip out too much over the rear wheels and you will find it still handles pretty well in the corners but traction out of them will be a real issue and in the wet a nightmare. Just my thoughts.
Cheers
Simon
Blown is always best!
PostPosted: Thu Mar 08, 2012 10:51 pm    Post subject: Reply with quote
Simon's comments bring to mind also... be careful about planning on high revs. We've found - the hard way - that the lifter buckets are a weak point, at least in stock form. I don't think they're good for more than 7000rpm, and we normally limit our shifting to 6000 on our racecar for longevity! Stock ones crack at the valve adjuster holes.
Otherwise you'll want to talk to Dan about his solid lifter project...
PostPosted: Thu Mar 08, 2012 11:32 pm    Post subject: Reply with quote
Yeah, bigger cam, stiffer springs (as with the big valve head) and the Sten Parner solid lifters should help raise the RPM limit a little bit, but I don't want to be the guinea pig to find out how high! FWIW, I have a small shipment of the Sten Parner lifters on the way, 2 of 5 sets are already spoken for...
PostPosted: Fri Mar 09, 2012 12:44 am    Post subject: Reply with quote
I read a google translated article about this guy running a n/a in eiffel rennen 300km. Placed pretty good i must say:
http://www.motor-klassik.de/rennsport/eifelrennen-im-porsche-924-nach-hausfrauenart-2985471.html
Really fun to see the last years results, several 924s, both n/a turbo and GTS according to the results list. Really good results to. A really tough event for historic racing cars. I think he says 155hp with webers, head port and cam, tuned for endurance racing.
Google translate it and read yourself !
PostPosted: Fri Mar 09, 2012 3:50 am    Post subject: Reply with quote
That article is a hoot, especially with the strange translation.
My favorite line:
Quote:
Continue to 6500 as a spin is no point in doubt or fray, but the Porsche 924 engine has only about 7,000 in the period of self-destruction.
"...in the period of self-destruction".
hehehehe
I think we want to stay out of the period of self-destruction.
tyfighter123
PostPosted: Fri Mar 09, 2012 3:51 am    Post subject: Reply with quote
Dan is putting together the big valve kit with the stiffer springs and solid lifters for me. I also am going to use a set of Diamond pistons with 10.5:1 compression. I am also going to put in a scrapper. What else do you guys think I should do?
Mustang GT/CS 2007
Porsche 911S 1976
Porsche 931 1980
Page 2 of 4
