TPS on megatune dilema
Scorpio
PostPosted: Thu Sep 16, 2010 7:22 pm    Post subject: TPS on megatune dilema Reply with quote
Bench testing my TPS with megatune when i calibrate TPS i get:
Throttle shut ADC count = 38
WOT ADC count = 230
After i recalibrate my throttle position in megatune it starts on 10 % (with closed throttle) and opens to 92 %
Shouldnt after recalibrating it start on 0% and reach 100 % on WOT??
what am i missing? flood clear or physically adjust TPS??
1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
GT BASED CUSTOM BODYKIT
Brisbane , Australia
Think mean think fast
all youll see is
my Porsches Arse!!!
Arvidw
PostPosted: Thu Sep 16, 2010 8:07 pm    Post subject: Reply with quote
It should say 0 to 100% after calibration.
I find your ADC counts quit low, mine where around 120 to 1400.
Are you sure that connected the TPS correctly?
Porsche 924 2.0 Kompressor 136.1wHp @ 5650rpm / 201.9wNm @ 3900rpm (dyno @ dp-engineering.nl)
Scorpio
PostPosted: Thu Sep 16, 2010 8:18 pm    Post subject: Reply with quote
The mega manual says I'm within range , I'm quite certain I've wired it properly as it increases open percent in megatune as throttle is opened . Even when I type in different values into the adc count I press ok and it's still starts at 10% mystery
1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
all youll see is
my Porsches Arse!!!
Min
PostPosted: Thu Sep 16, 2010 11:57 pm    Post subject: Reply with quote
I'm not entirely certain why this is occurring, however it won't make any difference to your car's operation. Set your floodclear to 75percent, and off you go.
Min
Martijnus
PostPosted: Fri Sep 17, 2010 7:11 am    Post subject: Reply with quote
I'm sure it has nothing to do with it, but my MS started to flip out when I tried to calibrate the tps on a running engine. So since you're benchtesting it, be sure you don't have a crank signal.
But i'm probably confused... because you don't have a seperate TPS and megastim at the same time... and without the stim you probably haven't got a crank signal.
Weird problem though.
Have you tried turning it off and on again? (I mean flashing the firmware).
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
RC
PostPosted: Thu Sep 23, 2010 10:07 am    Post subject: Reply with quote
Have you sussed this out during your 12 hr sess?
One way or another, it is not right.
Assume correct communication, code, .ini file for MT, wiring, etc for MS1. Low ADC @ WOT indicates low voltage. Caused by high resistance TPS, very poor earth, low angular deflection of TPS or limited butterfly movement; should be around 80 - 90* with TPS at say 100 - 120* for full coverage.
What TB?
What TPS?
Voltage readings of all 3 connections @ TPS on idle/closed throttle and also at WOT?
Hint - one should be 0 - 0.2V and earthed at same physical location as all other MS earths, and another at 4.8 - 5V. The sweeper terminal should vary between 0 and 5V but in your case will likely only be around 0 - 2V?
Scorpio
PostPosted: Thu Sep 23, 2010 2:32 pm    Post subject: Reply with quote
Ok will check it out rc the engine is on a stand and in earthily everything straight back to the battery negative. I'm wondering if something is wrong with my megasquirt as throttle on megatune originally would climb to about fifty percent with no tps plugged in but now with no tps it goes to 100% open what specifically could be making it act all hormonal like this ?
1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
all youll see is
my Porsches Arse!!!
RC
PostPosted: Thu Sep 23, 2010 3:00 pm    Post subject: Reply with quote
MS should be Ok as a FLOATING input like that will result in anything. Leaves it vulnerable to picking up static too. NEEDS between 0 and 5V to it to make it function rationally, even earthing out for 0V. A basic test is connecting both earth (simulating closed throttle) for ADC count and then 5V for a WOT reading.
Min
PostPosted: Fri Sep 24, 2010 12:23 am    Post subject: Reply with quote
Don't expect rational results when you don't have a TPS plugged in. This actually caused me some headaches, install a resistor or plug in a TPS. I have a resistor installed in mine. It does wonky things if you leave it as a floating input. And MS will do things based on that wonky input, BTDT.
Min
Scorpio
PostPosted: Fri Sep 24, 2010 9:51 am    Post subject: Reply with quote
It was doing strange things with it plugged in ie 10-92% after calibration . With it not plugged in I was curious why it was the only real time gauge input doing strange things. I'll move the tps around and see if starting a closed throttle with different original tps orientation does anything
1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
all youll see is
my Porsches Arse!!!
Min
PostPosted: Fri Sep 24, 2010 11:10 am    Post subject: Reply with quote
The TPS input floats when not plugged in this means it jumps around, or slowly changes to weird numbers, that's 'normal' behavior. Its not desirable behavior. Plug it in, or put a resistor inline.
Min
Scorpio
PostPosted: Tue Oct 12, 2010 10:01 pm    Post subject: Reply with quote
ok Jim stim finally arrived...and confirms that there is something wrong with TPS on my megasquirt
calibrating jimstim i get adc=0 and adc =254
BUT
when i slowly rotate the TPS knob on the stimulator it doesnt slowly rise or fall it jumps from 0-33-66-100 but mainly straight from 0 to 100% open
dont know why this is??
1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
all youll see is
my Porsches Arse!!!
Rich H
PostPosted: Tue Oct 12, 2010 10:48 pm    Post subject: Reply with quote
Easy, don't use TPS just wire a resistor in it's palce and run on MAP.
Mine ran just fine like that, read an article on MSEFI.com about the lag between MAP and TPS and it was rediculously tiny like milisecs.
Scorpio
PostPosted: Tue Oct 12, 2010 10:59 pm    Post subject: Reply with quote
good point Rich! will keep trying with this and if i cant get it to work then resistor it is
EDIT
OK after some playing its working now?..strange thing is i can remove throttlefactor.inc file from mtcfg folder and it still works?? why so tempremental?..seems like its working now but wasnt 10 min ago
im using megatune 2.25 p3 without the extra code (think its original B and G code) where exactly do i check which code im running? ..i tried loading extra code but when shorting the boot load pins it didnt want to work...Im determined to get this sorted
1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
all youll see is
my Porsches Arse!!!
Scorpio
PostPosted: Tue Oct 12, 2010 11:30 pm    Post subject: Reply with quote
turns out its not working!??...
i thought it was but whenever ide calibrate it at say 50% throttle to be fully closed it wouldnt hold the calibration value....its only going 0 adc to 254 adc because the resistance on the jim stim is made that way..NOT because the calibration is working......very frustrating
1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
all youll see is
my Porsches Arse!!!
